Installing 2012 Entune Nav into pre-2012 Tacoma
Discussion in 'Audio & Video' started by dibble9012, Sep 28, 2012.
  1. Jul 16, 2013 at 1:09 PM
    #41
    benright
    benright Well-Known Member
    Broghan
    Layton, UT
    11, 4x4, Dbl Cab, TRD Sport
    Velocity 3" spacers, Total Chaos UCA's, 18X9 XD Monsters, 275/65/18 Nitto Ridge Grapplers, Toytec AAL.
    So, just to clarify, this harness will convert R3 and R10 into R15?
    Wish I had found that before I depinned each harness and re-wired it...that was a pain.
  2. Jul 16, 2013 at 2:01 PM
    #42
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    hey there
    i ordered some of these but they are the wrong pins for the toyota connectors to the amp wiring and the other radio connectors - they are 0.64 II connectors
    the right pins are 0.64 III connectors
    http://www.digikey.com/product-detail/en/1674311-1/A104954CT-ND/3454187
    this is very confusing but the type II connectors simply will not seat all the way into the plug- they are about 1/2 inch short
  3. Jul 23, 2013 at 9:47 PM
    #43
    apoteker
    anyone want to share what gps antenna works with this entune jbl unit?
    post pics/links please
  4. Aug 5, 2013 at 5:26 PM
    #44
    dapetik
    dapetik Well-Known Member
    David
    Barboursville, Va
    2015 TRD Sport
    Magic bedcover, sweet ass floormats, rocket boosters, warp drive
    I'm in the same boat, I need to get the gps antenna for my entunes :(
  5. Aug 5, 2013 at 6:12 PM
    #45
    benright
    Broghan
    Layton, UT
    I got mine from here:
    http://www.ebay.com/itm/TOYOTA-CAR-NAVIGATION-UNITS-GPS-ANTENNA-09-/320819856679
    It's a tight fit but it will work. I also purchased an OEM antenna (from a prius) for $90 to compare and the $20 aftermarket antenna picked up more satellites. The $20 one is also a magnet. I just hooked it onto the entune and put it under the dash. I know some people claim to get better reception by placing it above the dash or on the roof but I've had no problems so far.
    Make sure the VSS (vehicle speed sensor) wire is properly connected. If not the GPS will not work properly.
    #45
  6. Aug 5, 2013 at 6:15 PM
    #46
    dapetik
    David
    Barboursville, Va
    2015 TRD Sport
    Thanks for the reply, I'll order that one tonight! :)
    I think I saw a post about connecting that, was that posted by you?
    #46
  7. Aug 5, 2013 at 6:23 PM
    #47
    benright
    Broghan
    Layton, UT
    Yeah I think so.
  8. Aug 6, 2013 at 6:55 AM
    #48
    apoteker
  9. Sep 15, 2013 at 1:59 PM
    #49
    galveznano
    galveznano Active Member
    Leo
    Santa ana
    black prerunner
    procomp 2in lift, secondary air filter delete
    Did you buy this harness from the dealer?
  10. Nov 15, 2013 at 2:36 PM
    #50
    FawkQ
    FawkQ Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    has anyone done this to a 2013 yet?
    I have a 2013 DCSB Sport non-jbl that I want to make jbl /entune / nav
  11. Jan 13, 2014 at 12:03 PM
    #51
    dapetik
    David
    Barboursville, Va
    2015 TRD Sport
    I'm trying to install a USB port on my 2013 HU. I found a wiring diagram for E16 but it doesn't differentiate the #2 &#3 wire. In order for me to splice it into a USB cable, I need to know which is + and which is -. Any help would be appreciated.....
  12. Mar 25, 2014 at 9:16 PM
    #52
    edstacoma
    edstacoma Member
    Ed
    Denver
    2013 Tacoma TRD Sport
    ARB sport bumper, Topper, ARB outback boxes, Custom roof rack. 3" lift
    I have a 2010 Double Cab Sport with a Bluetooth/JBL XM head unit and I bought the 04080 touch screen from a 2012 without JBL. Has anyone adapted this swap or am I just screwed?
    Any and all help is much appreciated.
    To help, I have bought the adapter and microphone harness, but the issue comes down to the AMP harness connector?
    Thank you !
  13. Mar 26, 2014 at 5:19 AM
    #53
    Madpage
    Madpage Active Member
    Frank
    Nashvillle, TN
    12 SR5 4x4
    2" Lift
    From what I've read the biggest issue is going from Non-JBL to JBL. I haven't seen much about reverse stepping from JBL to Non-JBL.
    In my truck I have an 2012 Non-JBL and screwed up and bought a 2013 JBL head unit (with Nav and Entune). I knew it wasn't going to be a plug and play swap over, but after pulling my radio out I decided it was going to be way more work than I wanted to put into it. I put the 2012 head unit back in my truck, and put the 2013 JBL system back in its box. Its been sitting on my garage shelf ever since.
    I just purchased a 2014 Non-JBL head unit and plan to put it in my truck. If you're interested in the 2013 JBL unit send me a PM and we'll work something out. I plan to post the 2013 unit for sale as soon as I get the 2014 unit installed.
  14. Jul 20, 2014 at 1:16 AM
    #54
    Chopper678
    Chopper678 Professional Threadjacker
    Devin
    Texas
    '07 SR5 PreRunner V6 DCSB
    5100s@0.85"+Eibachs, Toytec 2" AAL, Weathertech floor liners, WO seat covers, UltraGauge, ammo box mod
  15. Oct 5, 2014 at 2:47 PM
    #55
    kurkowsm
    kurkowsm COTaco
    Thornton, CO
    14 TRD Sport
  16. Feb 18, 2015 at 8:21 PM
    #56
    emilminasian
    emilminasian Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    is it a direct fit?
  17. Mar 14, 2015 at 9:09 AM
    #57
    Eddietaco2012
    Eddietaco2012 New Member
    Eddie
    boca raton
    Tacoma XSP
    None
    Hi, where did you get the cables to connect from the JBL amp to the JBL radio w/ entune nav. system? I just bought the JBL Radio I need to replace it with a old stock 2012 radio. i jot the same JBL amp and the Entune Nav. radio that you got. Im missing the cables.
    thanks
  18. Mar 22, 2015 at 5:07 PM
    #58
    NiteTaco
    NiteTaco Well-Known Member
    North Alabama
    09 TRD DCSB
    Sub'd for later :D
  19. Dec 23, 2015 at 9:45 AM
    #59
    fj40taz
    fj40taz Well-Known Member
    Carl
    Williamstown, NJ
    10 Toyota Tacoma
    Flowmaster Exhaust
    sub'd.. i just bought a 2012/2013 radio for my 2010 Tacoma
  20. Sep 15, 2016 at 1:44 PM
    #60
    Chopper678
    Devin
    Texas
    I just bought a 2012 radio for my 2007 Tacoma and am waiting on the rest of the interior parts to match. The initial writeup link is broken, does anyone know the part numbers to get it to work? I believe you just need the 28 pin harness?
