ReadyLift 2.75" Lift for Tacoma 5Lug
Discussion in '5 Lug' started by david04, Mar 16, 2008.
  1. Dec 3, 2010 at 10:03 PM
    #41
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    had this lift installed in my 2010 5-lugger access cab less than a month ago. along with bfg 245/75/16zz. and bilstein ft/hd-struts and rear/shocks + realignment . it`s 100 times better than the stock peanut wheels & ride.:eek:
    CrazyJoey1999 likes this.
  2. Dec 4, 2010 at 5:24 AM
    #42
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    im running 30x9.50 yokahama a[​IMG]/t's
  3. Dec 4, 2010 at 6:10 AM
    #43
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Nice wheels!
  4. Dec 4, 2010 at 6:18 AM
    #44
    TIM GAINOUS
    tallahassee fl
    o7 base desert sand
    THANKS! cool thing is i bought em for $50 apeice. un cool thing is they were[​IMG]
    discontinued so if i ever mess one up ill hafta swap the whole set.
  5. Dec 11, 2010 at 10:29 AM
    #45
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    Has anybody replaced their rear shocks? Ever since I installed my lift kit, I noticed my bed slams every time I go over bumps. Any suggestions? Thanks
  6. Dec 11, 2010 at 4:38 PM
    #46
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
    neslerrah did because of this issue. this is also why if you buy the fat bob's lift you get extended length shocks. neslerrah bought used trd billie's of another member here...
  7. Dec 29, 2010 at 8:11 PM
    #47
    aggiepack
    aggiepack Well-Known Member
    Nate
    [**SOLD**] '08 Super White reg. cab waiting for the '16
    Fat Bob's 5 lug 2."75" Lift Kit, Fat Bob's Performance 8000 Rear Shocks, 235/75/15 BFG A/T tires, UWS Low Profile Tool Box, AVID Off Road Sliders, Chrome Grille Assembly, Fog Lights, Black badges, Tinted Rear Window, TRD Bed Mat, TRD Off Road Floor Mats, Maglite Mount, CoverKing Seat Covers
    I just installed the readylift kit in my garage on my 5 lugger today. I put on rear shocks from Fat Bob's Garage. I'll post pictures later. Took it out for a drive and it really doesn't feel that stiff or tough or anything it's quite a nice ride
  8. Dec 29, 2010 at 8:19 PM
    #48
    TIM GAINOUS
    tallahassee fl
    o7 base desert sand
    its fine unless y[​IMG]ou hit a spped bump or somethng similar. the diff in height is great though imo.
  9. Dec 29, 2010 at 8:39 PM
    #49
    aggiepack
    Nate
    Oh without a doubt the height difference is amazing! That's true - I have yet to go over any rough bumps or such. Need to get it aligned tomorrow so I'll just wait. JW but did anyone replace the stock front shocks just because while they installed the lift kit? Just curious that's all
  10. Dec 29, 2010 at 8:47 PM
    #50
    TIM GAINOUS
    tallahassee fl
    o7 base desert sand
    not to my knowledge. theres no reason to unless youre gonna hammer on it. if so, id get a different truck. just my .02
  11. Feb 7, 2011 at 3:50 PM
    #51
    MotoPhotog
    MotoPhotog Member
    Darren
    Covington, WA
    09 Access cab SR5
    8000k HID's
    Aggie, looking forward to a few level side shots of your truck!!
    Sounds like you did your truck the RIGHT way, and spent what... 65 more bucks on the shocks? Excited to see it.
    I am hoping it doesnt look lower in the back. Seems like the trucks I've seen lifted with the 2.75" kit, it looks like it is lower in the back. Which I dont want. I cant imagine how horrible that would look with two dirtbikes in the back.
  12. Feb 7, 2011 at 10:45 PM
    #52
    aggiepack
    Nate
    It is definitely not lower in the back! With the kit I would say it is just about as even as you can get it. Here are two pictures of my truck. There are a few more on a thread i started on the 5 lug discussion. Note: I only have 235's right now but with 245's or 265's it will fill the back wheel well a lot more. I parked next to a 2nd gen access cab today and with the lift I'd say I was only about an inch or two shorter than it. If I had larger tires I would've been just as high. But that's another story. Hopefully I'll be getting a prerunner access cab in 2 years - Gotta save up for mods on that future baby :)
  13. Feb 8, 2011 at 8:26 AM
    #53
    MotoPhotog
    MotoPhotog Member
    Darren
    Covington, WA
    09 Access cab SR5
    8000k HID's
    Aggie looks great.
    So, is this all that you purchased??
    http://store.fatbobsgarage.com/toyota-tacoma-2wd-5-lug-suspension-lift-kit--2005-2009-p7611.aspx
    Was it a standard or longer leaf??
  14. Feb 8, 2011 at 6:30 PM
    #54
    TIM GAINOUS
    tallahassee fl
    o7 base desert sand
    them dirtbikes'll make it squat stock if its gonna. the shocks have nothing to do with that. the 2.75 lift comes with an additional spring. (add a leaf) mine sat ass-high at first. its l[​IMG]evel now.
  15. Feb 9, 2011 at 10:07 PM
    #55
    aggiepack
    Nate
  16. Feb 14, 2011 at 7:36 PM
    #56
    mcleod90
    mcleod90 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    hey aggiepack any reason why you did the readylift kit and adding just the fat bobs rear shock?
    also on a side note where did you get your fogs?
  17. Feb 15, 2011 at 2:18 AM
    #57
    scott572011
    SCOTT
    SO-CAL.
    HAD THE LIFT INSTALLED, FIGURED MIGHT AS WELL DO THE SHOCKS & STRUTS WHILE IT WAS STILL IN THE AIR + REALIGHNMENT. MILES IN 307 MILES OUT 307.2 ​
  18. Feb 21, 2011 at 9:04 AM
    #58
    Poot Klopp
    Poot Klopp Well-Known Member
    Ben
    New Jersey
    2024 Lurker
    for people running spacers/aal and upgrading there shocks, do the bilsteins have more travel distance than OEM?
  19. Feb 21, 2011 at 2:40 PM
    #59
    afd23a
    The Dynamo of Dixie
    The front struts are okay to leave stock, however I decided to go ahead and swap them out when installing the lift. I replaced them with Bilstein HD shocks made for the 5-lug. I'm guessing they don't have any more travel than the stock struts and you shouldn't need extra travel in the front.
    The rears are a different story. Readylift claims that you don't have to change the rear shocks but then folks complain about the rough ride. It's better to swap them out with longer shocks like the ones that come with the fat bob's spacer kit. Another option is to use rear shocks that are made for the 6-lug tacoma. They are longer and can accommodate the extra travel.
  20. Apr 7, 2011 at 2:07 AM
    #60
    mayday671
    mayday671 Well-Known Member
    Ralph
    Oahu
    A work in progress!
    For the rear upgrade, you suggest shocks from a 6-lug. Is this from any 6-lug or the TRD editions? Please clarify, I just ordered my readylift and if I want a decent ride I minus well take care of the rear shocks while it's in the air. Thanks!
