2005+ Backseat Sub Box Capacity
Discussion in 'Audio & Video' started by Cheetah223, Jun 29, 2009.
  1. Jun 29, 2009 at 12:23 AM
    Cheetah223
    Cheetah223 [OP] Member
    California Bay Area
    Not a Taco...
    Has anyone figured out what the biggest sub box (capacity-wise) you can squeeze behind the back seats in a double cab is?
    I want to start looking for subs, but I need to know what my max capacity is so I can get a sub that I'll be able to tune the box for and not be limited by size.
  2. Jun 29, 2009 at 12:28 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    u want to make one box all the way across? just measure it up, seperate into sqaures and triangles and do the math
    i have designed a box to have the JL 13TW5 fit with .8 Cubic Ft of airspace, no money currently
  3. Jun 29, 2009 at 12:36 AM
    Cheetah223
    California Bay Area
    Not a Taco...
    Measuring would be the easy solution, but I'm in Iraq for a while :) Unfortunately I can't quite reach to accomplish the task myself.
    I was just thinking behind each seat. If I feel the need for two subs I'll build two identical boxes.
  4. Jun 29, 2009 at 12:50 AM
    Burgman
    Stephen
    Ric VA
    well since the seats are 60/40... my box is very close to the center coming from the 40 side
    u might be able to squeeze out two 1 cubic foot boxes, it might be tight though and depth is an issue, the JL is only 2.5 inches deep which is all my setup will fit
  5. Jun 29, 2009 at 12:58 AM
    Cheetah223
    California Bay Area
    Not a Taco...
    I've gotta check out what subs I'm after. I was going to put some JL 10w6v2's in my car, but I haven't even looked at them recently enough to recall the mounting depth. I'll bet it's beyond 2.5" though. Maybe I could milk some depth if I glass it instead of building with wood?
  6. Jun 29, 2009 at 5:23 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    You should be able to get just over 2 cuft, if it is all used. However, you won't have any where convenient for amps and the like. Another note, your mounting depth is much more likely the limiting factor, rather than total airspace.
  7. Jun 29, 2009 at 6:55 AM
    Cheetah223
    California Bay Area
    Not a Taco...
    JL makes a stealthbox to mount behind the back passenger seat that holds two 10w1v2-8's, which have a mounting depth of 4.34"...That gives me some ground to run on. Sooner (a sooner from TX? sounds dangerous..) you say just over 2 cuft, are you talking about a single box spanning the whole width, or breaking the boxes up? I'm assuming the former, but just hoping for some clarification.
    Thanks guys.
    Edit: Gross, I'm leaning toward the 13tw5's...Anyone got some leftover seeds lying around for a money tree?
  8. Jun 29, 2009 at 7:45 AM
    sooner07
    A A Ron
    DFW, Texas
    I live here, and love it. But, I am a proud Sooner fan.
    As for the box; yes, I was refering to one single span of a box. You can get a little over 2 cuft out of it. That is the most airspace possible, if that is what you are trying to acheive. But, I think you are most likely going to have issues finding speakers with a shallow enough mounting depth, especially one that would require that sort of airspace (I doubt it exists). Then there is the logistical issue of where to put your amps, if you take up all the room behind the seat.
    I have some pics of the box that MrMarv built for me and the subs and amps I am using in my gallery. Check it out for some build ideas.
  9. Jun 29, 2009 at 7:52 AM
    dixiedeerslaya
    dixiedeerslaya Well-Known Member
    You got a link to your gallery sooner07?
  10. Jun 29, 2009 at 10:22 AM
    Cheetah223
    California Bay Area
    Not a Taco...
    I'll have to do some math if I do want to get the 13tw5's after all, but the boxes I had tuned for 10w6v2's tuned in best right at .928 cuft. I'm not going for pure volume, but neither am I experienced enough with car audio to know how capacity varies to tune for a specific sub. I'll have to find all the formulas and whatnot I used when I worked out the boxes for the 10w6's..Hopefully the shallower depth would allow for a slightly lower, or at least similar volume since the 13tw5's got an xmax reduced by roughly half, to make up for the larger surface area as compared to the 10w6.
    I'd also like to check out your gallery sooner.
  11. Jun 29, 2009 at 10:42 AM
    sooner07
    A A Ron
    DFW, Texas
    It's the camera under my avatar, like everyone else's. ;)
  12. Jun 29, 2009 at 10:45 AM
    Cheetah223
    California Bay Area
    Not a Taco...
    Well fancy that, you learn something new every day :D
  13. Jun 29, 2009 at 12:06 PM
    dixiedeerslaya
    Haha thanks sooner.... Just call me captian obvious!
  14. Jun 29, 2009 at 1:28 PM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    have you tried Bernard Madoff? He won't need his money tree for a 150 years.
    The 13TW5 is worth every penny I ripped of my money tree
  15. Jun 29, 2009 at 1:38 PM
    Cheetah223
    California Bay Area
    Not a Taco...
    Perhaps he could offer a lesson in resourcefulness...Group buy for a Bernie Madoff "investment school"?!
    My only reservation on the 13tw5's, aside from price, are potential sound quality issues. Please recognize that's a completely unfounded concern, stemming from no reviews I've read and definitely not from hearing them in person, I just have a very simple mind, and subs that small can't logically make great sound in my undersized brain :rolleyes:
  16. Jun 29, 2009 at 2:21 PM
    CoreyJ
    CoreyJ Well-Known Member
    Laurel, MS
    TRD Off Road
    I have searched everywhere for boxes myself and this is what I found.
    The deepest box I have seen was built with 5/8" MDF and had a depth of 5 1/2 inches. So the depth would be less if using 3/4" mdf to build the box. I have seen a fiberglass box (all fiberglass except the front wall of the box ) and it had a depth of 5 5/8". Also there was a limit on the diameter of the magnets on the box of the subs and that was 6". If the magnets are larger, then the depth you have available decreases. All of these boxes were for 8's or 10's. The only times I have seen these trucks with 12's they were of the slim sub variety.
    Airspace wise, the largest 2 sub box I have seen was .8 cubic foot per sub. If doing a single sub, and building the box all the way across, 1.6 is possible.
  17. Jun 29, 2009 at 2:39 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Image Dynamics ID 12 fits all those specifications and so does the StereoIntegrity Mag. The Mag is the better sub and is VERY shallow <5in. Even just one of those will be plenty for a Tacoma.
  18. Jun 29, 2009 at 6:17 PM
    cjag
    cjag Active Member
    Georgia
    07 TRD OFF Road 4x4
    www.cardomain.com/ride/2537226
    Have 4 ID8's, each pair sharing .60 cubic ft in seperate enclosures. So i squeezed in about 1.2 cubes, and could have done more if not for design of amp rack. Hope this helps.:thumbsup:
  19. Jun 30, 2009 at 8:54 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    I'm just skimming through today since I've been extremely busy so my apologies in advance if I say anything that was already covered! :eek: 10W6v2's are some of my favorite subs however they will not fit without some serious surgery. On the other hand if you like the w6v2 IMO you will also like the 13TW5 as they have very similar SQ. Also, the depth available in a DC is dependent on basket shape and diameter as well as magnet diameter.
  20. Jun 30, 2009 at 10:09 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Indeed...very nice sub but also very pricey. Fits the bill completely in this case but the bill is what you'll be worried about.:eek:
