2013 into 2012 oem radio help
Discussion in 'Audio & Video' started by bellot8670, Feb 12, 2015.
  1. Feb 12, 2015 at 3:07 PM
    bellot8670
    bellot8670 [OP] Active Member
    Steven
    Mt Sterling KY
    2012 Tacoma SR5 double cab 4x4
    I installed a 2013 non entune touchscreen radio into my 2012 model radio. I had 3 connectors from the factory harness that would not fit... I believe they are the Bluetooth microhone for hands free phone and the steering wheel remotes. Also the antenna connector is different... Anyone make this switch before? Is there any way to make the above issues work. Any help is appreciated
  2. Feb 12, 2015 at 3:21 PM
    bellot8670
    Steven
    Mt Sterling KY
    3CDF2330-E981-4180-99A5-6DEB058E19FE_zps_4bc60bb74055bb621cc626c3c0167f4f872187b8.jpg
    these are the connectors that were left over
  3. Feb 12, 2015 at 3:22 PM
    bellot8670
    Steven
    Mt Sterling KY
    B3C0E958-F180-4E3B-9D69-90025F8F5055_zps_9fc9866efbd22368d8ae6643d8704d01accf177f.jpg
    this is the back of my factory 2012 radio
  4. Feb 12, 2015 at 3:23 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    You will need the 28pin to 20 pin adapter and the blue plug is the Xm antenna
  5. Feb 12, 2015 at 3:23 PM
    bellot8670
    Steven
    Mt Sterling KY
    FEE92B25-A130-4BED-A127-32268E1333AD_zps_92e3996c2547db52513f449f52b9ff8ca522a315.jpg
    this is the back of the new 2013 radio I'm attempting to install
  6. Feb 12, 2015 at 3:24 PM
    bellot8670
    Steven
    Mt Sterling KY
    where do i get them at
  7. Feb 12, 2015 at 3:28 PM
    zeekevin
    San Diego
  8. Feb 12, 2015 at 3:29 PM
    zeekevin
    San Diego
    Also you can but the antenna adapter also it's less then 10 bucks
  9. Feb 12, 2015 at 4:50 PM
    bellot8670
    Steven
    Mt Sterling KY
    i found part numbers 546-00120 and 546-74120 on another thread for doing the same radio swap. are those part numbers something i can pick up at the local toyota dealership or something i'd have to order online. right now I'm able to bluetooth spotify so I'm managing, but missing the bluetooth phone which isn't working when i try, it says no mic
  10. Feb 13, 2015 at 9:08 AM
    bellot8670
    Steven
    Mt Sterling KY
    Update. I ordered the 28 pin to 20 pin harness adapter and the antenna adapter. So everything's taken care of other than the blue Xm plug... Wondering what others did to regain Xm radio
  11. Feb 16, 2015 at 1:24 PM
    mrbee2828
    mrbee2828 Well-Known Member
    BJ
    Virginia Beach
    Following
  12. Feb 20, 2015 at 1:43 PM
    SWFLTim
    SWFLTim New Member
    Tim
    SW Florida
    PreRunner SR5
    I'm following this as well because I'm going to attempt the same next weekend.
    Steven, did you have bluetooth in your original system?
    My truck is not equipped with it and I'm curious as to what I'll have to do to gain those capabilities. I see all kinds of aftermarket add-ons and just wondering how much if any is needed.
    Good luck in your efforts and I'll be following. Damn that sounds creepy.........
  13. Feb 20, 2015 at 8:08 PM
    bellot8670
    Steven
    Mt Sterling KY
    Finished with the install. I ordered the 20 pin to 28 adapter from dealership for roughly 34 dollars. Then the metra 40lx-21 antenna adapter from local shop for 20 dollars. Right now I have an/fm radio, cd, and Bluetooth audio. Steering wheel controls work fine and usb charge phone. I lost Xm radio and auxiliary jack input. In order to get Xm radio, you'll need to pick up an SL3 tuner and sxv200 from vais technology. Think it runs in the low 300 dollar range for both parts. My subscription was about to run out so not too worried bout losing Xm. The address book and hands free phone is way better than my stock head unit was so its a good trade off. Overall happy with the swap
  14. Feb 21, 2015 at 3:36 AM
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
    You can get the XM module from FLTrucks for something like $85. It will screw onto the brackets below the radio.
  15. Feb 21, 2015 at 6:59 AM
    SWFLTim
    SWFLTim New Member
    Tim
    SW Florida
    PreRunner SR5
    Right now I just have the base head unit, 6 speakers, no Bluetooth, no steering wheel controls,it does have the XM radio.
    My end game here is the Bluetooth capabilities, which I don't have now. I have the 2013 touchscreen head and I guess it would be nice but will I have to buy a Bluetooth module for it or is it built into the head itself?
    There are all kinds of after market modules I can plug into the existing head unit and I'd be fine with that.
    I don't mind investing a little time and money into a project. I have the tools to do most anything needed. All I need is to gather a cut list of items needed because if I need something that I don't have on hand a simple trip to the hardware store or Toyota dealer for most is a day long journey for me.
    Appreciate the heads up on FLTrucks. XM would be nice to have at re-sale, but not needed for my purposes. Looking OEM at re-sale also helps, I think.
    I do appreciate the replies and advice.
  16. Feb 21, 2015 at 8:24 AM
    bellot8670
    Steven
    Mt Sterling KY
    There is a stock Toyota Bluetooth mic you can order from the dealership. I'll pm you the part number. I've got it wrote down at home.
  17. Feb 21, 2015 at 8:25 AM
    bellot8670
    Steven
    Mt Sterling KY
    Can you post the link for this? Thanks in advance
  18. Feb 21, 2015 at 10:05 AM
    zeekevin
    San Diego
    That xm unit is only for the 2014+
  19. Mar 9, 2015 at 6:35 PM
    bfum1059
    bfum1059 Active Member
    Michael
    Lexington, SC
    2012 Tacoma TRD
    bought used with the rims Added running boards, woods and waters matte black diamond tread toolbox, kryptek typhon seat covers
    Trying to put a 2015 touchscreen into a 2012. I have the blue connection as well for the Xm. is there no plug adapter? do we really need a separate module for the XM? Though it was built into the radio (or can we hijack it from the 2012 radio?)
  20. Mar 9, 2015 at 6:36 PM
    zeekevin
    San Diego
    You gotta order the xm unit i think its like 85 bucks from fltrucks
