-   5 Lug (http://www.tacomaworld.com/forum/5-lug/)
-   -   Possible lift and upgraded suspension suggestions (http://www.tacomaworld.com/forum/5-lug/253877-possible-lift-upgraded-suspension-suggestions.html)
Swampmonkey 12-18-2012 09:58 AM
Have a 2003 2.4 cyl. I need new shocks and new front coils and ucas ate rusted out. Any suggestions on good quality aftermarket suspension and is it possible for a slight lift like a prerunner so I don't have to step up out of truck? Daily driver only offroad when hunting.
Mishael 01-30-2013 09:44 AM
From my research, good quality complete packages with little lift as an option, you can't go wrong with Old Man Emu setups. http://www.rocky-road.com/tacoma.html
kind of hard to find an easy to navigate site with the options but this one is pretty good
Joels98taco 01-30-2013 11:43 PM
lift spindles and aal or shackles in the rear. call it a day also for factory replacement parts look at the moog parts
Tacomated 02-01-2013 07:44 PM
I'm planning on setting up a Expo-lite 5-lug.
Don't want any life just concerned about sagging once I put on my shell and start loading the bed with gear.
I'm waiting to hear from the dealer regarding getting an upgrade to a 4 leaf spring set under the TSB but the TSB doesn't actually cover 2013 models (that I can find).
Suggestions for beefing up the rear without a lift (if TSB doesn't come through)?
Tacomated 02-07-2013 04:10 PM
Upgrade Leaf Springs without Lifting
Bump.
Any opinions?
I found these:
Super Springs
Claim to be a simple install without lifting. I'm no engineer or mechanic but the concept sounds feasible. Anyone with any experience using these?
Joels98taco 02-07-2013 07:24 PM
i would look into airbags. anything else is gonna lift the rear including the tsb if there even is one
