Ported Subwoofer Box Tuning. Need some help.
Old 04-12-2013, 08:36 AM   #1
KJaikaran [OP] KJaikaran is offline
KJaikaran will become famous soon enough
KJaikaran's Tacoma Gallery
Currently running an 8" kicker L7 in a ported box that i built. I have built other boxes in the past that I would tune at about 30hz-35hz, usually running 10"-12" subwoofers in cars with trunks. This is my first time doing a box in a truck and using an 8" sub woofer.
So, currently i am running the 8" L7 at 40hz (actually right in between 40hz-41hz) with 30hz subsonic filtering and it sounds good, but it is lacking the loudness of the lower frequencies. I like the way it sounds, but there is some songs that if you don't hear those low notes it kind of kills the song. So, i can actually close up the port a little to lower the frequencies with two different option, either 36hz or 33z. What i am really looking for is a little bit of every thing. I don't just want low pounding bass that people can hear me coming from down the street that doesn't handle the bass line very well, and i don't want only high bass notes and everything else under that sounds like crap.
Options:
1: Leave at 40HZ (Dont mind, not all songs hit low anyways.)
2: 36HZ (Not sure if i would actually notice the difference from 40HZ)
3: 33Hz (Not sure)
4: Rebuild the box with different tuning
So any opinions on the tuning would be appreciated.
Rough fitment:
Old 04-12-2013, 08:53 PM   #2
Sounds Gooooood
ItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shedItalynStylion is one of the sharper tools in the shed
ItalynStylion's Avatar
ItalynStylion's Tacoma Gallery
My suggestion would be to go with the lower tuning option. That will yield the largest gain down in that region. It shouldn't take away much from the slightly higher notes. Remember, the tuning affects where the FR curve gets the most help. It's not just a single peak. You'll just be shifting it down a little and adding low end.
If you use Polyfill in the box it will also lower the tuning slightly.
Old 04-13-2013, 10:53 PM   #3
Thanks, probably will be adjusting the port for lower tuning. I was thinking about using some polyfill, but i am kind of worried about it throwing off the tuning. Never actually used polyfill in a ported box so i could be wrong about it throwing off the tuning by much.
Old 04-13-2013, 11:25 PM   #4
Sounds Gooooood
Trust me, use a little bit in there. It should pull the tuning down a little and it should also help with box resonance.
Old 04-13-2013, 11:32 PM   #5
davidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the sheddavidjmay is one of the sharper tools in the shed
davidjmay's Avatar
davidjmay's Tacoma Gallery
I would agree that tuning it to the lower frequency ia probably going to be better. I'm also curious as to using polyfill in a ported box, as I've heard that it will screw up the tuning and free air resonance... OP, if you do polyfill the ported box I'd appreciate your opinion on it!
Old 04-14-2013, 06:52 AM   #6
Sounds Gooooood
It will absolutely change the tuning in the box; it will make it lower by maybe 1-2hz (which is ideal in this case).
Long story short, the fibers in the polyfill catch the air movement and essentially slow down the speed of sound. This changes the effective size of the enclosure to something that ACTS larger than it is. It would be like he kept the same port and made the enclosure volume larger causing the tuning to go down. That's how it works.
Old 04-14-2013, 11:00 PM   #7
I closed up the port and it should be tuned at 32-33hz now. Debating on the poly fill a little more now because i am getting some port "chuffing" or what ever they call it noise now. I can only hear it if i have it turned up and i literally have my head down by the port. I was kind of worried about that happened when closing up the port a little so i was kind of expecting it, but as i said its only heard if your looking for it with your ear down by the port. I had the same problem when i built my first ever ported box and my port wasn't wide enough. Now i am thinking about adding the poly fill to slow down the air movement a little.
If i decide to do it ill let you know how it goes.
Old 04-14-2013, 11:29 PM   #8
davidjmay's Avatar
You're your biggest critic. Haha I feel like everybody else's systems are perfect, but when I listen to mine there's always little things that I know no one picks up on, but I do just because its mine
Old 04-15-2013, 01:36 AM   #9
lol, tell me about it, anything vehicle or house related i'm never satisfied until I know its perfect. Sometimes I tell my self its fine and i should leave it alone, but deep down it bugging the hell out of me until i am back at it. Drives the gf crazy.
Old 04-15-2013, 08:23 AM   #10
Sounds Gooooood
What do you think of the new frequency response? Better than before?
Old 04-16-2013, 10:40 AM   #11
Sounds a lot better. I ended up building another box yesterday with the proper tune, and port dimensions so i don't get the port noise since i now knew what numbers i was looking for. The first box worked out good for testing even though i didn't want to resort to building another one. Thanks for the help.
Old 04-16-2013, 03:22 PM   #12
Hot Steppa
pinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shedpinktaco808 is one of the sharper tools in the shed
pinktaco808's Avatar
pinktaco808's Tacoma Gallery
same here. i always feel like other people systems are louder than mines.
12w1v2 in a ported box in a DC ??? NOCENTS Audio & Video 4 04-30-2013 03:46 PM
Alpine Touch Screen, Dash Kit, and Custom Ported Subwoofer Box Tyler_G13 Buy / Sell / Trade 24 07-18-2012 03:52 PM
New Ported sub box for access cab! 08bluetacoma Audio & Video 11 03-24-2011 02:40 PM
Need help with ported box and sub tacomaniacmatt Audio & Video 4 11-01-2010 08:33 AM
Compared ported subwoofer vs. my sealed subwoofer box netman1969 Audio & Video 11 03-09-2010 04:34 PM
