Go Back   Tacoma World Forums > Vendors > Armor Tech Offroad
Shackle Flip Kit - The Official Armor Tech Offroad Thread!
Old 07-10-2014, 07:30 AM   #401
If it can't be overdone it's not worth doing
SMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shedSMKYTXN is one of the sharper tools in the shed
SMKYTXN's Avatar
SMKYTXN's Tacoma Gallery
Originally Posted by holyfield19 View Post
Installed with Dakars.
I had seen this picture before but couldn't see the extra holes in the lower hanger.
So how does this design compensate for the toe in of the frame? Are the hanger mounts angled to line up with the front? It's hard to tell from the pictures.
Old 07-31-2014, 07:12 AM   #403
Lone Star Club
whahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shedwhahahajr is one of the sharper tools in the shed
whahahajr's Avatar
whahahajr's Tacoma Gallery
Thought I'd share some info and see if it helps anyone.
One of my older techs saw one of the young guys struggling to cut off some rivets on ball joints. He told him cut an X with cut off wheel and then use the air hammer from the side.
They shot right off.
Old 07-31-2014, 12:12 PM   #404
VA6DCO
IgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shedIgnorantlyAlberta is one of the sharper tools in the shed
IgnorantlyAlberta's Avatar
IgnorantlyAlberta's Tacoma Gallery
Yeah except when you have to try and get either an air hammer or cut off inside the frame. I took my bed off to do the rear suspension and it was still a PITA.
Old 07-31-2014, 03:13 PM   #406
VA6DCO
I'm thinking they might not be all exactly alike lol. I seriously had to cut the spare tire frame support to get them loosened up. Maybe rust.
Old 08-08-2014, 03:47 PM   #407
Banned
XXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shed
XXXX's Tacoma Gallery
I just mocked mine up tonight. They look strait on.
Left pass side lined right up with the front hanger
Right pass side lined right up with the front hanger
Waiting for paint to dry now before I install them, but before I do Ill run two string-lines and measure to see if I need to adjust the angle at all. They eye up great so I think this side is spot on. Worst case I shim 2 bolts out to get it perfect.
I cut the tops of the rivets off with a sawzall, then tapped them out with a drill. It was super easy. 90* drill is a must, but it works really well.
I did the same but with a cut off wheel.
Cut off both sides.
ground bottom rivets flush.
Ran a 1/4" drill bit right up the center of the riven about 1/4" deep so my punch wouldn't jump around.
Inserted punch into hole and held with vise grips.
Pounded the bottoms out with a sledge.
Drilled out holes to fit new bolts.
Once the bottoms were loose I pounded the shackle hanger away from the frame and the top came loose immediately.
Ground those down flush, drilled, punched through, drilled to fit new bolts.
About 30 minutes total for the pass side tonight.
Only tools used besides a C clamp, 11/16" drill bit, and tube of tooling wax for the bits:
The bottom rivets wanted to take the rear spare tire supports with them so I had to c clamp them down before hitting them out.
Rivets could of been hotter and pressed in more on your production run
Old 08-08-2014, 04:10 PM   #408
HiFire is on a distinguished road
HiFire's Tacoma Gallery
Subbed
Old 09-10-2014, 05:33 AM   #409
nimrod712 has a spectacular aura aboutnimrod712 has a spectacular aura aboutnimrod712 has a spectacular aura about
nimrod712's Avatar
nimrod712's Tacoma Gallery
So I seem to recall that someone had gotten a custom Alcan pack made to work with this setup (not like all of the other packs that are built to work with the inverted shackle). Now I can't find that info or who it was. Anybody know how that worked out and/or who it was?
Old 09-14-2014, 03:34 PM   #410
Banned
Stuffed a 12" travel shock in mine... today was the first test drive. Still got some tweaking to do, but I have to wait until the new springs get broken in and I get my rear bumper (weight) back from powder before I work on the angles and final adjustments.
Had to extend my bumps, but Ill take over 29" of droop any day for a little less up travel and zero need for limit straps.
Old 09-14-2014, 05:14 PM   #411
I love your mom!
Slimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shedSlimwood Shady is one of the sharper tools in the shed
Slimwood Shady's Avatar
Army: Sergeant First Class
Slimwood Shady's Tacoma Gallery
Just be sure to keep an eye on your ebrake cable when droop that far. John Andrews was having issues with his rear brakes. We thought this was the culprit.
Old 09-14-2014, 05:34 PM   #412
Skinkwerks Rockware & Fabrication!!
BradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shed
BradyT88's Avatar
Army: Cannon Crew Member
BradyT88's Tacoma Gallery
A pair of wire cutters will fix that
Old 09-14-2014, 07:40 PM   #413
VA6DCO
Haha ^ true story.
Old 09-15-2014, 06:52 AM   #415
Banned
I already disconnected the e-brakes, speed censors, and my already extended brake lines.
Bending and making a custom bracket for the brakes and speed censors.
I'm using 1/4" shock cord doubled up to keep the e-brake cable from dragging over everything. Keeps it out of the way, cheap, simple, and will allow plenty of flex when need be.
Originally Posted by allmotorrex View Post
29" of droop?
29-1/4" is my total from bottom of shock mount shaft to center of lower eye.... not really droop, but extended length.
Old 10-07-2014, 01:23 AM   #416
Thin Blue Line
ProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shed
ProForce's Avatar
ProForce's Tacoma Gallery
Subd
Old 10-27-2014, 11:25 PM   #417
Carolina Alliance Southwest Region Ambassador
jandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shed
jandrews's Avatar
jandrews's Tacoma Gallery
I can vouch for this as true. At full droop with the redone shocks I was able to pop the e-brake cable loose by accident. All fixed now, but was an annoying oversight.
Old 12-16-2014, 04:28 AM   #418
ragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shedragincajun35 is one of the sharper tools in the shed
ragincajun35's Avatar
ragincajun35's Tacoma Gallery
Did my flip kit tonigh. Getting the rivets out was by far the most difficult part. Added a leaf to my Dakar pack (d29xl), ATO shackle flip, all pro Ubolt flip, and extended brake lines. 5 hours total. 3 hours of which were spent on getting the rivets out. Bear in mind I have never done this type of thing before. Wanted to let everyone know about one of my findings. When you are removing the lower bottom rivets many people are having difficulty because the rivets will come out of the frame but be stuck in the spare tire cross member. I had this same problem and was resorting to using a C clam Etc. Then I reolized that there is a tack weld that attaches the top of the rivet to the top side of the cross member . I cut all 4 tack welds with a dremel and then they were much easier to get out. Figured I would pass along that little bit of information. These tack welds are only on the bottom rivets. Everything else was very straight forward and the design is solid. Good luck
Old 12-19-2014, 08:19 AM   #419
Old 12-23-2014, 09:29 AM   #420
ArmorTech [OP] ArmorTech is offline
ArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shedArmorTech is one of the sharper tools in the shed
ArmorTech's Tacoma Gallery
Spencer, great tip on the rivets. We never saw that on our 05 but that doesn't mean we missed it. Also, Thanks for the pics. Your truck is looking great.
Shackle Flip Kit fabjunkie 2nd Gen Tacoma Marketplace 36 11-22-2014 06:06 PM
shackle flip kit.. how/what/why TX RPO Suspension 33 11-25-2011 10:30 AM
Hello from Armor Tech Offroad Fire931 Armor Tech Offroad 28 09-28-2011 02:19 PM
Armor Tech Offroad - Fire931 lsocoee Vendor Reviews 2 09-24-2009 06:44 PM
