2014 5 lug with 4.10 ECGS rear
Old 06-11-2014, 07:58 PM   #1
navin [OP] navin is offline
navin is on a distinguished road
Law Enforcement: Ret.
navin's Tacoma Gallery
I installed a new third in my truck a couple weeks ago. I was figuring it would need bigger tires to kinda make it tolerable after I finished but I knew for sure the 3.31 stock ratio wasn't going to work for me. A travel trailer is in my near future, and I tow a small boat and load with motorcycles weekly.
Stock I was stalling on uphill starts EMPTY and smelling clutch when backing into my barely sloped driveway with a 1000 lbs. total trailer/boat combo. Not good.
I was stuck between 3.73, 3.90 and 4.10... I am glad I went to the lower ratio in my sites.
I'm happy to report the new 4.10 and stock tiny wheels/tires are just fine. In fact, my MPG have stayed the same. a tank of mixed driving and up to 80 MPH actual speeds netted 23.5 and 24.5 MPG. If I can manage to stay below 65 I'm sure that can go up a bit.
The engine feels like it has been set free. It (relatively) leaps forward now with a bit of throttle. It was struggling badly before.
Stalling on uphill starts is a thing of the past. I can release the clutch with no gas pedal and the truck walks away at idle. Throttle response is absolutely transformed, the thing pulls now. It feels like it lost 1500 lbs. off the bare truck.
First is slightly short, but unless you are rolling at least 5 MPH, second is just a skootch too tall to start in. So, first gear start, then shift to second after you are at least rolling. Highway speeds to 80 MPH cruise are smooth and quiet. It'll pull 5th gear cleanly at around 1500 RPM/40 MPH on semi flat roads.
Stock it could comfortably cruise at 50 MPH in THIRD GEAR!!!
My local mountain road downhill was a death ride dragging 3rd gear stock, it would soar to over 50 MPH easily requiring heavy foot braking. Second gear was too short, and it would rev to the moon. With the 4.10s it holds the truck perfectly at around 35 MPH.
In short, it cost me $1035 and 2 hours on my back and was worth every cent and bit of wrenching. Why this truck isn't stock with this ratio I can't understand.
Old 06-12-2014, 01:27 PM   #2
jtye is just really nicejtye is just really nicejtye is just really nicejtye is just really nicejtye is just really nice
jtye's Avatar
jtye's Tacoma Gallery
i've got a 4.10 third in my 5 lug as well (i've got 31's), but you're totally right. Should just build the cost of a new third into any new 5 lug. ooorrrr just save for a 4x4, but that's another thread.
Old 06-12-2014, 01:58 PM   #3
Half Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant futureHalf Caf has a brilliant future
Coast Guard:
Half Caf's Tacoma Gallery
JT, do you mind sharing what you paid for yours? I'm thinking this mod may be in my future as well and am wondering where people usually source their gears from.
Old 06-12-2014, 02:39 PM   #4
Whatever the cost, forget the stock third as a core, it is only 3.31 ratio compatible. I tried to sell/give mine away as it was brand new. I ended up recycling the damn thing.
Another note for Toyota, if you must install crazy tall gears for some reason, use the 3.52 in both the stick and auto trucks so we can rebuild the OEM third!!! So STUPID.
I coulda done this job locally for about half the cost if my third could accept lower ratio gears.
Old 06-13-2014, 05:49 AM   #5
Mr. Pick is on a distinguished road
Mr. Pick's Avatar
Mr. Pick's Tacoma Gallery
Did you correct the speedometer? If so, how do you change it?
Old 06-13-2014, 07:04 AM   #6
No, it reads high by 2-3 MPH at 70 so easy enough to remember. I'll probably get slightly taller tires when these wear out and that should be close enough.
Old 06-13-2014, 07:41 AM   #7
jtye's Avatar
Yeah no problem. I got mine from another TW member for $400 i think? Maybe $450. Installed it with a buddy, super easy if you've got the tools. Just bolts on, lots of write ups on TW.
Old 03-14-2015, 01:13 PM   #8
I ended up with 4.88s, a Detroit True Trac locker, 30x 9.5 -15 tires and she drive great. It's actuall fun to rev it out now. Shifting point went from max 3000 to freely spinning to 4500 without the horrible strain it seemed to suffer with stock gears and the 4.10 and the 30" tires.
The engine used to feel thrashy, now it friggin zips!
It is actually quick now!
Don't fear the gear! I always err to the lower ratio when trying to decide.
The locker is pretty great, no wheel spin at all on rain soaked streets. I drove thru and stopped in 8" of unplowed snow with ice under it. No problem.
If I get stuck now, I'll deserve it.
Old 03-14-2015, 01:54 PM   #9
Coast Guard:
Nice! Good to hear the locker is working well for you. I can't wait to ditch the stockers I'm currently running
sold Azdesert50 2nd Gen Tacoma Marketplace 5 12-30-2014 05:39 AM
4.10 IFS front + 4.10 8" elocker rear diffs digitalferg 1st Gen Tacoma Marketplace 11 02-22-2014 04:10 PM
5 lug rear end with 4.10 jeffz0rz 1st Gen Tacoma Marketplace 6 09-10-2013 01:27 PM
4.10 gears factory from 06 2.7l 4x4 front and rear 4.10 bigskytacoma 2nd Gen Tacoma Marketplace 23 08-13-2012 08:12 AM
6 Lug rear Spring on a 08 access 5 lug? Blackcat10 5 Lug 5 07-19-2012 06:34 PM
