16 inch upgrade
Discussion in '5 Lug' started by varmit53, Oct 10, 2012.
  1. Oct 10, 2012 at 7:20 PM
    varmit53
    varmit53 [OP] New Member
    kentucky
    2012 2 wheel drive
    is it possible to install 16 inch 6 lug rims ,on a 5 lug 2 wheel drive tacoma? if it is possible , what will i need to do to correct speed senor inputs, tpms etc.
  2. Oct 10, 2012 at 7:22 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    U can run any rim size just overall tire height takes you spedo out of wack.
  3. Oct 10, 2012 at 7:33 PM
    varmit53
    kentucky
    2012 2 wheel drive
    Hey , thanks!! i appreciate the info.
  4. Oct 11, 2012 at 7:20 AM
    fgcutaco
    fgcutaco Fly rod in one hand, hockey stick in the other
    Nashville
    '09 SWB, Access Cab, 5 Lug
    Stock... For now...
    Correct me if I'm wrong, but if you're going to be running 6 lug rims, you'll need some sort of adapter/conversion type deal.
    Not sure if that's part of the question, but just wanted to throw that out there incase you're about to buy some very expensive 6 lug wheels and find out they won't work after you've bought them
  5. Oct 11, 2012 at 10:29 AM
    goomba
    Josh
    San Antonio Fl
    OOPS missed that. You can not go and just slap on 6 lug rims to a 5 lug truck.
