Using Stock Speakers for New Speaker Adapter
Discussion in 'Audio & Video' started by samiam22691, Nov 26, 2012.
  1. Nov 26, 2012 at 7:39 AM
    samiam22691
    samiam22691 [OP] Member
    Sam
    New Orleans
    2012 Access Cab 2.7L 5 sp. Manual
    I looked around for awhile to see if anyone had used the front door stock speakers (2012 Access Cab) and modified them to accommodate new speakers (in this case 5-way Pioneer 6x9s).
    I hadn't seen anyone attempt it and post something comprehensive explaining how it went. So I decided to give this a go and see how it went. I'm about halfway through right now (it has become more work than I originally intended) but it's working rather well. I'm going to explain how I went about this and you can see if this is a worthwhile task or if you should just go shopping at *********...
    First I took off the driver side door panel. NOTE: if you plan on doing this but won't finish in one day (or plan on driving the truck while the panels are off it is worth the 2 minutes it takes to remove the window/lock buttons and reattach them (you'll need both attached for full functionality).
    As you can see, I took out the stock speaker, it's very flimsy but the casing they've built it into is rather remarkable.. They've built it into its adapter and integrated a plug and play type clip.
    If you cut these two wires, you can remove the clip very easily. I saved this clip to solder onto the new speakers (to retain the plug/play ability)
    Then it was time to rework the plastic adapter to accommodate a new speaker, first I ripped out the little paper cone, then using a Dremel and some cutting/sanding attachments I removed the spokes that hold the magnet and sanded it down to a flat surface around the top.
    With Cones ripped out
    After cutting out the magnet
    Grind down the top edge, you will have to keep checking to make sure your speaker will fit flush against that top edge. The smoother the edge, the better contact with the speaker.
    I was a bit unsure how to connect the speaker to the mount because there isn't a lot to drill into - I decided to try some J.B. Weld to secure the speaker in place. I wasn't sure this was going to work but after it cured I was very happy with the result. Seems very sturdy.
    Solder some speaker wire to the speaker leads then the other end to the adapter- make sure you line up which side is positive and negative. Make sure you protect the cone of the speaker when you're soldering in case something drips. Some paper under the housing should work just fine. Also- if it's important to you, thread the speaker wire through the hold in the mount so you can secure the clip back to the housing- I decided to let mine hang free. I also wasn't sure which color wire in the door represented positive and which was negative so before I soldered the clip I played around to see which sounded right with the radio on. Found out now Pink is positive, violet is negative on the left, on the right it's green is positive, blue is negative.
    When I was done I went back and secured the speaker to the door. When I tried to cover it with the door panel, however, I found out that my speaker was just too deep (even without the speaker cover). As I had already covered a $70 speaker with J.B. weld I thought it was a good time to try my hand at modifying some interior panels. I used my Dremel to open up a hole large enough to allow the door to fit back together nicely but before I closed everything up I secured the Pioneer speaker cover with some small zip ties (they won't be seen anyway). I also used some weather stripping to ensure good contact between the mount and the door.
    Everything went back together alright in the end. It's not the most beautiful mod in the world but it's functional (If anyone wants to comment on how to make this look nicer please do)
    Finished driver side door
  2. Nov 26, 2012 at 7:50 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    2010 Tacoma Regular Cab Slider
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    While I didn't do it myself, I had my local guy modify my 2010 to accept 6x9's. He just cut a little of the sheetmetal and used the speaker adaptors I supplied. Looked great and sound better.
  3. Jul 6, 2013 at 11:52 AM
    Tj0hn
    Tj0hn Well-Known Member
    Arkansas
    Stock TRD Sport 4x4
    A for effort but someone needs to take your Dremel away.... Why not do it the right way instead of hacking up a 2012 vehicle?
  4. Jul 6, 2013 at 6:46 PM
    Bunk454
    Bunk454 Well-Known Member
    Huntsville, AL
    '13 MGM DCSB TRD Off-Road
    Really? All that work just to murder a perfectly good door panel in the end?
