Tacoma World Forums GreySky72's 2008 Tacoma TRD Sport 4x4, covered in mud and PackerfanXD's 2007 Tacoma TRD at the Phoenix Meetup
Register Site Information Glossary Calendar Search Today's Posts Mark Forums Read
the standard stereo and reg cab question
Old 01-03-2008, 05:38 PM   #1
phantom has much to be proud ofphantom has much to be proud ofphantom has much to be proud ofphantom has much to be proud ofphantom has much to be proud ofphantom has much to be proud ofphantom has much to be proud ofphantom has much to be proud ofphantom has much to be proud of
phantom's Avatar
phantom's Tacoma Gallery
trying to save myself the future trouble of pulling it out just to look in the future!!
i have a stock 07 toyota 4X2 ( 5 lug) with a regular cab. there are no rear speakers at all. the control doesn't do anything and if i select back it just gets quieter
so my question
are the jacks there but they don't put in rear speakers
and can i get a set of speakers and then have my front /back adjustment and not just left right?
i am a old fart with marginal hearing so don't need anything but stock speakers
anyone have any recommendations for speakers if i just have to hook them up ?
thanks
Old 01-03-2008, 05:46 PM   #2
Towing Guru
maverick491 is a glorious beacon of lightmaverick491 is a glorious beacon of lightmaverick491 is a glorious beacon of lightmaverick491 is a glorious beacon of lightmaverick491 is a glorious beacon of lightmaverick491 is a glorious beacon of light
maverick491's Avatar
maverick491's Tacoma Gallery
so my question
thanks
My guess would be that there is no wiring in the truck for them, and that it is just a case of toyota just using the same stereo across several trim packages, ie all tacoma models unless you pay for the upgrade to the 6 disc changer or the JBL system.
In the access cab and double cab models the rear speakers are in the doors. Since you have no rear doors I am not sure where to suggest that you would look for them to even see if the wiring was there.
Perhaps along the back wall of the cab? Take a look for something that looks like a speaker grill?
Perhaps someone with a regular cab truck will chime in and offer up some better information.
Old 01-03-2008, 06:12 PM   #3
jjewell is on a distinguished road
jjewell's Avatar
jjewell's Tacoma Gallery
you can definitly put speaker back there but as far as hooking them up to the stock radio i'm to sure. i'm pulling my radio tomorrow and i can take a look at it to see if it has any hook up's for rear speakers.
Old 01-03-2008, 06:40 PM   #4
Jesse is on a distinguished road
Jesse's Tacoma Gallery
You are correct. There is no speakers back there. Even if there were, it will not sound any better than what you already have because the seat would be covering them up. If you really want better sound, I would install a set of component speakers in the front doors. If you go to Crutchfield, they have a sale on some Blaupunkt components for $50. If you don't want to spend too much money, than definately don't try to install speakers in the rear. Concentrate on improving the front.
Old 01-03-2008, 07:10 PM   #5
phantom's Avatar
jjewell thanks on looking, and a pic or a sketch of location of the jacks would be appreciated !
ANYTHING out of the back area would be a improvement as sound is very directional now !
there is room in the back to put in two speaker enclosures ;-D, not a big bass unit but two speakers on left and right down low !
and it would be a "bit of fun" to string the wires, but there is already directions on removing the side kick panel and door jam and should be room to use that !
anyone know what the power outage is of the stock radio and resistance ( ohms) of the factory speakers?
thanks
the music i listen to dosen't have heavy bass anyway !
or if anyone has the original door speakers and wants to sell them cheap after doing a upgrade?
i'm not going to do this tomorrow, but will in the future
and 1/2 of the radio output isn't getting used now and the sound is so directional
thanks
Old 01-03-2008, 07:22 PM   #6
Towing Guru
thanks
Factory speakers have a 4 ohm resistance. (4.1 or 4.2 to be exact if I remember correctly) I can't remember the power output off the top of my head though. Sorry.
Old 01-03-2008, 07:27 PM   #7
If you are really wanting stock speakers, I have a pair of stock speakers that I took out of my 06 Infiniti G35. They are practically brand new. If you are going to run new wires anyway, it wo'nt matter if they are toyota or Infiniti speakers. Let me know if you are interested.
Old 01-03-2008, 07:34 PM   #8
phantom's Avatar
on the speakers
jessee
check for a pm in a min ;-D
Old 01-04-2008, 09:05 AM   #9
5862007 is on a distinguished road
5862007's Tacoma Gallery
I just bought a 2007 Tacoma Regular Cab and the only speakers are the two factory speakers on each door. The factory speakers definitely leave something to be desired if you're prone to listen to music loudly, as I sometimes do. For the most part, though, I've found that lowering the Bass level on the control to -1 or -2 on the knob takes the rattle/distortion out of the picture most of the time while still having a decent bass kick for the normal rock music that I listen to. I usually don't turn the volume past the 45 mark on my speakers, so I've been able to get by alright over the past two weeks and most everything sounds pretty good.
Since my last three vehicles were all Toyota Corollas, I've been accustomed to hearing music from back speakers, but I strangely don't miss them that much on my Tacoma. I'm sure that I could find a way to mount some back speakers up on the back corners of my truck from the ceiling right above the back window if I really wanted to get creative and get advice/work from some expert audio people. For now, I have no desire to "mess with the formula", though, and I'm more inclined to get by on minimal or no modifications for the present. Some better JBL speakers or other speakers on the doors to replace the factory speakers is a "distant future" project and I've gotten some great advice here on this forum from y'all so far. Just sticking with the ole' factory system for the immediate future, though.
Old 01-11-2008, 11:15 AM   #10
gsm gsm is offline
gsm is on a distinguished road
gsm's Avatar
gsm's Tacoma Gallery
I just installed rear speakers in my standard cab. I posted my install if you are interested.
The sound quality/clarity/volume is definately noticeable. Since there is so much space behind the seats the sound is easily heard. I'm 5'10" and when driving my seat is a good 6" from the back window allowing plenty of sound to be heard. And yet I call put the seat all the way back and not damage the seat nor the speakers.
Old 01-11-2008, 12:40 PM   #11
phantom's Avatar
that was a great write up you did !!!! and i will be following your instructions soon !
thanks a lot !
Display Modes
Synthetic or standard oil djhannah 2nd Gen. Tacomas 33 11-30-2008 01:38 PM
Toyota Tacoma - New Gold Standard! TheMaster 2nd Gen. Tacomas 13 11-25-2008 05:07 PM
Former VW owner, new 07 Access cab owner with stereo question stockham@sunflower.com Audio & Video 3 07-18-2007 11:41 PM
stock stereo question SPOWERS07 Audio & Video 18 05-08-2007 06:40 AM
2005 Taco double cab stereo question ??? taco suprme sport Audio & Video 5 01-15-2007 09:10 AM
Copyright © 2008 Tacoma Forum
