NO DRILLING
Discussion in 'Audio & Video' started by ELMOTM, Feb 10, 2011.
  1. Feb 10, 2011 at 11:46 AM
    ELMOTM
    ELMOTM [OP] Member
    Canada
    07 Tacoma TRD
    I have a stock stereo in my Taco with NO Aux plugs or anything. How do I get my MP3 player hooked up to it without drilling holes OR buying a new broadcaster? Are there plugs in the back for this option? It's too bad Toyota didn't put the MP3 jack into my stereo at the factory. When I bought it new, they said it's a $500.00 option. I said: No thanks!
  2. Feb 10, 2011 at 11:49 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    You will probably need to run an FM modulator.
    They make two versions:
    One that sends an FM signal over the air, the other plugs in between your antennae wire and the radio. The second option tends to have better sound, however is a little more expensive than the first.
    Basically you tune your radio to any radio station, 88.5 FM for example, then FM modulator will play the music through that radio station.
  3. Feb 10, 2011 at 11:55 AM
    ELMOTM
    ELMOTM [OP] Member
    Canada
    07 Tacoma TRD
    Broadcaster = FM modulator. And I would rather hard wire it in. So if anyone has any ideas about how to get the Aux working, please let me know. I have already read quite a few posts and not found anything.
  4. Feb 10, 2011 at 11:59 AM
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    if you want to hard wire it you have to get an aux adapter. There are many on the market. USA Spec is a brand many tacoma owners have used. THere should be many threads about it on here and toyotanation.com. There is probably a DIY sticky about it.
    The aux controller plugs into the aux input in the bakc of the factory stereo, and you access it via the cd button (the cd button will toggle between CD and aux. Its about $60 to $100 depending on the model.
  5. Feb 10, 2011 at 12:04 PM
    ELMOTM
    ELMOTM [OP] Member
    Canada
    07 Tacoma TRD
    Okay Whip and Nova, I now love you. :D
  6. Feb 10, 2011 at 12:04 PM
    novataco
    NOLA
    06 Sport V6 auto
    http://www.toyotanation.com/forum/showthread.php?t=104019
    http://www.toyotanation.com/forum/showthread.php?t=111143
    FYI, the DF-TOY has been discontinued, but they have newer models now, i think with more features...
    And whichever model you choose, this is a good place to stash it, next to the shifter under the shifter panel (which simply pops out). That way you can run your aux cord into the center console box, or drill a small hole on the bottom corner of the cubby hold below the climate controls. I ran two cords, one to each place.
    One into my console vault, and one into the cubby hole (so I can charge and listen at the same time)
    I drilled the hole in the bottom front right corner of the cubby hole so you cannot see the hole unless you stick your head down there.
  7. Feb 10, 2011 at 12:07 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    the grom audio one is great. i have it. it works right about 97% of the time. (it gets tempermental every month or so but will only last until u restart the truck a couple of times) it is a hard wire to the back of the radio. the only thing i dont like about it is the you have to change the song through the radio unless you jailbreak your ipod
  8. Feb 10, 2011 at 12:24 PM
    novataco
    NOLA
    06 Sport V6 auto
  9. Feb 10, 2011 at 12:30 PM
    Gadvan
    Gadvan Well-Known Member
    cincinnati,ohio
    v6 SR5 TRD
    Or downgrade ur iPod cable to the regular headphone jack style. I use to hav e that before for my droidx but now that iPhone I got that cable to play/charge :)
  10. Feb 10, 2011 at 12:31 PM
    Gadvan
    cincinnati,ohio
    v6 SR5 TRD
    I can change song on radio or my ipod
  11. Feb 10, 2011 at 12:37 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    From what I've seen some people say they can't change songs on the radio, I'm wondering if they need to press the disc button 2x.
  12. Feb 10, 2011 at 4:27 PM
    ELMOTM
    ELMOTM [OP] Member
    Canada
    07 Tacoma TRD
    Well, I just bought a new laptop and would like to integrate it right into my truck, since I spend so much of my life in there travelling. Meaning getting it harnessed to my truck stereo or whatevers easier. I doubt I'll drill any holes but you never know. Thanks for all the info here people. Lots of options.
    Just seen the power inverter tap thread. I was already thinking of doing that so I can plug in my laptop.
