Straight bolt on black rims. "No mods"
Old 04-07-2014, 12:45 PM   #61
Josephm is on a distinguished road
Josephm's Avatar
Josephm's Tacoma Gallery
I want to thank the OP (Gitsum) and everyone else on this thread. Trying to find aftermarket wheels that properly fit a 5 lug is a chore. I ordered the Cragars from Summit Racing and just mounted them. I am happy with the results. Thanks again for the very useful info.
Old 04-07-2014, 04:39 PM   #62
jtye is just really nicejtye is just really nicejtye is just really nicejtye is just really nicejtye is just really nice
jtye's Avatar
jtye's Tacoma Gallery
Looks good man
Old 04-08-2014, 06:00 AM   #63
gitsum [OP] gitsum is offline
gitsum will become famous soon enough
gitsum's Tacoma Gallery
Thumbs up
NICE!
Old 04-08-2014, 11:41 AM   #64
Josephm's Avatar
I removed the ugly red and blue Cragar stripes. Fast and easy with acetone.
Old 04-09-2014, 08:17 AM   #65
Way better! I am SOOOO doing that!
Old 04-09-2014, 11:42 AM   #66
Josephm's Avatar
If you have these wheels, I highly recommend these hub centric rings. Dirt cheap right now on ebay. http://www.ebay.com/itm/140927444133...84.m1439.l2649
These rings eliminate the vibration caused by non hub centric wheels. Just pound them into the back of your wheels with a rubber mallet. The Cragar wheel bore is 83.8mm. My hub size is 60.1mm.
This specific size is needed for my truck. (Measure your hub diameter to be sure). 83.8mm OD 60.1mm ID
Old 04-10-2014, 07:03 AM   #67
never seen these before. They center better than the lugs? Have you noticed any difference before and after?
Old 04-10-2014, 09:30 AM   #68
Josephm's Avatar
You will only notice any difference at higher speeds. (60mph plus).
I do alot of freeway driving and noticed less steering wheel vibration right away.
These rings basically turn the Cragar wheels into hub centered wheels just like the stock steel wheels I replaced. Are they necessary? No. If you carefully star pattern tighten the lugs with the wheels off the ground, you are very close to perfect center. But for $13.88 and free shipping for all 4 rings this is a no brainer for me.
Old 04-14-2014, 02:19 PM   #69
Josephm's Avatar
A couple more photos. Notice the gap around the hub is eliminated. So is my steering wheel vibration. Back to factory feel driving.
Old 06-23-2014, 07:11 PM   #70
Cranky & often armed sysadmin
Xaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shedXaks is one of the sharper tools in the shed
Xaks's Avatar
Xaks's Tacoma Gallery
So, since I'm a n00bsauce at this....this is the 235/75/15s and Cragars strait bolt-on without a lift?
Old 06-24-2014, 06:04 AM   #71
Is it finished yet?
TommyTacomaNC is on a distinguished road
Navy: USS R. G. Bradley (FFG-49) OS2
TommyTacomaNC's Tacoma Gallery
Xaks, yep, pretty much that easy. Think i paid 57/wheel for mine from summit. Im running Wrangler DuraTrac's on mine, and get a little rub with wheels turned full lock in reverse, but i HAVE NOT done the black box mod, and they only LIGHTLY rub the plastic fender liner. I am not running centering spacers and am careful when torquing wheels to make sure they are centered on lugs. I get minimal vibration sometimes, but it's a truck, not a cadillac. : ) i just blame it on NC roads. hope this helps ya! It was the best $$ I've spent on my truck!
Old 06-24-2014, 05:34 PM   #72
Xaks's Avatar
Thank you very kindly, good sir. I called the wifey over and showed her the pic of yours and she literally said "Got-damn, now that's purty"
In my head I had been thinking 250 a pop for 5 rims, plus 200-250 each for tires, would be looking at 2000-2500 to do all 5 for Betty. To know I can do all 5 for less than $1000 made our evening.
*brofist
Old 06-25-2014, 09:14 AM   #73
Is it finished yet?
Xaks, Something to remember, if you have a discount tire nearby, they will price match. I got them to price match to 4X4 off road parts, and got my DuraTrac's for 140/ea, and they also matched the $60 rebate that was offered by the other company. The part that hurt, I couldn't get around the TPMS sensors as I wanted to keep my factory wheels/tires for spares. I still did all four for around 900. Next is the Ready Lift leveling kit... good luck, post us some pics when you get it done!
Old 07-14-2014, 09:54 AM   #74
eclipse22 is on a distinguished road
eclipse22's Tacoma Gallery
http://m.summitracing.com/parts/usw-044-5712/overview/
I wanna pull the trigger on these...Can you guys tell me 100% if these will fit properly.?
Old 07-15-2014, 09:07 AM   #75
Is it finished yet?
I don't know if anyone here has tried them, I DO know that the clearance issue is with the caliper/bar that goes around the caliper. My Cragars are VERY VERY close to the bar but as of yet do not rub, you may have to order one and check fitment before ordering the others. If you do, please let us know how it goes! Essentially we are putting RWD wheels on a FWD front end, you can even see the plugs where the axles are supposed to go through the "hubs" on our front ends, so even larger dia. wheels may not work, it's all about the offset and wheel contour where it meets the hub : (
Old 07-16-2014, 12:24 AM   #76
worst case scenario i would have to buy a 5mm spacer?
Old 07-16-2014, 08:21 PM   #77
SoCalSparky53 is on a distinguished road
SoCalSparky53's Tacoma Gallery
I tried the 15x8 4.5"BS and the caliper held them off about 3/4". If you try them let me know if they fit.
Old 07-24-2014, 11:20 PM   #78
can you provide a pic?
Old 07-27-2014, 03:56 PM   #79
Sorry ive already returned them.
Old 08-21-2014, 07:00 AM   #80
So its been a little while now. Has anyone found any other rims that to fit with out modding?
xd 20" black rims and 35" tires simonsay Wheels & Tires Marketplace 16 11-22-2013 08:00 PM
"Best" way to achieve black rims? Yoshio 2nd Gen. Tacomas 67 09-03-2013 08:33 AM
Black "women friendly" rims parnell14 Wheels & Tires 9 08-12-2012 11:59 AM
WTS-4 Black "Baja" Rims, $550+Shipping mrw3685 Buy / Sell / Trade 22 02-20-2012 09:20 AM
16" BLACK MB Chaos 6 WHEELS RIMS 6x139.7 (6x5.5") LUG with a -6mm backspacing luco1029 2nd Gen. Tacomas 2 10-20-2010 02:56 AM
