-   5 Lug (http://www.tacomaworld.com/forum/5-lug/)
-   -   5 lug driveshaft question? (http://www.tacomaworld.com/forum/5-lug/163463-5-lug-driveshaft-question.html)
bills yota 2wpeel 06-22-2011 07:12 PM
Could somebody take a picture of the area where the rear driveshaft slides into the transmission on their 5 lug standard cab manual 05up tacoma? I need to know how far into the transmission the driveshaft should normally be.
Im having problems with a leaking seal and looseness on the output shaft of the transmission probably caused by my lift and driveshaft angle. I think the driveshaft is too far to the back now. I swapped the center section with one from a older truck with different gearing too. Thanks for any help.
Joels98taco 06-25-2011 08:31 PM
that older 3rd member could be your issue
bills yota 2wpeel 06-26-2011 06:16 AM
The center came from a '96 4x4 non ELD. I was told the '08 and it were both the 8.4 diff. They looked identical, but I did have to swap the pinion flange from my '08. Any ideas? Thanks.
Joels98taco 06-26-2011 02:29 PM
what im thinking is that the 3rd member you swapped in may be slightly shorter than the one you took out causing the driveline to be pulled back
NakedTacoma 07-12-2011 05:24 PM
http://i80.photobucket.com/albums/j1...ic/photo-5.jpg
NakedTacoma 07-12-2011 05:50 PM
i dont think so unless he has linked suspension .... i have a race pack and at full droop the driveshaft pulls out but no issues and im sure my DS is coming farther out than his. the pinion/ds angle would be my first guess.
To the OP do u have any DS vibrations?
bills yota 2wpeel 07-15-2011 07:50 PM
No vibrations from the driveshaft at all. Looking at your picture, id say the slip yoke looks right. Im thinking now that a bad U-joint on the differential side may have helped cause the problems on the transmission side. I replaced the seal on the trans and both driveshaft u-joints, but the transmission is still leaking. I put 3* shims on the axle to help the angle.
I thought maybe I could just buy the slip yoke and it would be tighter on the splines, but the dealer shows the entire driveshaft sold together. I guess I'll just have to add oil and hope the output shaft bearings dont go bad on the transmission.
Joels98taco 07-15-2011 11:34 PM
that sucks man. hope you get it fixed soon
