5 lug upgrade to electric locking differential?
Old 12-23-2012, 08:02 PM   #1
smbrewer [OP] smbrewer is offline
smbrewer is on a distinguished road
smbrewer's Tacoma Gallery
New here and got a question:
I have a 2008 access cab. I understand that in 2009 Toyota added an electronic locking rear differential. Is it possible to "upgrade" to this axle and if so, what else would be needed. I'm just looking for some extra traction in snow and dirt. Perhaps just a limited slip would be better?
Thanks for any input.
Old 12-26-2012, 07:30 PM   #2
Joels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to behold
Joels98taco's Avatar
Joels98taco's Tacoma Gallery
are you trying to swap the whole axle or just the 3rd?
Old 12-26-2012, 07:36 PM   #3
Granite Guru
Spoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shed
Spoonman's Avatar
Spoonman's Tacoma Gallery
You'd have to swap the whole rear axle to an e-locker rear end.
You'd need the entire e-locker harness (not sure if you can buy it seperately).
Module(I believe there's a module to operate the locker.
Dash Switch
Personally I would wire it up myself with a wiring diagram.
Old 12-26-2012, 09:01 PM   #4
dont forget youd be making the rear of the truck 6 lug meaning you would need 2 different wheels with different bolt patterns... youd be better off getting an aftermarket elocker
Old 12-26-2012, 09:10 PM   #5
Granite Guru
Spoonman's Avatar
Good point^^
Wondering if you can swap out the 5lug axle shafts into the 6 lug e locker rear end? Either way, the non e-locker six is stronger, so it's better to put a locker in your axle.
Old 12-26-2012, 09:12 PM   #6
might be possible but im thinking spline count is different but you never know
Old 12-26-2012, 09:12 PM   #7
Cornfed
95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed
95 taco's Avatar
95 taco's Tacoma Gallery
Originally Posted by Spoonman View Post
Good point^^
i think i read somewhere that the shafts and spline are the same, so you could have a 6 lug rear and swap it to 5 lug.
Old 12-26-2012, 09:13 PM   #8
revised
TrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shed
Navy: HM1
TrdSurgie's Tacoma Gallery
Waste of time, effort, and money. Just put a after market locker in.
Old 12-26-2012, 09:14 PM   #9
Cornfed
95 taco's Avatar
Originally Posted by TrdSurgie View Post
Waste of time, effort, and money. Just put a after market motor in.
motor? this is about diffs.
Old 12-26-2012, 09:18 PM   #10
lolz
Old 12-26-2012, 09:27 PM   #11
might be true but then again better safe than sorry
Old 12-26-2012, 09:29 PM   #12
revised
Navy: HM1
Originally Posted by Joels98taco View Post
lolz
Distractions lol
Old 12-26-2012, 09:39 PM   #14
Cornfed
95 taco's Avatar
ford 302 swap and a spooled 9"
yyyyeeeaaahhhh buddy.
go to a junk yard and tear some diffs down and rebuild them with each others parts.
Old 12-26-2012, 10:06 PM   #15
not alot of newer tacomas in every junkyard. most around here dont even get toyotas
Old 12-26-2012, 11:45 PM   #16
Cornfed
95 taco's Avatar
forgot we were talking 2nd ten.
that might pose a problem with what i said earlier, because i think that was for 1st gens.
Old 12-27-2012, 07:54 PM   #17
afd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shedafd23a is one of the sharper tools in the shed
afd23a's Avatar
afd23a's Tacoma Gallery
Axle spline count should be the same between 5 and 6 lugs for the second gens too. I put a prebuilt third with 4.10 gears and an eaton LSD in mine with no problem. The third was originally built for a Sequoia and the guy I bought it from was going to put it in his 6 lug tacoma. I had to get the pinion flange changed but that was it.
Old 12-27-2012, 10:13 PM   #18
Professionull
battlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shedbattlescars is one of the sharper tools in the shed
battlescars's Avatar
battlescars's Tacoma Gallery
Ok first off, a Ford 302 is a pile, if you're not putting a Toyota motor in, the next step down in a Chevy LS (corvette) motor mind you.
Secondly, an electric locker is not that great. More moving parts, more money to throw into a interesting yet horrible design. You can get away with a regular locker just fine and not have to worry about an electronic connection issue and tire wear.
Third, if you want to keep the same lug pattern, (you can keep the rear end you have now) swap to an X-runner rear end which is still 30 spline, a little wider and can bolt up to your current rear drive line set up, has locker options and can handle a good amount of HP and torque for the trails.
But number #3 isn't necessary, its a necessity.
Old 12-27-2012, 11:34 PM   #20
Also 1st gen 5 lug is 7.5 6 lug is 8.4 or 8
Electric Automatic Differential Disconnec Lee from MN 1st Gen. Tacomas 3 01-20-2012 06:16 PM
How to tell if it has a Locking Differential ShaLor 1st Gen. Tacomas 2 05-21-2010 01:12 PM
What would it take to put the Electric Locking Differential in? Kuneff 1st Gen. Tacomas 32 11-20-2009 10:57 AM
Locking Differential VS. Open Differential Agent475 Off-Roading & Trails 0 12-18-2008 12:47 PM
Rear Differential Lock? Electric Differential Lock? tcboss 2nd Gen. Tacomas 12 01-23-2008 03:08 PM
