2011 Tacoma Access Cab Door Speakers
Old 03-26-2012, 01:39 PM   #1
ArcaneEdge [OP] ArcaneEdge is offline
ArcaneEdge is on a distinguished road
ArcaneEdge's Tacoma Gallery
Ok so I am looking into putting a full audio system in my brand new truck. I got my custom sub box on order (thanks Mr. Marv) but I only have front door speakers. I see where the back access door speakers would go cause there is a panel cut out I am assuming its for that. Since it didn't come with factory speakers, what do I need in order to install speakers in the cab door? Is there a kit out there or something? Appreciate any guidance. I attached a pic for referrence. Thanks.
Old 03-26-2012, 06:45 PM   #2
Really...37 views and no responses...please...
Old 03-26-2012, 07:26 PM   #3
Mr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shedMr Marv is one of the sharper tools in the shed
Mr Marv's Avatar
Mr Marv's Tacoma Gallery
You're welcome and I just replied to your PM regarding this thread!
Old 03-28-2012, 09:15 PM   #4
Tokeisch is on a distinguished road
Navy:
Tokeisch's Tacoma Gallery
I have the same issue, many views not one reply.
I also would like to do the same.
Hello, hello... Is this thing on.....
Old 03-28-2012, 09:17 PM   #5
Banned
Honestly rear speakers aren't useful when looking for sound quality. I would concentrate on the front speakers.
Old 03-29-2012, 09:42 AM   #6
Sheepshead45 is on a distinguished road
Sheepshead45's Tacoma Gallery
Sucks for us 2010+ that the rear "speakers" are nothing more than a couple of wired napkins in the headliner. This is quite possibly the cheapest way possible for Toy to claim a "6 speaker audio system". Just pure crap, wait till you put your hands on the front speakers. Cheap, cheap garbage.
Anyway, looks like you want a complete system but just for reference I recently replaced my front speakers with JBL GTO938 6X9's, and the difference is tremendous. These speakers have a lot of low end power & clarity, something I found was missing in $50-60 range 6X9's. They were something like $85 from Amazon.
After putting these in I have no need at all for rears. It was quick, simple, inexpensive and the results were excellent for me.
Old 03-29-2012, 10:14 AM   #7
Mr Marv's Avatar
The rear speakers are now in the headliner of an Access cab as mentioned however the speaker holes are still in the rear door inner frame as in previous models. Installing rear speakers in the original door location requires an adapter, running wires into the door, cutting a hole in the door panel and attaching a grill cover.
Also, I would agree that front speakers are most important in regards to SQ however rear speakers when implemented properly can be used to actually enhance the front stage. I prefer a nice soundstage up front so I use a left minus right/right minus left delayed signal from about 100hz-7khz on the rears (requires a specific processor or an amp such as a JL 500/5 that does left-right/right-left on the rear channels along with a head unit that has signal delay) however when processing is not available I use some simple tuning tricks without a tweeter in the rear to give a similar effect. On the other hand if you like more of a "club type" sound with music at the same level all around as opposed to the music focused up front then this type of tuning is not necessary so just put a set of speakers in the rear and crank it up if that is how you like to listen in your truck that you paid for!
Old 03-29-2012, 10:32 AM   #8
bubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shedbubbagumps is one of the sharper tools in the shed
bubbagumps's Tacoma Gallery
Youre running those without an AMP on the stock HU? It will probably cause the stock HU to eventually overheat and blow out. These speakers are rated at 300W. The stock unit on the Tacoma is not designed to deliver that much power. If you run the speakers at high volumes for long stretches you are going to fry the HU. The unit will get red hot.
Old 03-29-2012, 11:01 AM   #9
Will The Thrill
Warhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shedWarhorseforever is one of the sharper tools in the shed
Warhorseforever's Avatar
Warhorseforever's Tacoma Gallery
Huh? Running aftermarket speakers won't fry the hu just because they are rated at 300w, which btw is probably a peak power and not rms, doesn't mean you have run them at that power. It'll be fine to run with stock hu.
Old 03-29-2012, 11:13 AM   #10
spithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shed
spithead051's Avatar
spithead051's Tacoma Gallery
Running more powerful speakers on a stock head unit just means that the speakers probably won't get full power as the head unit can only produce so much.
