TroubleShoot Sound System Issue
Discussion in 'Audio & Video' started by TopGuns, Dec 15, 2014.
  1. Dec 15, 2014 at 5:44 PM
    TopGuns
    TopGuns [OP] Well-Known Member
    Kevin
    So Cal
    08 Mid Travel
    Mid Travel, Satoshi Grill, Halo Projector Headlights, 2x 10" Kicker Comps, OEM Roof Rack,
    2008 toy taco JBL package
    2x10" kicker subs with Kenwood 1000 watt
    Tapped into stock JBl sub signal wire coming from the stock JBL amp into a line output converter. Then into Kenwood amp.
    The Issue:
    I was out in Barstow and I was driving over some rought terrains when my radio cuts off(no audio from any speakers). I try turning the nob on the radio, but the number didn't move. I let it be and 5 min later I check it and it works fine but still no sound from speakers.
    What could the issue be? I checked the fuses under the hood, and the connections in the rear of the radio. Also checked the stock JBl amp plugins. Only thing that I can think of is a blown Stock JBl amp, but why would off-roading cause an amp to blow?
    Any help would be appreciated.
  2. Dec 15, 2014 at 7:35 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    im gonna say stock amp pooped out on you. it just its time i guess
  3. Dec 16, 2014 at 10:34 AM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
    That's what I'm thinking. But other than that, what could it be? A short?
  4. Dec 16, 2014 at 10:42 AM
    Aw9d
    Aw9d That one guy
    Could be a ground that came loose or a short in the line.
  5. Dec 16, 2014 at 10:51 AM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
    Where do the factory components ground to? Also, how do I check for a short? Thanks
  6. Dec 16, 2014 at 10:57 AM
    Aw9d
    Aw9d That one guy
    Honestly I'm not sure where the factory JBL grounds too. I didn't pay attention when I ripped it all out of my truck.
    I'd get out a DMM and start seeing what powers on and what doesn't. You'll find a dead item somewhere, then start tracing wires. It's a bitch.
  7. Dec 17, 2014 at 6:33 AM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
    Damn alright. Thanks for the info man.
  8. Dec 18, 2014 at 3:22 AM
    ike3000
    ike3000 Well-Known Member
    hopefully you didn't shake any amplifier internal components loose. although the Tacoma is technically an offroad vehicle, i'd be surprised if JBL went the extra mile on shock/vibration testing. good luck!
  9. Dec 18, 2014 at 11:28 AM
    Aw9d
    Aw9d That one guy
    Any luck OP?
  10. Dec 18, 2014 at 5:25 PM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
    Finding these amps is painstaking.
    Couldn't get to it in the last couple of days. Gunna look at tommrow when I'm installing my bedsides. I'll let you guys know if I find a fix.
  11. Jan 2, 2015 at 11:33 PM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
    Pulled out my amp circuit board and found this. Two of the metal connections are broken and theirs a burn mark. I hope this is the issue that is causing my system not to work. How do I fix this? Can I take it somewhere to get it fixed? I have no experience with circuit boards. Thanks again.
  12. Jan 3, 2015 at 10:40 AM
    RedHarris
    RedHarris Member
    So California
    06 Tacoma TRD
    I'm an Electronics Tech (Aircraft Avionics) by trade.
    Those rectangular chips look like Pre-Amp or Amp IC's (integrated ciruits) to me. There may be burnt components (resistors, caps, diodes) behind that chip as well. The scorched Board might need repair before mounting new components. If the board is multi-layered,(doesn"t look like it) then forget about it. Though it might be POSSIBLE to replace the toasted IC, it is likely beyond your capabilities if you are not a full fledged Tech, with access to all the necessary tools. Thats supposing you can even IDENTIFY that IC and find a new one in the marketplace.
    I doubt that you will find a shop willing to go through the trouble to fix that for you. Paying a bench tech for the amount of hours it would take to troubleshoot, repair and test that device would almost certainly make it Beyond Economical Repair. I doubt that it would even be feasible to replace the entire board.
    I'm sure there are HOBBYIST's out there who might be able to fix that. Some people do it for the fun of the challenge. Honestly, its probably not worth it. Replace the entire device. Or, look at this as an opportunity to Upgrade your Audio System.
  13. Jan 3, 2015 at 10:47 PM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
    Thanks for the info! Appreciate the in depth description of the problem. Looks like I'm going to either replace or upgrade. Thanks agaim
  14. Jan 3, 2015 at 10:50 PM
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
    NSA Pnl,US OFF ROAD winch mount bumper,Sirrius pods,Clazzio covers,Wheathertech mats, Pro Comp wheels,Image dynamics audio,leer cover,lights,bed mat,anti dark light...
    Go for it !
    I'm saying do you like music type of upgrade .....
    :rockband:
  15. Jan 4, 2015 at 10:36 AM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
    How do I run the stock speakers off a new amp? What's the original wattage of the stock jbl amp? I'm running my 2, kicker 10" off a 1000 watt kenwood amp right now, but I think that if I were to wire my door speakers to it, It wouldbn't perform as well. What is the best way if I don't want to go back to a stock jbl amp. Thanks.
  16. Jan 4, 2015 at 1:20 PM
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
  17. Jan 4, 2015 at 1:34 PM
    TopGuns
    Kevin
    So Cal
    08 Mid Travel