  5. Jul 8, 2013 at 3:23 AM
    ducati
    ducati thie-trickster
    Carlsbad, CA
    2013 DC 4x4 Black
    Icon coils, Squeaky dakars, Thule rack, tinted windows, weathertech rain guards, Demello off road front bumper, warn winch, shok sound deadening.
    Nice pics and info but are you serious? The door panel wouldn't fit without chopping it up like that.
  6. Jul 8, 2013 at 7:59 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    UMMMMM.......:eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
    :smack:
    Maybe...:rasta:
    :anonymous:
  7. Jul 9, 2013 at 2:45 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    Ouch on the door panels.. I would have trimmed the Speaker grille before the door panel grille..
  8. Jul 9, 2013 at 5:56 PM
    Desert Snow
    Desert Snow Well-Known Member
    Greg
    Chandler, AZ
    2012 4x4 DCSB Pyrite Mica
    Bilstein 5100s, 1" blocks rear, ATX Slot Chrome 17x8, Toyo Open Country 285/70/17s, Polished N-Fab steps, Pioneer AVH-P4400BH, Alpine PDX-V9, Boston Acoustics Pro60SE front, Boston Acoustics SR65 rear, ID 10D4v.3 sub, SuperCrew sub box, RaamAudio sound deadener, Escort 9500ix with BlendMount, shorty antenna, tint
    A for honesty. Seriously, if I did that to my own door panels on purpose I'd lie about it, certainly not post the evidence here.
    What's next, the AC mod?
  9. Jul 9, 2013 at 6:01 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    since youve already cut it, its too late to say, but atleast you shouldve cut the whole square out for a cleaner look then just leaving the dippled look behind.
  10. Jul 9, 2013 at 6:09 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    SoCal - Fontana
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    The grills aren't meant to be installed like that. And the door isn't meant to be cut either. Great job with the speaker into the stock housing/spacer (a lot of people do it that way) but the last 2 steps ruined your door. I would not do that to the passenger side. And is buy a new door panel too. But like others have said, I guess A for effort :notsure:
  11. Jul 9, 2013 at 6:58 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Only way to make that look better is to buy a new door panel. Sorry to say.
  12. Jul 9, 2013 at 7:05 PM
    ProForce
    Anthony
    SoCal - Fontana
    :laughing:
  13. Jul 9, 2013 at 7:12 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    wait so you just left it zip tied in there???
    It looks good, but it would look better if you had never done any of that.
    (constructive criticism)
  14. Jul 9, 2013 at 7:19 PM
    ProForce
    Anthony
    SoCal - Fontana
    Fixed :)
  15. Jul 9, 2013 at 7:32 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    I feel kinda bad so I won't poke fun. Would hate to see a new member scared away.
    My suggestion is to take the dremel and clean up the edges a bit to make them straight. Then get yourself some of that flexible rubber/plastic trim and press it on around the edges. That way it will give you a cleaner look.
  16. Jul 9, 2013 at 7:34 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    lol
    I give you an A+ for effort, but an F for execution. it was quite a feat to take on a job that was made way more complicated by your desire to use stock components, but now there's a hole in your door.
    silly 2nd gens, at least when we cut big ass holes in our trucks, we make sure you can go back :D
  17. Jul 9, 2013 at 7:40 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Get some PROPER sized speakers, get a new door panel and put that shit back together right...you want better sound in front, get some high quality PROPER fitting speakers, and hook an amp up to them..
  18. Jul 9, 2013 at 7:40 PM
    Ice Horse
    Lauren
    Colorado
    Wait a minute...this thread is 7 months old!
    :smack:
    OP hasn't been active since March.
  19. Jul 9, 2013 at 7:46 PM
    ProForce
    Anthony
    SoCal - Fontana
    :facepalm:
  20. Jul 9, 2013 at 8:35 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    FUCKDAMNIT!!! blame the friggin thread revival genus...
    and ill go punish myself and take a shot of cheap vodka.
