Stock 6lug skid plate on 5lugger Taco
Discussion in '5 Lug' started by 05RedTaco, Nov 28, 2010.
  1. Nov 28, 2010 at 1:04 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I wanted to try this, I knew that most likely the bolt holes won't line up, however I was pretty certain that the skid itself will fit. I researched and some people make skid plates for 5lugger Tacos, however those can be expensive... around $200 shipped, that definietly wasn't in my budget....
    I posted a thread in the AZ section asking if anyone has stock 6lugger skid plate laying around. I wanted to come by and test fit the skid, just to see if it works. Even used the stock 6lugger skid plate is cheaper than custom 5lug skid plate.
    Fellow member OH-MAN pm'd me and told me he has two stock 6lug skid plates laying around and that I can have one. I was stoked! I came by the next day and got the skid plate from him. Many, many thanks to OH-MAN for giving me the skid plate! Thanks to him I was able to verify that stock 6lugger skid will fit 5lug Tacos!
    Then I went to my buddies house where we talked about how to mount it. No holes lined up. So this had to be completely custom. I figured out where I want the mounting points to be. Two in the back and one up front. The reason for one up front, is because nowhere else on the front the skid touched in large enough area to drill & get a sturdy bolt there. I got Drill bit for hard metal from ACE hardware and some 8.8grade hex bolts, washers & nuts.
    Install was easy. I had my friend hold the skid tightly to the truck, while I drilled. It turned out great and it should provide some protection. I am not certain about just one bolt up front, however I think it will be ok.
    Now for pictures;
    The skid even clears the front sway bar, gotta make sure that the skid is centered and that same amount of clearance is on both sides of the front sway bar.
    In this picture you can clearly see the one bolt up front and two bolts in the back.
  2. Nov 28, 2010 at 1:14 PM
    OH-MAN
    OH-MAN Well-Known Member
    Steve
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Nice job !!
    Glad you could use it.
  3. Nov 28, 2010 at 1:16 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    thats sweet. i will keep this in mind.
  4. Nov 28, 2010 at 7:20 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    thats pretty sweet, i had no idea you could do that! ill probably do that in the future
  5. Dec 1, 2010 at 9:53 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Looks good, you just need to extend it so it covers the oil pan.
  6. Dec 5, 2010 at 10:56 AM
    113tac
    Stephen
    Northern Virginia
    did you have to remove the two bars that are in the same location?
  7. Dec 5, 2010 at 11:14 AM
    05RedTaco
    Tony
    Scottsdale
    Nope. I didn't remove anything, just screwed it in...LOL
  8. Dec 5, 2010 at 11:16 AM
    113tac
    Stephen
    Northern Virginia
    oh okay thanks
    EDIT: what type of drill did you use?
  9. Dec 5, 2010 at 11:27 AM
    05RedTaco
    Tony
    Scottsdale
    Just a regular cordless Black & Decker drill. Make sure to get drill bit for hard metal.
  10. Dec 5, 2010 at 11:37 AM
    113tac
    Stephen
    Northern Virginia
    oh alright, i might get a skid that i found for sale on here
  11. Dec 5, 2010 at 3:58 PM
    05RedTaco
    Tony
    Scottsdale
    Cool! If you do, post pictures of how you mounted it!
  12. Dec 5, 2010 at 6:02 PM
    113tac
    Stephen
    Northern Virginia
    alright man i will if i do end up getting the skid
  13. Dec 7, 2010 at 9:42 AM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    hows the clearance for getting the oil filter off?
  14. Dec 7, 2010 at 11:44 AM
    05RedTaco
    Tony
    Scottsdale
    The skid plate is far from the oil filter...
  15. Apr 22, 2011 at 1:10 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    This is what I was looking for.
    Wanted to see this thread before I went ahead and pulled the trigger on having a 6 lug skid shipped out to me from Cali (I'm in Ohio).
    OP, with the truck parked, are you able to tell that there is a skid plate under it?
  16. Apr 22, 2011 at 8:26 AM
    05RedTaco
    Tony
    Scottsdale
    Yes! It looks installed the same as on any 6lug Taco...
  17. Apr 22, 2011 at 7:06 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Awesome Opposum.
  18. Apr 22, 2011 at 9:47 PM
    alexmxman185
    alexmxman185 Keepin' it dirty in Texas
    Alex
    Waco, Texas
    08 toyota tacoma 2.7 4 cly 5 lug
    Black grille guard with mounted kc road lights, 31x9.5x15 AT on stock rims. My future mod list: new white front bumper, Fat Bobs 2.75 spacer lift with rear AAL, american racing Flat Black Rims, 32x11.5x15 BFG A/T, satoshi grille with road lights mounted behind it, 8000k HID for all lights, 1'' Body Lift, new window tint, blacked out headlights and taillights, custom hood scoop, weather tech floor liners, LED dash cluster replacement, Front bilstein shocks, 40 series flowmaster, paint all my badges black.
    im getting a skid plate too for free and now i know how to install it :D thanks man!
  19. Oct 12, 2013 at 11:47 AM
    Braking Bad
    Braking Bad Member
    I did this today. I had bought one thinking that I would bolt right up. It has been sitting around for almost a year.
    I cut some slots in the plate and bent down the tabs on the braces so they would fit through and support each side. Then Bent them back up once it was on.
    Probably would have been better to drill through and then tap the holes in the braces.
    I dont know how you had the patience to drill the braces I just used hose clamps.
    And I cut away some on each side to clear the x runners sway bar.
