-   5 Lug (http://www.tacomaworld.com/forum/5-lug/)
-   -   Fatbobs lift - not completely happy. (http://www.tacomaworld.com/forum/5-lug/201339-fatbobs-lift-not-completely-happy.html)
Rob1234 01-29-2012 05:03 PM
Thanks to the discussions on this forum I was able to decide on what I wanted to do on my new 2011 access tacoma 5 lug 4 cyl. I was not happy with how low the truck was so I decided on the FatBobs lift for 5 lug with the front spacer and longer rear shocks as well as the long AAL.
I like it overall. The only thing I do not like is the the nose sits slightly higher. Maybe an inch. I thought I could live with it but after three months I still can't deal with it.
I have researched relentlessly but I cant find the answer to my problem while knowing very little about trucks in general.
Can somebody please guide me as to how I can add 1-2 inches lift to the rear. How about the 3 leaf options? Not sure what exactly they are but would this option replace the existing AAL and add some lift? Or maybe getting a smaller spacer for the front. I would rather not lower the front but if that is the only option for a level or slightly higher rear I will have to do it.
Thanks to everybody for their valuable input.
Konaborne 01-29-2012 05:11 PM
http://www.tacomaworld.com/forum/sus...tml#post398462
check this post out regarding rear lifts.
for more lift in the rear, you can look at new leaf packs
KPT 01-29-2012 05:12 PM
See Johns tacos post below
Johns Taco 01-29-2012 05:22 PM
You cannot add a block since 5 lugs are sprung under axles, adding a block lowers the rear. I have this same problem with the same lift on the same truck, my rear is sagging 2" and I am too not happy. I ordered helper airbags for the rear and they should be here on tuesday, will install them next saturday. Will post pics and comments on if this works out for me. New leaf packs are over $500, this kit cost $233.
Bought them from autoanything.com.
Rob1234 01-29-2012 05:22 PM
Thanks for the quick response.
Will look into the 1 inch block. Any recommendations on vendors? Also, any concerns with blocks for normal street driving?
Rob1234 01-29-2012 05:23 PM
Wow, blocks not an option.
KPT 01-29-2012 05:24 PM
Originally Posted by Johns Taco (Post 4455607)
You cannot add a block since 5 lugs are sprung under axles, adding a block lowers the rear. .
Crap you are right. Editing my post now.
Rob1234 01-29-2012 05:25 PM
Hey John, I will let you know if I find anything else as well.
Johns Taco 01-29-2012 05:27 PM
Here is the link to what I got
http://www.autoanything.com/suspensi...0A3398743.aspx
Konaborne 01-29-2012 05:30 PM
I like confusing prerunners with 5lugs. It makes me look really smart. :thumbsup:
sorry OP
Rob1234 01-29-2012 05:30 PM
Originally Posted by Johns Taco (Post 4455651)
Interesting find. I have been searching for days. Did not come across this. Which leaf options exists and what lift would they add?
Rob1234 01-29-2012 05:31 PM
sorry OP
No problem. I appreciate the effort.
Rob1234 01-29-2012 05:34 PM
Looking at this product. How much lift would this add?
Konaborne 01-29-2012 05:36 PM
http://www.tacomaworld.com/forum/2nd...-build-up.html
maybe send ryan a PM on his rear setup
Johns Taco 01-29-2012 05:37 PM
I exhasted the internets resources on this. New leafs is the best choice{over $500}, heard pre-runner leafs will fix it but not sure about this and finding {good}used pre-runner leafs for a decent price would be tough. The air bags seem to be good for the price and since I do load down my truck sometimes, also a new leaf pack will sag when loaded down with a lot of weight. You just adjust the air pressure in your air bags for the weight your carrying. Here is a pick of what I mean when I say {loaded down}, my truck. Drove like this from Richmond VA to Colorado, got a lot of funny looks along the way. LOL
http://www.tacomaworld.com/gallery/d...m/IMAG0686.jpg
Johns Taco 01-29-2012 05:38 PM
I have followed his build, his rear is sagging too.
Johns Taco 01-29-2012 05:41 PM
I called FatBobs about my problem and they said they have a vendor that can custom make them for me that will add the lift of my choice for $550. I did not actually find the leafs online.
Rob1234 01-29-2012 05:45 PM
I see what you mean. I am not sagging as much since there is no load but I am still about 1 inch lower. So it looks like this product will add lift under load.
I think the fatbobs long aal added 0.75-1 inch lift to the rear without load. If there is a leaf system that would add 2 inches it would probably work for me and I do not need to worry about load since I never have any.
For you it seems like you may have use for the airbags with the bed cap and etc.
Not sure if I am understanding this.
Johns Taco 01-29-2012 06:40 PM
If I have no topper with nothing in the bed my truck it sags 1" lower than the front, with the topper and sand bags in the bed I sag 2". The air bags should level out my truck whether I carry weight or not. It's basically an adjustable suspension.
Rob1234 01-30-2012 05:45 AM
In that case it might work for me as well. Mine sags about an inch without load as well. Let me know how it turns out. This may be our only option.
So you think the airbags will add an inch without load and can be adjusted to decrease the sag when you do have load.
