Rebuilding GoKart, Need help with engine.
Discussion in 'All Terrain Vehicles' started by airsoft_warrior, Nov 7, 2010.
  1. Nov 7, 2010 at 1:36 PM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    I didn't know where to post this at so I figured that ATV's would be ok. Anyway, when I was a kid I had two go karts one that was centripetal clutch and the other is torque converter. Anyways my dad had an old generac 4000XL generator that didnt generate anymore so we we have taken the generator apart down to the engine and the rotor of the generator but the rotor now wont come off. I am trying to figure out how to get it off. If anyone has any ideas or experience with it I could use some help. If you guys want me to post pics of our progress I can do that too. This is a first for us. We are upgrading from a 5 HP engine to a 7.8 HP engine. Hopefully we can get it all working properly. :rolleyes:
  2. Nov 7, 2010 at 1:49 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    YES POST PICS!
  3. Nov 7, 2010 at 1:54 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    LOL I knew that was coming Ok hang on its getting dark
  4. Nov 7, 2010 at 2:06 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Here is the frame, We already took out the 5hp briggs and stratton motor
    Here is the 5HP Briggs & Stratton Motor that is all rusted up and out of commission at the moment.
    Here is one of the two Generac 4000XL generators before we took them down.
    Down to the Rotor and cant get the rotor off to get to the shaft. I need the shaft to put the clutch on it, then we can make a gas tank to put on it and be off.
  5. Nov 7, 2010 at 2:21 PM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Looks like a fun project.
  6. Nov 7, 2010 at 7:02 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    definitely so far, the only snags so far is getting that rotor off and then will fixing a good fuel tank on the motor. we thought about fastening the frame of the generator with that huge gas tank on top of the frame of the go kart and just go with that its possible but probable needs to be welded to work the best.
  7. Nov 7, 2010 at 7:03 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I have to figure out how to make my lawnmower work lol Hasnt run in about 5 years and now I have grass to cut again lol
  8. Nov 7, 2010 at 7:04 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    so by the pictures what are you wanting to take off?
  9. Nov 7, 2010 at 7:10 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    This here. The rotor here is the part of the generator that spins and on the crank shaft and creates electricity when the other parts of the generator are on. There is some how to get it off. I have done an internet search and it has come back negative. Some people have stuck a 5/16 rod down there and struck it with a hammer and said that the rotor just falls off. But there is a fine threaded hole in there (the shaft) that I will need for the Clutch to attach to. That's my problem
  10. Nov 7, 2010 at 7:13 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    after I get the rotor off I have to make sure that the shaft is the right size for the clutch to fit. :rolleyes:
  11. Nov 7, 2010 at 7:14 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Hahaha. Start taking the beast apart. Thats what I do. At least you learn how it works. :D
  12. Nov 7, 2010 at 7:15 PM
    08pretaco
    az
    ya but its about 30 minutes away from me right now so I will wait till tomorrow to tear into it lol
  13. Nov 7, 2010 at 7:25 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Yeah and I guess its not 10:30pm there like it is here. lol :rolleyes:
  14. Nov 7, 2010 at 7:26 PM
    08pretaco
    az
    man once I start working on something its an addiction. I lose track of time and everything goes to shit lol
  15. Nov 7, 2010 at 7:31 PM
    2gtacoma
    2gtacoma Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    get closer pictures of the inside of the housing and of the shaft. seems like the rotor might be rusted in place on the shaft, try soaking it with some wd-40 or pb blaster see if that helps. It hard to say whats holding it on from the pictures u provided.
    Other than that it looks like a honda clone OHV their is plenty of after market parts for those engines. I put one on my manco dingo and it sure as hell has more pull low to mid range than my old 5 hp briggs.
  16. Nov 7, 2010 at 7:32 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    everytime i start on something it cost me something. :crapstorm:
  17. Nov 7, 2010 at 7:36 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Ok. I thought maybe a wheel puller might work but I would need a long wheel puller with a fine threaded 5/16 rod in it to do it. Its so long I will try to get that in the morning for you guys. That silvery gray part was the cover to the rotor we unbolted that already so that now freely spins (it didnt before) I dont know if it is rusted in there or not. i have not seen any signs of rust on the inside of the generator parts yet but there very well could be.
  18. Nov 7, 2010 at 7:39 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i just did the same thing at work, one of our honda generators stopped generating electricity. replaced bushings etc.....and still did not work so i decided to take off the stater etc.. and save the motor for a replacement motor anyways take a rubber mallet or hammer and start whacking away at that housing, (your not going to need it anymore) your not going to break anything trust me. ....once that is removed you will see some allen heads (4 of them) remove them and the housing will come right off. the shaft probably does not have any set screw's or anything attached. it will be smooth so your going to have to modify that once you get apart.
    what your trying to do should take you all of 10min. your right there dude.....
  19. Nov 7, 2010 at 7:41 PM
    2gtacoma
    Daniel
    H-town
    05 -PreRunner sr5
    I have a pully puller to bad you dont live any closer id help ya out.
  20. Nov 7, 2010 at 7:45 PM
    907taco
    Bobby
    Alaska
    dude you don't need a puller for what your trying to do, see my above post...
