How To Install A Pioneer X5500 in 2nd Gen Tacoma with ASWC1 Module and Parking Bypass
Old 03-05-2014, 06:41 PM   #41
tagging shit all over the net since 2001
trktwo is on a distinguished road
trktwo's Avatar
Army: Medic/xray tech
trktwo's Tacoma Gallery
Originally Posted by doughboy View Post
There should be a 3.5mm jack on the pioneer labeled wired remote input
thank you! (and thank you to OP!!!!) i installed pioneer avhx-4500bt, aswc-1, and ebay parking brake bypass today, took about 30 minutes. thats because i did all my connections and soldering this past week.
next is to install pioneer CD-IV202AV cable, and see if i can watch some video from my iphone 5. i'm wondering about using a usb splitter to run that cable and a regular iphone cable. that way i can have the option of sing the normal cable to charge my phone, or using the pioneer cable for the few times i watch videos or apps from the iphone. would like to run the pioneer cable into the consol, because it is an embarrassing "solution" to the problem.
also, i was kinda disappointed with the metra dash kit that came from crutchfield. it doesn't seem to fit right.
Old 03-08-2014, 05:41 PM   #42
Flaco
bluedegeon is just really nicebluedegeon is just really nicebluedegeon is just really nicebluedegeon is just really nice
bluedegeon's Avatar
Army:
bluedegeon's Tacoma Gallery
I have a x5500 and trying to install the Taotronics back up camera (http://www.amazon.com/TaoTronics%C2%...aotronics+cc17). I can't get it to work when in reverse for some reason. Where do these wires plug into? The red and black one.
How To Install A Pioneer X5500 in 2nd Gen Tacoma with ASWC1 Module and Parking Bypass-imag0274-1-.jpg
Old 03-09-2014, 06:47 PM   #43
MrK MrK is offline
MrK is on a distinguished road
MrK's Tacoma Gallery
I just installed a backup camera with the 5600 in my 2003 Sequoia, and like the results. Maybe the 5500 is similar. I ran the red wire to ACC (so the camera is energized the whole time the car is turned on), and the black wire to ground. But on the 5600, there is a separate, third wire (violet/white) used to detect when the car is in reverse. So I ran a separate wire from violet/white, tapping into one of the backup light wires that is energized (12 volts) when the car is put in reverse. So now when I put the car in reverse, the 5600 senses this and changes the 5600 display to the backup camera. When I take the car out of reverse, the 5600 reverts to whatever function I was using, i.e. HD Radio, etc. The advantage of having the camera energized continuously is that you can switch to the rear display any time you want, not only when in reverse. However, someone in another forum mentioned that a possible downside is that the camera could burn out prematurely. I don’t know if this is true.
If the 5500 doesn’t have the third wire (violet/white or whatever) feature, then I think you would connect the red wire to one of the backup light wires that is energized (12 volts) only when you put the car in reverse. Black wire to ground as usual. In this installation, the camera is only on while the car is in reverse. Good luck.
Old 03-29-2014, 08:01 PM   #44
NorCalTRD [OP] NorCalTRD is offline
NorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to beholdNorCalTRD is a splendid one to behold
NorCalTRD's Tacoma Gallery
Wow, everybody has been busy!
Looks like some SWEET setups
Bluedegeon, I ran the redblack wires to my left tail light and used the reverse lights 12V wire.
So now whenever the reverse light gets power so does the camera.
Also, be sure to setup the radio!
In mine it didnt display until I set the Camera Polarity setting to Battery rather than Ground or None.
I upgraded from my generic Android to an iPhone5S and now I cannot use the Pandora interface on my Radio.
It will fail to connect.
Pioneer wants me to buy some $200 worth of cables to connect the iPhone, what a bunch of bullshit. The whole idea is to have NO CABLES.
However, it works just fine using Pandora App on my iPhone.
I synced my iPhone to the X5500, then start playing Pandora, then select Bluetooth Audio rather than Pandora.
I think it actually works BETTER this way than in its own Pandora mode.
It stops and starts music on my Pandora when I get in/out of the truck, pretty cool although I think the damn Pandora mode should work since its advertised too!
I would like to have in dash navigation so now considering replacing the 5500 with an AppRadio or something that can show the Google Maps.
Old 05-03-2014, 10:18 AM   #45
nbrooks is on a distinguished road
Army:
nbrooks's Tacoma Gallery
Originally Posted by nbrooks View Post
An update with a lesson learned.
Warranty Service from Pioneer is practically none existent.
Around the beginning of March the unit started having problems with the SiriusXM function. I emailed Pioneer tech support and advised that I had performed the firmware update, but that the screen occasionally froze.
It took TechSupport 6 days to respond and advise me to perform the firmware update. I responded, telling them to look at my first email where I told them I'd already done that. Another 6 days and they tell me to take it into their authorized repair shop. Shortly thereafter the unit failed to recognize the Sirius Module so I contacted Sirius and they immediately shipped a replacement. The unit failed to recognize the replacement so I then took it into the repair facility on April 9th.
On April 21, the repair shop said they'd ordered a replacement XM board but they had no date when the board would be available and advised me to contact Pioneer for a replacement 5600BHS. I did so that same day and received a claim number and was told I'd be contacted within 48 hours.
