-   5 Lug (http://www.tacomaworld.com/forum/5-lug/)
-   -   MB wheels (http://www.tacomaworld.com/forum/5-lug/245702-mb-wheels.html)
jz23 10-25-2012 12:40 PM
MB wheels
does anyone have experience with the MB Wheels TKO's
I found a set that i want to buy but I don't want to order them and find out they don't work.
my truck is a 2009 reg cab 4x2 4 cyl. with stock 215/70r15's (5 on 4.5).
the rep said it is an aggressive fit (which scares me) but they should work???
i want to pull the trigger but need to be confident they will work on my truck with no mods.
plan on switching tire to a 235/75r15 or 235/70r15 if 75 is too big.
any info you could provide would be greatly appreciated.
scaplus 10-25-2012 07:13 PM
I have MB Wheels Razors. When I had them installed the wheels were already sticking out by an inch, without the tires being on there, so I guess that's what they probably mean.
The biggest tire without needing a lift is 235/75/15's but you might want to tone it down to 235/70's or even 225/75/15. I don't know the actually size of the TKO's so I can't tell you for sure. If you want you can check the other 5 lug builds and post to get an idea of how big they are.
MIAtaco 01-16-2013 05:00 PM
i have the MB chaos 5 wheels 15x7 and a 235/75/15 tire and before i lifted it they rubbed a tiny bit on full lock but its not too bad
orion44 03-04-2013 11:10 AM
No problems with my MB TKO's - just get the alternative wheel cap. I also didn't go with oversize tires either.
jz23 03-05-2013 09:30 AM
mb wheels
thanks for the replies guys. LOL!
I did go with the TKO's and they fit perfect.
you were right just a little bit of a rub at full lock and in reverse with 235/75/15's but not a big deal at all. That being said my next project will be the black box (cut out). this way no rub and I can run 30's if I want http://i.cdn2.tacomaworld.com/forum/...cons/icon7.gif .
I am very happy with the TKO's minus the the huge (gaudy) plastic center piece of course.
MIAtaco 03-06-2013 05:24 AM
got any pics of them on your truck?
