-   Armor Tech Offroad (http://www.tacomaworld.com/forum/armor-tech-offroad/)
-   -   Hi-Lift Mounting Bracket kit for 05+ Tacoma Pickup Beds from ATO! (http://www.tacomaworld.com/forum/armor-tech-offroad/252218-hi-lift-mounting-bracket-kit-05-tacoma-pickup-beds-ato.html)
ArmorTech 12-07-2012 08:33 AM
2 Attachment(s)
These mounts are the best and simplest solution to mounting your Hi-Lift in the bed of your Tacoma. They require NO modifications, NO holes drilled, just a simple bolt on installation. The only tools required are a 9/16" wrench or socket. They hold your jack securely to the side of the bed utilizing the factory track system. They can be adjusted towards the front or rear of the bed, whichever suits you better.
Kits come with two brackets and all hardware needed for $72.00. Price includes free shipping to all 50 US states, Puerto Rico and Guam. Save $5 each if you order 2-4 mounts or save $7 each when you order 5 or more! To order click here or contact ATO!
*NEW*: Cross Drilled Bolt Option! Each Hi-Lift mounting bolt is cross drilled for a 1/4" pad lock. Upgrade for just $5 per set.
http://www.tacomaworld.com/forum/att...1&d=1354920369
ArmorTech 12-14-2012 09:22 AM
Our laser shop got a batch of these out for us faster than expected. They are now in stock and ready to ship! Your family could have a great stocking stuffer for you in time for the big day!
ArmorTech 12-21-2012 04:33 PM
We've got these great hilift mounts in stock and ready to ship!
JimBCa 12-23-2012 11:03 AM
Raining outside and it gives me time to wander through the forum on items i need. No doubt about the strength of these, question on the bottom of the bracket.
Is the any issue with it punching or wearing into the bed? Do I need to put something under it?
ArmorTech 12-27-2012 07:26 AM
No we have not had any issues with that. Keep them tight and they shouldn't be vibrating.
JimBCa 12-29-2012 11:14 PM
Thanks, ordering a set
Ordered
ArmorTech 01-02-2013 07:31 AM
Thank you for the order!
JimBCa 01-04-2013 09:56 PM
My set arrived today, packaged very well.
These are probably the most stout item on my truck and are very well made. Glad I spent the extra to get these. Will paint and install this weekend.
Will post pics when done
Thanks again
ArmorTech 02-05-2013 01:06 PM
I've got these in stock and ready for a new home, order yours today!
CrAiG 02-05-2013 01:09 PM
I wish there was a way to lock it so no one walks off with the jack.
ArmorTech 02-05-2013 01:15 PM
We've had customers drill across the end of the bolt and install a small padlock or cable lock.
CrAiG 02-05-2013 01:17 PM
That's not a bad idea at all!!
ArmorTech 05-08-2013 07:31 AM
Cross Drilled bolts are now an option for those of you looking to be able to lock your jacks. The option includes both bolts cross drilled to accept a 1/4" shaft lock. This upgrade is $5 and is available on our website now!
Brackets are back in stock and ready to ship so get yours ordered before you next wheeling trip!
krob32 09-03-2013 12:03 PM
Primed and sprayed with bedliner. Worked perfect and still allows use of the tonneau with no problems.
http://www.tacomaworld.com/gallery/d...um/Hi_Lift.JPG
Pdugan6 09-03-2013 08:40 PM
Sweet
ArmorTech 09-09-2013 05:50 PM
Kelly, looks great, thank you for sharing!
CanisLupus 09-09-2013 05:51 PM
Are we able to order just a cross drilled bolt if we already have the mounts? Wish this would've been an option when I ordered...
ArmorTech 09-09-2013 06:09 PM
Matt,
Sure we can arrange that. Give me a call and I'll get you set up.
CanisLupus 09-22-2013 03:38 PM
Originally Posted by ArmorTech (Post 7407263)
Matt,
Tried calling multiple times over the last week or two with no luck as well as leaving a message. Any way I can get one of the cross-drilled bolts?
ArmorTech 04-16-2014 06:44 AM
We have plenty of these in stock and ready to ship!
