2001 Tacoma Viper 5704 install help
Old 11-08-2012, 10:42 PM   #1
LowLyfe [OP] LowLyfe is offline
LowLyfe is on a distinguished road
LowLyfe's Tacoma Gallery
Hey everyone, ive been lurking the site for awhile...but havent posted much here. But i need some information on the install of the viper 5704 alarm...
Heres the wires i have
H1/1 - 12vDC constant ----------White/red wire at Ignition
H1/2 - Chassis Ground -----------Grounded
H1/3 - Siren Output -------------- Red wire from siren speaker(and also pezo postive wire spliced in)
H1/4 - Parking light Isolation -----Dont Need?
H1/5 - Parking Light Output - Green (+) back of fuse box
H1/6 - Ground when armed - Dont Need? If i had a tilt sensor i would hook here
H2/2 - Neutral Saftey ------Grounded
H2/6 - Door Trigger - I have a diagram that i must wire in 4 diodes to all 4 door pin trigger wires.
H2/8 - Horn Honk ----------- Green/Red Steering Column
H2/16 - Brake Shutdown ---- Green/White Brake Pedal
H2/17 - Hood Pin Input ------- To hoodpin (if i use)
H2/19 - Instant Trigger Input ------- Blue wire from backup battery (520t)
H2/23 - Tachometer Input----- Light Green/Black (at igniter on pass fender)
H3/1 - Ignition Input/output ----- Black/Red Ignition Switch
H3/2 - Fused Ign. 2 ---------------Black/Yellow IS
H3/3 - Accessory Out -------------Blue/Red IS
H3/4 - Starter Out ----------------Black (car side)
H3/5 - Starter In ------------------Black (key side)
H3/6 - Fused Ignition 1 Input ----- ????
So, if i didnt list it im pretty sure i dont need it? Also, does any of these require relays?
And i Had a question about the Gray wire +12v output from the backup battery..does this actually goto H1/1 and then the Red wire on my backup battery goes to the White/Red wire at ignition?
The door lock harness im good with, and the 2 sensors (glass break, shock) are just plug in play.
Thanks for anyones help in advance, i greatly appreciate it.
Dee
Old 11-25-2012, 01:31 AM   #2
Riverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shedRiverdog is one of the sharper tools in the shed
Riverdog's Avatar
Riverdog's Tacoma Gallery
Hey Dee,
I don't know if you've figured everything out yet or not, but I would post this exact thing on www.the12volt.com if you haven't solved anything yet. You'll want to post here. Its their car alarm/remote start forum.
I have a 2005 Tacoma and just posted some questions on the12volt about installing a 5704 and got clear answers right away. Good luck and let me know how it goes!
Old 12-01-2012, 05:53 PM   #3
Yea i posted there after. Heres the correct Information in case anyone else needs help. This is for the viper 5704 Remote start harness only. If you need help with the actual alarm harness all the info is at 12volt.com
H3/1 (+) igntion 1 input/output ====== black/red
H3/2 (+) fused 30a Ignition 2/ ====== White
H3/3 (+) accessory output ====== blue/red
H3/4 (+) starter output car side ====== black wire car side
H3/5 (+) starter input key side ====== black wire key side
H3/6 (+) fused 30a Igntion 1 input ====== White/Red
H3/7 (+) igntion 2 / flex relay output ====== Black/Yellow
H3/8 (+) flex relay input 87a key side ====== Not Used
H3/9 (+) fused 30a accessory/starter input ====== White
H3/10 no connection ====== no connection
Viper 5704 (5901 Replacement) nut Product Reviews 11 10-14-2012 04:39 PM
12 Taco and Viper 5704 Redtaco12 2nd Gen. Tacomas 1 09-16-2012 07:09 AM
Viper 5901 Install on 2011 Tacoma snipe700 Technical Chat 4 05-31-2011 11:50 PM
Viper 5701 alarm install - '09 Tacoma Taco13 Audio & Video 2 07-26-2010 10:45 AM
Viper 690xv install rab89 Technical Chat 14 02-23-2010 05:18 PM
