5 lug tire size.
Discussion in '5 Lug' started by 808tacomas, Feb 5, 2013.
  1. Feb 5, 2013 at 9:53 PM
    808tacomas
    808tacomas [OP] Well-Known Member
    kingrob
    oahu
    2011 toyota tacoma 4door 4 cyl.
    working on it..need some advice
    Alright let's get this straight guys.
    The largest tires that can go on with no lift and no rubbing without removing the Black Box is 235/75/15?
    If you remove the black box. The largest tire size is 30x9.5/15 with no lift and no rubbing?
  2. Feb 6, 2013 at 12:25 PM
    808tacomas
    kingrob
    oahu
    Sorry bro I'mma noob jus like you
  3. Feb 6, 2013 at 8:55 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    from what ive seen your correct.
  4. Feb 6, 2013 at 8:56 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    if your gonna lower a truck keep it stock sized tires or smaller. going bigger is kinda bringing the ride height back up so pretty pointless imo
  5. Feb 13, 2013 at 9:51 PM
    KDogg311
    KDogg311 Well-Known Member
    K H I E M ™
    So Cali 626 ³²³ 818
    Gen² Impulse Red Access Cab
    Avid Offroad light bar (Black), Avid Step bar (Black), TRD skid plate (Black), BHLM w/yellow signals, Pioneer Avic-x930bt, OEM fogs w/ yellow H10, Magnaflow muffler, aFe drop in filter, Toyota Neoprene "Tacoma" seat covers, Shorty antenna, Tint, Removed secondary filter, LED interior lights, LED reverse, Bedlinered rear bumper, color match grill, Black emblems, Red rear signals, Bed mat, OEM bike mounts
    This I know is true ... thats what I'm running
  6. Feb 13, 2013 at 10:18 PM
    tacotruck 2.7
    tacotruck 2.7 Well-Known Member
    Katy TX
    09 cab and a half 2.7
    i got the same truck went from 27 to 31x10.5x15" or 4" diffrence lost aprx 1.5-2 mpg. so u probably wont notice any diffrence depending on how u drive. however im easy on the gas pedal.
  7. Feb 14, 2013 at 5:40 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Your axle is an 8.4 keep an eye out on the tw classifieds for someone selling the 4.10s out of their 6 lug. The black box is in the front fender well behind the fender liner and when you put bigger tires they tend to rub they are for the mud flaps i think. What size wheel are you trying to run?
  8. Feb 14, 2013 at 11:53 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Any tire equivalent to about 28-30 inches would fill the fenders stock height. And for gears try east coast gear supply
