-   5 Lug (http://www.tacomaworld.com/forum/5-lug/)
-   -   Wheel and tire size Question (http://www.tacomaworld.com/forum/5-lug/256089-wheel-tire-size-question.html)
SuperchargedFX 01-02-2013 05:34 PM
Hey guys just need something clarified im planning to buy some wheels, the pro comp series 51/52 to be specific. Im pretty sure the 15x8 5x4.5 -19mm offset and 3.75 backspace will fit the 2005 up tacos. The question i was wondering how far they will stick out from the wheel wells? and what the biggest tire size i can fit on there also? 225/70/15? (probably going to take out the black box)
Joels98taco 01-03-2013 10:28 PM
any plans on lifting?
SuperchargedFX 01-03-2013 11:11 PM
Sometime down the road. So not right away. Will this setup only work with a lifted taco?
thanks for the reply
Joels98taco 01-04-2013 02:13 AM
If you plan on lifting later id do a 30x9.5
SuperchargedFX 01-04-2013 03:56 AM
Oh ok and those will fit without rubbing if i take out the black box? Also the wheels will fit without spacers correct, i went to a nearby 4 wheel parts and they said it might rub the brake calipers, but im seeing a bunch of threads with 2005+ tacos with these rims not using spacers just want to clarify.
thanks again
Joels98taco 01-04-2013 10:18 AM
Im pretty sure if you ditch the black boxes you can run a 30x9.5 no problem as for the wheels theres a few 5 lug builds that use those types of steelies with no issues. Id double check that first before you drop the coin
