HID Fog light HELP!
Old 12-28-2011, 12:15 PM   #1
rmahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant future
rmahoney2013's Tacoma Gallery
HID Fog light HELP!
im trying to install my HID fog light kit and i cannot get them to work. i replaced the bulbs as you can see in the picture these are my new bulbs and ive mounted the ballast but i dont know what im doing wrong.. should i be connecting the OEM wire directly into the ballast? and there are too of the bigger female and male ends that i dont know where to attach.. can someone try to explain or help me?
ballast
i dont know where the 2 big plugins go...(one is at the top other is at the bottom)
Old 12-28-2011, 12:24 PM   #2
bump for help!
Old 12-28-2011, 12:33 PM   #3
XJBaylor will become famous soon enough
XJBaylor's Tacoma Gallery
Maybe you would have better luck in the lighting forum?
Old 12-28-2011, 12:35 PM   #4
06harris is on a distinguished road
06harris's Avatar
06harris's Tacoma Gallery
i have hid fogs the 3000k! an i have them empty! same with my 8000k headlights i just taped the ends an silicond em so nothing got inside an ziptied them out of the way ! i honestly dont know why there there but there not usable lol ( atleast on my rig)
Old 12-28-2011, 12:39 PM   #5
mine wont even turn on though! how did you wire them?
Old 12-28-2011, 12:57 PM   #6
anyone?
Old 12-28-2011, 01:01 PM   #7
That one guy
Aw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shedAw9d is one of the sharper tools in the shed
Aw9d's Avatar
Aw9d's Tacoma Gallery
http://www.tacomaworld.com/forum/lig...stall-diy.html
this is for headlights but will give you what you need..
You should have a set of wires that goes to your stock headlight plugin
and 2 sets of wires that will plug into the ballast.
Old 12-28-2011, 01:01 PM   #8
06harris's Avatar
okay so the kit came with two ballast an two wire "squids" right ? does one squid have an extra long wire an the other smaller in length?
(im trying to get in my truck to see, mines setup in the same spot you have yours waiting to get done work tho so i can get under my hood)
Old 12-28-2011, 01:09 PM   #9
yes i have that
Old 12-28-2011, 01:15 PM   #11
06harris's Avatar
this is my kit the skinny male an female off the bulb pluged into the male an female connects off the ballast , then the one wide end plugs stright into the ballast then the long wired one pluged into the other ballast ( from the passenger side over to the driver side) then battery wire to battery an ground to ground! i have the one male connect just hanging on the driver side cause thats where the long one pluged in!
Old 12-28-2011, 01:42 PM   #12
ok i think i understand but let me see just to make sure... soo you went small bulb connections to ballast and then you used the battery chord and connected the long make end of the batter chord into the passenger ballast and the short batter male end into the dirver side ballast and plugged the OEM connector into the female end connected to the bulb? along with battery connecting
Old 12-28-2011, 02:19 PM   #13
also, where did you mount your battery relay?
Old 12-28-2011, 06:58 PM   #14
06harris's Avatar
yes !! an i literally just double zip tied it to the inside next to the radiator! lol
HID FOG LIGHT ?? AlaskaTacoma Lighting 21 07-22-2013 04:08 PM
Fog light HID thewhiteknight Lighting 8 12-22-2011 07:59 PM
HID fog light out RyanBelliston Lighting 5 10-27-2011 08:52 AM
HID FOG LIGHT ufrusty Lighting 1 06-24-2011 10:36 AM
fog light hid's???? brutalguyracing Lighting 29 03-23-2010 11:56 AM
