2012 wiring for a remote start
Old 10-22-2012, 10:14 AM   #1
NiceTaco [OP] NiceTaco is offline
Canadian Redneck
NiceTaco has a spectacular aura aboutNiceTaco has a spectacular aura about
NiceTaco's Avatar
NiceTaco's Tacoma Gallery
***Posted in wrong section... I have reposted in technical***
I have been waiting to get my remote start installed for weeks.. Reason being the tech wasn't able to get the wiring schematic for a 12 it was not on the site Of the company he normally uses..
He took panels of and checked it against an 11 schematic and it was different. He did get his hands on a 2012 drawing from directed but he thinks it is just a copy and paste of the 2011.
Staub tech is where he normally gets it all and they don't have it up yet.
Does anyone know where I can get my hands on remote start instructions? For a 2012?
Shit I thought I put this in technical.... Oops
Old 10-22-2012, 10:46 AM   #2
Hmmmm
TurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shedTurboGT is one of the sharper tools in the shed
TurboGT's Avatar
TurboGT's Tacoma Gallery
not a bad place to put this... there's lots of remote start questions in here. As for a 2012, I haven't personally worked on one, but but I highly doubt that toyota would have change up the wiring colors... the locations might be slightly different, but not to the extent that you should have troubles finding the right wires.
Example: Your parking light wire will likely still be available in the harness coming out of the steering column - whether or not it's a + or - pulse is still up for grabs, but either way, you can still grab it here. Likewise, you can almost always find the parking light wire in the driver's kick panel, in a large bundle of wires heading down the sill plate. Toyota's typically used a slightly larger gauge green wire (+ pulse)
Additionally, door locks will be coming from the driver's door bundle, also in the kick panel, but tucked back farther... pop off the door window/lock panel and poke around.
Tying into the ignition harness is not likely to have changed.... at all. The wires are the largest around, come from the steering column, and are extremely hard to miss if you've taken off the lower dash panel and the lower column cover.
The tach hookup is likely gonna be the hardest to find, assuming that it did, but even still, just simply going to a coil will net you workable results.
The hardest part of the installation is likely going to be the key interface, again, at the column, but this is pretty easy to find - If it hasn't changed, it will be a 3 wire bundle (pretty small gauge) coming immediately off the key cylinder.
Take the 2011 wiring guide you have and ignore the part that tells you where the wires are located, only paying attention to the color, and start looking in logical places (I know, cars are rarely logically assembled), such as the one's I've listed.
Best of luck
Old 10-22-2012, 05:40 PM   #3
Canadian Redneck
NiceTaco's Avatar
Thanks man... We shall see what happens Thursday
Old 12-30-2012, 11:03 PM   #4
Amys2012namedTOYA is on a distinguished road
Amys2012namedTOYA's Tacoma Gallery
That tech is a liar
If you havent gotten installed yet I would take it to a different company all together. I just did my own install on mine !!!. It is exactly the same wiring diagram from 2009-2012. Mine is a 2012 if that tells you anything.
Oh and by the way, Tell that tech The 12volt.com !!!
Thanks,
Brad
Old 12-31-2012, 05:19 AM   #5
Canadian Redneck
NiceTaco's Avatar
It's installed I did have to go to another tech cause the above guy kept screwing me around with its not the right schematic... Brought to another guy he had it done in no time...
Old 12-31-2012, 09:16 AM   #6
Nice to hear, glad its working for you.
Remote Start for 2012 Tacos TitansWycheck89 2nd Gen. Tacomas 28 12-30-2012 10:53 PM
Remote Start Wiring Pictorial hookedontronics Technical Chat 6 12-06-2012 11:50 AM
Wiring for Viper 5501 remote start? ubugarrity 2nd Gen. Tacomas 1 12-23-2009 11:39 AM
Remote Start Wiring Help x1motoxxx1x 1st Gen. Tacomas 0 11-10-2009 03:24 PM
I need help wiring a remote start ho_ho14 2nd Gen. Tacomas 1 05-12-2008 12:14 AM
