CB problems... any ideas
Old 10-29-2012, 04:52 AM   #1
uscg2008 [OP] uscg2008 is offline
uscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the shed
uscg2008's Avatar
Coast Guard: AMT3 kodiak 60T jayhawks
Location: KODIAK, AK! originally from Huntington Beach, CA
uscg2008's Tacoma Gallery
hey guys i just installed a uniden 510 and a external speaker. im getting interference across all channels. i have to have my squelch between 50% and 60% with the truck on but around 10% with the truck off. im still getting it even with my antenna unplugged. could i be getting it from the fuel pump? the coax is running down the same side as the fuel tank.
anyone have any ideas thanks for the help guys
edit: so i know that im getting a bit of interference from my alternator. and im gettting a lot of interference when i turn on my HID headlights or fogs. is there anything i can do to help against it?
Old 10-29-2012, 05:05 AM   #2
NetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shedNetMonkey is one of the sharper tools in the shed
NetMonkey's Avatar
NetMonkey's Tacoma Gallery
sounds like you dont have a proper ground or power for the radio.
i have mine wired directly to the battery and i have hardly any electrical interference.
where is yours wired to?
Old 10-29-2012, 04:29 PM   #4
Another Traitor
brian's Avatar
brian's Tacoma Gallery
Originally Posted by uscg2008 View Post
hey guys i just installed a uniden 510 and a external speaker. im getting interference across all channels. i have to have my squelch between 50% and 60% with the truck on but around 10% with the truck off. the interference stays the same as accelerate so its not alternator interf. im still getting it even with my antenna unplugged. could i be getting it from the fuel pump? the coax is running down the same side as the fuel tank.
Buy a case of beer and talk to your tweet shop. Preferably someone that knows what the Bird wattmeter is
Old 10-29-2012, 06:17 PM   #5
uscg2008's Avatar
i have the power wire straight to the battery and a ground wire to an existing ground in the center console. but i didnt have any spice connectors so when i extended the power wire i spliced it straight to the next segment of wire then heat shrunk that connection. do you think that could be it?
Originally Posted by LUSETACO View Post
How did you wire the CB?
power wire straight to the battery through the fire wall, then the ground its to an existing ground in the center console
ive talked to a tweet and he doesnt know why im getting it hahaha
Old 10-29-2012, 06:45 PM   #7
NetMonkey's Avatar
wire both the power and ground straight to the battery.
Old 10-29-2012, 09:36 PM   #8
uscg2008's Avatar
ya i think that is the next thing that im going to try
Old 10-29-2012, 09:42 PM   #9
uscg2008's Avatar
here is a pic of how it is wired
red wire: power
black w/ blue connector : ground
Old 10-29-2012, 11:09 PM   #10
Another Traitor
brian's Avatar
You must have worthless tweets up there.. oh yeah Morales ... slap that kid up side the head for me.
Old 11-02-2012, 01:08 PM   #11
stewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shedstewartx is one of the sharper tools in the shed
stewartx's Avatar
stewartx's Tacoma Gallery
red wire: power
That looks fine, but I'd probably use the bolt on the side of that bracket instead of one already used by whatever.
Anyway, if your electrical connections are okay, check the antenna ground and ground plane. One quick way to do so is to disconnect the coax at the back of the radio to see if the noise reduces substantially. If so, make sure the antenna is mounted well to metal (the beds on many Tacoma trucks are fiberglass) and the metal surface area is large enough to provide a sufficient ground plane. If either of these are lacking, the antenna will pick up noise from the truck and nearly everywhere else.
Old 11-03-2012, 08:36 AM   #12
uscg2008's Avatar
so i need my antenna to be touching metal? because i have it on a bracket off the side of my bed between the tail gate and bed but i have a rubber gasket between the bracket and the metal. when i disconnect the cable in the back at the antenna the noise sounds the same.
Old 11-03-2012, 11:33 AM   #13
Truck ~n~ Tow
TacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shedTacoDell is one of the sharper tools in the shed
TacoDell's Avatar
Navy: BU3....   Builder with NMCB3 1981-1986...  SeaBee's if that's easier...
TacoDell's Tacoma Gallery
yes your antenna need be grounded...
but your noise could be due to fuel pump noise interference.
I wouldn't run the coax down the same frame rail as the fuel pump wiring.
what antenna are you using ?
coaxial does not loop/coil on itself right ?
how long is the coaxial ?
increments of 3 ft... the shorter the better.
did you already tune with a swr meter ?
Old 11-03-2012, 05:57 PM   #14
uscg2008's Avatar
hmmm ill try and make sure that my antenna is grounded first.
i have a 10ft long coax cable right now running down the left side of the truck i think im gana try and change it to run down the right side.
and no i havent tried a swr tuner yet
Old 11-03-2012, 06:34 PM   #15
stewartx's Avatar
Okay, if the noise remains the same with the antenna disconnected, it's not the antenna, Coby. However, the antenna must still be grounded to metal to work properly. You should also check the SWR (which will be high with no metal ground).
Anyway, getting back to the noise issue, I don't have much more to offer. Noise normally gets into the radio in three ways - the power wires, the antenna, and the air (a strong noise source located near the radio itself). We've ruled out the antenna as the source of the noise, so that leaves the other two. The latter is fairly rare (but not unheard of), which is why everyone is focusing so hard on the power wires.
My only remaining suggestion would be to reroute those wires. One or the other (positive or negative) could be picking up noise from a wire running beside it or from a nearby electrical device (fan motor, etc). Choose another route to get those wires to where they need to be. Good luck.
Old 11-04-2012, 09:42 AM   #16
uscg2008's Avatar
thanks for all the help man
Old 11-09-2012, 07:25 PM   #17
uscg2008's Avatar
updated op
Old 11-09-2012, 07:36 PM   #18
Another Traitor
brian's Avatar
Check all your grounds, including your stereo, if you have one, make sure they're all solid and metal to metal contact. In most cases interference is from poor shielding and bad grounds. In your case I don't think theres much you can do to shield the wires, so check all the grounds on your high current systems.
Old 11-09-2012, 07:53 PM   #19
uscg2008's Avatar
hmmm will do that later tonight at work
Old 11-10-2012, 05:18 AM   #20
uscg2008's Avatar
so after trouble shooting toinight i found this out. when i turn my HID headlights or HID fogs on im getting a lot of interference. like i have to have my squelch up around 70 to 90% , but i have practically now interference when my lights are off. i only have to use like 3-5% squelch then.
CB Setups looking for ideas silverbullet05 Audio & Video 63 03-22-2011 02:28 PM
cb problems tacomazach Technical Chat 16 03-08-2011 07:23 AM
CB aradio and attenta ideas? mounting? mwinslow 2nd Gen. Tacomas 72 01-16-2011 09:24 PM
CB Radio Problems. SRQ TACO General Automotive 19 11-12-2010 07:31 PM
CB problems. wolfgang123 1st Gen. Tacomas 51 02-15-2010 09:06 PM