There was no contact and I again emailed Pioneer and also contacted them via phone on April 29th was assured that the replacement would be shipped the next day and they'd give me a tracking number. (during this time I had also contacted the Consumer Business Alliance of Southern California who intervened but never received any response to their inquiries).
Not hearing from Pioneer on the 30th, I again contacted them on May 1, 2014 and finally received an email giving me a tracking number on May 2, 2014.
I guess I'm lucky because I found out that Pioneer will not honor warranties if you purchase their products through Amazon - now exactly how someone is supposed to know that is totally beyond me, because you don't actually see the warranty until you purchase the product.
If you have a problem with a unit purchased from an on line vendor or through Amazon - you should take advantage of Amazon's return policies. If you rely on Pioneer you'll probably be without a working unit for a couple of months.
I was thinking of writing a letter to the President of Pioneer North America detailing my experience, then I did a little googling and found a website where employees can rate their companies. Pioneer North America apparently has some real problems since a downsizing in 2009. Employees report that sales take precedence over Customer Service. I've had problems with purchases before and with Toshiba for example - they shipped me a new unit immediately and took a credit card number to ensure that I'd send the defective unit back when I received the replacement. Sirius shipped me a new module within days of my request.
I'm not sure that I would have received any different treatment had I purchased the unit from one of Pioneers authorized distributors at a cost of nearly $100 more than the Amazon price.
That being said - when it was working it was great.
Old 05-03-2014, 12:37 PM   #46
doughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the shed
doughboy's Tacoma Gallery
sorry to hear that and hope you get the replacement soon.
I think this is a risk we all take buying cheaper elsewhere instead of paying more at crutchfield. The warranty from authorized dealer only is fairly standard and is the same for any electronic device, like cameras, computers, tv, etc. The seller on Amazon or amazon itself may be an authorized dealer. you can try calling amazon. It appears they honored the warranty for your unit you got from amazon, albeit slowly. The quality of the product is the same, authorized dealer or not, only difference is warranty. If your pioneer box came with a USA warranty certificate, then it is from an authorized dealer and not a gray market item.
I had xm before on my stock jbl stereo, had the service for 4 years and then cancelled and now use hd radio and pandora only. I don't think I miss anything by cancelling xm, unless you got the howard stern station, which I don't.
http://www.tacomaworld.com/forum/aud...scription.html
you can probably ask for credit for the days your unit was out of service from xm. They'll probably just extend your subscription renewal date, which looks to be like over a month in your case.
Old 05-08-2014, 03:12 AM   #47
Army:
And one more chapter of the saga
Today, the replacement unit arrived at the Houston repair facility and I dutifully went there to pick it up.
What Pioneer apparently decided was an appropriate replacement for the defective Pioneer AVH-X5600BHS was the 2013 version. What the repair facility received in exchange was an AVH-X5500BHS refurbished unit.
Not only that, the refurbished unit had a limited 90 day warranty which apparently replaces the 360 day warranty of the original unit.
Needless to say I'm somewhat perturbed and will be contacting Pioneer in the morning. Although the terms of the warranty indicate they may substitute an equivalently priced model, the replacement does not have the same attributes as the one I purchased. Why in the world they decided to replace this years model with last years is totally outside of my comprehension.
more to come
Old 05-08-2014, 10:00 AM   #48
I thought the 5500 and 5600 are exactly identical except for the label (which you won't even see on the faceplate) so they can sell it for $100 more.
http://www.crutchfield.com/S-O0pXVAa...-X5600BHS.html
if you really want the 5600, maybe you can ask them to move the xm board from the 5500 to the 5600, but I would just leave it alone if it were me.
when I was shopping for a head unit, I noticed the price of x5500 was actually higher than the x5600 on ebay (and probably on amazon). who knows you might actually be getting a better unit if pioneer decided to use lower quality cheaper components on the x5600.
Old 07-30-2014, 01:45 PM   #49
Army:
more to come
Sooo, I contacted Pioneer and was advised to return the replacement to them - they provided me a fedex prepay label for the return. About a week after they received the return, I received a brand new replacement unit.
It's been installed and working perfectly for about 6 weeks.
When dealing with a defective unit - deal with the place you bought it from and avoid Pioneer warranty service at all costs.
Old 07-30-2014, 04:55 PM   #50
glad it ended well.
I liked the pioneer I got, that I also replaced the radio of my old car with a pioneer deh-x8600bh for $130.
Tacoma FJ transfer case install 2nd gen scgunslinger 2nd Gen. Tacomas 13 02-23-2014 12:05 AM
Anyone in Dallas able to help install OME lift on Tacoma 2nd Gen.? toyotajhui Suspension 1 07-08-2013 05:18 PM
has anyone put a pioneer avic x910-bt into a 2nd gen fj40taz Audio & Video 5 11-29-2012 12:48 PM
1st gen rim to 2nd gen install issues Uke2 Wheels & Tires 4 11-13-2012 02:28 PM
IPAD INSTALL IN DASH OF TACOMA 2ND GEN c.coulby Audio & Video 4 11-27-2010 10:37 PM
