Will 2012 5-lug 15" steel wheels fit on a 96 5-lug?
Discussion in '5 Lug' started by jvswaim, Jun 11, 2013.
  1. Jun 11, 2013 at 11:40 AM
    jvswaim
    jvswaim [OP] Well-Known Member
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    My 96 AC 5-lug came with 14x6 and would like to go up to 15" steel for better tire choices without going to aftermarket alloys. Don't want to lift, just go to a 225/70x15 from current 225/70x14.
  2. Jun 19, 2013 at 9:56 PM
    Kyleinator
    Kyleinator Well-Known Member
    Kyle
    SoCal
    2013 SR5 5 Lug
    Fog lights 3.73 Third Member
    I believe the diameter of the hub on first gen Taco's is larger than the second gen and will not fit. When I upgrade to xrunner wheels I sold my old ones and I had someone with an 80's toyota truck, gen 1 tacoma both try them and they didn't fit in the front. Not sure if his truck was modified at all though. =/
  3. Jun 21, 2013 at 11:03 AM
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    That makes sense, I'm afraid you're right. I haven't been able to find anyone, before now, who could tell me why 2nd gens won't fit! :)
    Now I need to know if 01-04 5-lug 15x6 steelies will fit on my 96 5-lug. The factory wheel dealers list the 01-04 as only fitting 01-04 and not 96-00. Maybe the hub size changed to the smaller size in 01, while still in the 1st gen era? :confused:
  4. Mar 22, 2014 at 12:47 AM
    Titus
    Titus Member
    bay area
    96 Tacoma 2wd
    hey Joe, i wanted to do the same and wondering if you found a solution.
  5. Mar 22, 2014 at 1:01 AM
    Titus
    Titus Member
    bay area
    96 Tacoma 2wd
    i think i have the larger hubs so it seems i can't fit 2nd gen wheels on my 1st gen 5lug. been researching wheels but can't find correct offset/ backspacing.
  6. Mar 23, 2014 at 5:56 PM
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    No solution with Tacoma wheels I'm afraid. My solution was to go to the General Grabber AT2 27x8.50-14 on my stock 14x6s, instead of 15" aftermarket wheels, because I wanted to stay with hub centric steel wheels.
  7. Mar 24, 2014 at 7:36 PM
    Will922
    Will922 Well-Known Member
    Would wheels with a offset of 18 fit on my 5 lug?
  8. Mar 26, 2014 at 12:57 AM
    Titus
    Titus Member
    bay area
    96 Tacoma 2wd
    jvswaim:
    how do you like your at2 27x8.5r14's? was lookin at some lugcentric 15" steelies for $60 ea but wouldnt mind stayin stock if those tires are durable. heard the sidewalls may be questionable. whada you think?
  9. Mar 26, 2014 at 1:07 AM
    Titus
    Titus Member
    bay area
    96 Tacoma 2wd
    What year is your 5lug? i usually see 3.75 to 4" backspace for 1st gen 5lugs
  10. Mar 26, 2014 at 1:10 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  11. Mar 26, 2014 at 9:57 AM
    Will922
    Mines a '07. I believe they have about a 45mm offset. Not sure about that though.
  12. Mar 26, 2014 at 10:40 AM
    jvswaim
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    They are perfect for a 1st gen 5 lug. They are round, stay balanced, wear like iron, and grip like sports car tires. I also have them in load E LT245/75x16 on my Jeep Rubicon and they are great on snow/ice. And they are relatively cheap compared to other 1st line tires like BFG and GY. In the Jeep world, they have a reputation for strong sidewalls and are used for rock crawling. In fact one of the few criticisms I've heard is that they ride a little rough because of their two extra thick sidewall plies, which are 50% thicker than normal. They are also considered one of the best ATs for mud, although, of course, they don't clear out mud as good as a pure mud tire. I run 35 psi in the 27x8.5-14 and get 22-23 mpg from the 5 lug.