In regards to getting speakers in the back doors of an 09+ Access cab you have a couple of options:
If you want to use the existing door panels, run speaker wires from either the speakers in the headliner or from the head unit to the back doors. Then, either cut a hole and install a grill over the hole or if you are skilled with a dremel, cut slots or some sort of vent for the sound to get through.
The other option is to find a set of interior door panels from an 05-08 AC Tacoma and replace yours with them OR a company called Xtreme Kreations makes an AC door panel for Xrunners that will work with any other AC cab Tacoma and that allows you to mount a sub and speaker into the door.
There are some choices out there but they can be pricy and/or time consuming to do. I chose to upgrade my speakers in the front doors and that made a huge difference. I'm planning on putting a better HU in next and with the factory TRD sub in the back I think I will have more than enough sound for my needs. However, it's your truck so you can do whatever you like
Old 04-03-2012, 11:50 AM   #11
Navy:
Is there a "How to" remove the headliner and replace the speakers?
Also, when you upgraded your stock speakers, (front door) are the tweaters still operational?
Old 04-04-2012, 12:29 PM   #12
As others have mentioned I don't believe this is accurate. The stock unit definately does not have nearly the power these speakers can handle and an amp would give me much more volume. But, I don't listen to anything at high volumes, much less for long stretches, so this suits me just fine.
Old 04-05-2012, 11:13 PM   #13
babyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shedbabyboi2284 is one of the sharper tools in the shed
babyboi2284's Avatar
babyboi2284's Tacoma Gallery
Too bad my panels only fit 05-08 access can models or these might be perfect for you. top fits a 6.5" speaker and bottom fits a 10" sub with .5cu.ft of air space and 6.5" depth.
Old 04-05-2012, 11:24 PM   #14
SNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shedSNJTacoma11 is one of the sharper tools in the shed
Law Enforcement:
SNJTacoma11's Tacoma Gallery
I hate that I have to get rid of my stuff but Mr. Marv is great and right on with his advice. Help me big time with my stuff...
Old 04-05-2012, 11:24 PM   #15
4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed4x4Taco2012 is one of the sharper tools in the shed
4x4Taco2012's Avatar
Navy:
4x4Taco2012's Tacoma Gallery
Those panels are sweet! Wished they made something like that for a '12.
Old 04-05-2012, 11:27 PM   #16
My stock panels are the same as the OP. Once I get some sets of the 05-08 panels I make sold then I will start to make sets for 09+ access cabs.
Old 04-05-2012, 11:29 PM   #17
Will The Thrill
A speakers makes no power what so ever. You can run speakers that are rated 1000w rms on 20 rms all day long and it'll be just fine as long as the signal is not clipping or distorting. Just because a speaker is rated at 200rms doesn't mean you have to give it that power.
Old 05-25-2012, 06:35 AM   #18
barcodeguy is on a distinguished road
barcodeguy's Tacoma Gallery
I have a 2010 with the speakers in the headliner. I was told to just leave them alone and disconnect them. Then mount speakers in the rear access doors and connect those to the rear speaker wires. Do you have any instruction or advice on the best way to do that? Where to cut the holes in the panels, what covers to use, etc.?
Old 04-08-2013, 06:19 AM   #19
urguardian is on a distinguished road
Firefighter:
urguardian's Tacoma Gallery
Hi...where i can buy that panels??
Old 04-08-2013, 05:35 PM   #20
I make them
2011 Access Cab closing door issue GaryS1964 2nd Gen. Tacomas 9 08-21-2013 07:37 PM
Major issue with 2011 Tacoma Access Cab Door Jwake 2nd Gen. Tacomas 97 06-12-2011 04:07 PM
Water inside door 2011 Access Cab Bamfs01 2nd Gen. Tacomas 14 04-05-2011 05:50 PM
2010 access cab Tacoma Speakers in the ceiling? kristonex 2nd Gen. Tacomas 6 08-06-2010 07:00 AM
what size are the rear door speakers in an 07 access cab NWtacoma Audio & Video 3 02-26-2010 11:10 PM
