Advice on sub for my set up
Old 02-16-2014, 01:35 PM   #1
SKULLY [OP] SKULLY is online now
SKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shedSKULLY is one of the sharper tools in the shed
SKULLY's Avatar
SKULLY's Tacoma Gallery
Looking for a little advice on a sub for my set up. Will the amp that I have be enough to power the speakers and sub that I am looking at? Planning on setting up the amp as a 3 channel. This is the first system I have installed and already have the deck and speakers installed. Just adding the amp to power the front speakers and new sub (crutchfield link below).
I am running this pioneer deck:
Along with these 6.5 speakers up front:
This is the amp that I am going to run:
Going to run it like this:
Looking at getting this sub and building a small box behind the driver side backseat.
http://www.crutchfield.com/S-CDEYTA4...-SW2501S4.html
Just want to make sure that the amp will power the front speakers and sub with enough power?! Thanks for any input!!
Old 02-16-2014, 02:18 PM   #2
ZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shedZMan2k2 is one of the sharper tools in the shed
ZMan2k2's Avatar
ZMan2k2's Tacoma Gallery
I love my Sundown Audio SD-2's. They hit hard, and are clear as well. Seems like your amp would power it well. It's a 500w rms sub, so you're well within the range of power it can take, and the Sundown subs are designed tow work in small boxes as well. I'm running them in .6cu ft boxes each right now, but I just built a ported box to run them as well. Should be a different experience for me. But in sealed, they hit hard and clean. And with they're shallow mounting depth, you can get away with a smaller box too.
Old 02-16-2014, 02:53 PM   #3
SKULLY's Avatar
It says the the RMS power range for the sub is 50-300? If I the set the amp up as a three channel it says-
speaker A output= nominal input: min 100W
speaker B output= nominal input: min 300W
So B would be set up as the sub. I just want to make sure what I think is right and will work is actually correct! Lol
Old 02-16-2014, 03:04 PM   #4
ZMan2k2's Avatar
Yeah, you'll be fine running 300w to the sub. Just means you should have zero chances of frying the voice-coil. Then again, I'm putting about 750w per sub at them, and they take that like a champ. Just be prepared for a large magnet. It's a shallow mount sub, but the magnet is huge!
Looking for a new set of rear gas shocks, any advice? 05BDS Suspension 14 07-19-2013 04:29 PM
What set up is best for me?...need advice please StreetTaco4Me Suspension 13 05-19-2013 09:28 AM
1 Set mudlaps with white 4X4, 1 set stock lights, 1 halo headlights Studder 2nd Gen Tacoma Marketplace 4 12-25-2011 06:21 PM
Advice for 05+ AllPro UCA & Evan Walker 2.0 Suspension Set-Up RAD 2nd Gen. Tacomas 14 07-25-2009 11:42 AM
