x runner rims on 4cyl.
Old 08-06-2012, 05:13 PM   #1
808tacomas [OP] 808tacomas is offline
808tacomas is on a distinguished road
808tacomas's Tacoma Gallery
i have an 11 double cab 4cyl and i am wondering if xrunner rims and tires can fit on my truck without any mods?
Old 08-06-2012, 07:15 PM   #2
Manual Transmission Enthusiast
TacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shedTacomaBuzz is one of the sharper tools in the shed
TacomaBuzz's Avatar
TacomaBuzz's Tacoma Gallery
Yep they will fit perfectly with no mods!
Old 08-06-2012, 07:26 PM   #3
Rich91710's Avatar
Rich91710's Tacoma Gallery
As long as you have a 5-lug and not a 4x4 or Prerunner
Old 08-18-2012, 06:46 PM   #4
shoots bra u guys da shit
Old 08-18-2012, 06:47 PM   #5
and do i have to take out the black boxs?
Old 08-18-2012, 10:05 PM   #6
TacomaBuzz's Avatar
Check out ryanjboutin's build page, he's running XR Rims on his 5-lug. He should be able to answer more questions for you,http://www.tacomaworld.com/forum/2nd...ld-down-2.html
Old 08-24-2012, 12:05 AM   #9
I'm gunna go check out these xr rims tomorrow and hopefully it's good because most likely I'm gunna buy them and if I do I'm putting pics on Sunday. So just swap and go?
Old 08-24-2012, 06:19 AM   #10
ivel is on a distinguished road
ivel's Avatar
ivel's Tacoma Gallery
That's my understanding.
Old 08-24-2012, 06:02 PM   #11
Xr
Originally Posted by Kelson View Post
nah unless you goin run massive tires no need cut the black box...if you keep the stock XR sized tires you'll be fine.
Do you know the size that it will rub? Because the rims I'm looking at the guy put on new tires n he doesn't know the size....lol
Old 08-24-2012, 06:07 PM   #12
245/40. Will clear it?
Old 08-24-2012, 08:10 PM   #13
ivel's Avatar
235/75/15's are 11% bigger than 245/40/18's so I would say they will clear.
Old 08-24-2012, 09:56 PM   #14
i did not know that.. thanks bro
Old 08-24-2012, 10:32 PM   #15
Rich91710's Avatar
Really consider going bigger.
With the 245/40-18 on there, your speedo is going to read 65 (actually a bit higher) when you're only doing 62.
My 5-lug is already 3-5mph fast...
245/45-18 would be close to your stock 215's. Personally, I'd go with a 50 series to bring the speedo down a bit closer to reality.
Old 08-24-2012, 10:56 PM   #16
This space intentionally left blank.
Boring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shedBoring is one of the sharper tools in the shed
Air Force: Discharged honorably many years ago.
Boring's Tacoma Gallery
The tires for the 4 cylinder 2wd are 215/70-15, not 215/75-15. I was just at the tire store.
Old 08-24-2012, 10:59 PM   #17
Rich91710's Avatar
Correct... that's what I based my calcs off of in recommending the 245/50-18
Ivel was using the 235/75-15 because we know they fit.
Old 08-25-2012, 05:42 PM   #18
im undecided on what tire size i should get without worrieng about rubbing or needind to take out those blaack boxes
Old 08-26-2012, 12:26 PM   #19
ivel's Avatar
Old 08-26-2012, 01:25 PM   #20
Rich91710's Avatar
Unless you lower your truck, you are not going to rub on any low profile tire up to 245 or 255. The issue is mostly diameter. Guys doing off-road setups are going larger diameter than stock without needing to do more than remove the black boxes (which is not a big deal at all).
Refer to this:
tire calculator
Your stock size tire is 215/70-15, which is about 27" tall.
We can easily fit 235/75-15 without rubbing, which is about 29" tall.
To get to a 29" tall tire on an 18" rim would require 235/60-18, or a 255/55-18.
245/50-18 is less than 1" taller than stock and will fit without a problem.
X-Runner Rims ParisTexas Buy / Sell / Trade 6 01-10-2011 06:30 PM
Looking for S Runner rims Rockit 2nd Gen. Tacomas 6 12-25-2010 07:57 AM
Looking for S Runner rims. Rockit 1st Gen. Tacomas 0 12-24-2010 06:46 AM
need new rims and tires for stock 08 access 4x4 4cyl hondarida122 Wheels & Tires 8 07-28-2008 06:29 PM
Tire Size on 4cyl - NOT PRE-RUNNER thehtizzle@gmail.com Wheels & Tires 13 06-22-2008 08:24 PM
