-   5 Lug (http://www.tacomaworld.com/forum/5-lug/)
-   -   x runner rims on 4cyl. (http://www.tacomaworld.com/forum/5-lug/233097-x-runner-rims-4cyl.html)
808tacomas 08-06-2012 05:13 PM
i have an 11 double cab 4cyl and i am wondering if xrunner rims and tires can fit on my truck without any mods?
TacomaBuzz 08-06-2012 07:15 PM
Yep they will fit perfectly with no mods!
Rich91710 08-06-2012 07:26 PM
As long as you have a 5-lug and not a 4x4 or Prerunner
808tacomas 08-18-2012 06:46 PM
shoots bra u guys da shit
808tacomas 08-18-2012 06:47 PM
and do i have to take out the black boxs?
TacomaBuzz 08-18-2012 10:05 PM
Check out ryanjboutin's build page, he's running XR Rims on his 5-lug. He should be able to answer more questions for you,http://www.tacomaworld.com/forum/2nd...ld-down-2.html
Kelson 08-19-2012 10:26 AM
nah unless you goin run massive tires no need cut the black box...if you keep the stock XR sized tires you'll be fine.
Joels98taco 08-19-2012 06:02 PM
this^ x2
808tacomas 08-24-2012 12:05 AM
I'm gunna go check out these xr rims tomorrow and hopefully it's good because most likely I'm gunna buy them and if I do I'm putting pics on Sunday. So just swap and go?
ivel 08-24-2012 06:19 AM
That's my understanding.
808tacomas 08-24-2012 06:02 PM
Xr
Do you know the size that it will rub? Because the rims I'm looking at the guy put on new tires n he doesn't know the size....lol
808tacomas 08-24-2012 06:07 PM
245/40. Will clear it?
ivel 08-24-2012 08:10 PM
235/75/15's are 11% bigger than 245/40/18's so I would say they will clear.
http://www.tacomaworld.com/forum/tir...245x40xR18.png
808tacomas 08-24-2012 09:56 PM
i did not know that.. thanks bro
Rich91710 08-24-2012 10:32 PM
Really consider going bigger.
With the 245/40-18 on there, your speedo is going to read 65 (actually a bit higher) when you're only doing 62.
My 5-lug is already 3-5mph fast...
245/45-18 would be close to your stock 215's. Personally, I'd go with a 50 series to bring the speedo down a bit closer to reality.
Boring 08-24-2012 10:56 PM
The tires for the 4 cylinder 2wd are 215/70-15, not 215/75-15. I was just at the tire store.
Rich91710 08-24-2012 10:59 PM
Correct... that's what I based my calcs off of in recommending the 245/50-18
Ivel was using the 235/75-15 because we know they fit.
808tacomas 08-25-2012 05:42 PM
im undecided on what tire size i should get without worrieng about rubbing or needind to take out those blaack boxes
ivel 08-26-2012 12:26 PM
http://i.cdn2.tacomaworld.com/forum/...lies/smile.gif
Rich91710 08-26-2012 01:25 PM
Unless you lower your truck, you are not going to rub on any low profile tire up to 245 or 255. The issue is mostly diameter. Guys doing off-road setups are going larger diameter than stock without needing to do more than remove the black boxes (which is not a big deal at all).
Refer to this:
http://www.tacomaworld.com/forum/tirecalc.php
Your stock size tire is 215/70-15, which is about 27" tall.
We can easily fit 235/75-15 without rubbing, which is about 29" tall.
To get to a 29" tall tire on an 18" rim would require 235/60-18, or a 255/55-18.
245/50-18 is less than 1" taller than stock and will fit without a problem.
