DIY: Rear Speakers- 2nd Gen Reg Cab
Discussion in 'Audio & Video' started by gsm, Jan 11, 2008.
  1. Apr 15, 2011 at 2:39 PM
    #81
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    hey champs.........page 3 post 50 i think it was.....gsm put in some mesurements
  2. Nov 1, 2012 at 11:12 AM
    #82
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i'm bumping this back up. i'm thinking i wound to add some sound deadening to the rear wall. after i complete that, i'll want to carpet it so i dont have to look at the deadening mat. will the spray adhesive stick to the sound deadening just the same as to the bare metal of the truck?
  3. Nov 1, 2012 at 1:01 PM
    #83
    NuovoTech
    NuovoTech Well-Known Member
    Upper Left Corner
    09 Tacoma 4x2
    Just adding rear speakers made a world of difference in my base cab, IMO adding sound deadening, etc seemed unnecessary. Tho it might help to cancel out road noise at freeway speeds?
  4. Nov 1, 2012 at 2:22 PM
    #84
    danteisme
    South Western PA
    that is the main reason i want to do it. i added the rear speakers to the cab a couple years ago. i'd like to cover up the bare metal with some automotive carpet, and i figured i may as well add some sound deadening before i do the carpeting.
  5. Nov 3, 2012 at 4:26 PM
    #85
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    has anyone measured the out wattage of the factory radios? i have the 2013 6.1 touchscreen and want to get rear speakers that will match well.
  6. Dec 9, 2012 at 5:47 AM
    #86
    11bdad
    11bdad New Member
    SC Lowcountry
    Bone stock
    Thinking of adding some rear speakers to my 2012 reg cab. Should I expect to find a connection with the brown wire behind the radio? From reading this thread it appears that the connection with the brown wire is for rear speakers. Anyone know where the wires terminate in the back? It appears as though this truck hasn't been pre-wired for anything (so far), so I'm expecting to not find a connection with the brown wire. I was thinking of using a Scosche TA02RB connector & running speaker wires & a ground. Has anyone wanting to add rear speakers not found the connector behind the radio?
  7. Jan 23, 2013 at 9:11 AM
    #87
    SlowComa666
    San Antonio TX
    another thought on all this
    since we have another set of outputs...why not "bi-amp" the front door speakers.
    this way we can fade between the "6x9" and "tweeter" to tailor the sound to our liking.
    this also assumes speaker replacement as the factory offering are kinda shit.
  8. Sep 5, 2013 at 6:32 AM
    #88
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    good job on the speaker carpet and box
  9. Sep 8, 2013 at 10:13 AM
    #89
    Evenflow
    Evenflow Well-Known Member
    Jason
    San Diego, CA
    06' DCSB 4x4
    Yes
    Sorry if someone already mentioned this but any stereo shop will have Metra brand male harnesses for repairing OE harness that have been chopped. That would be the easiest way to tap into those rear speaker outputs on the back of the OE deck.
  10. Mar 14, 2014 at 5:12 AM
    #90
    DealsGapCobra
    DealsGapCobra New Member
    This thread has bee very helpful. I did my base 2007 4x4 yesterday and found some differences. When I pulled the radio to add the speaker wires, I noticed they were already installed! So then, the hunt for the loose ends began, thought I would share what I found.
    On the drivers side, the wires are yellow and black (black positive based on the information from the OP) and they terminate in the bottom of the white plug shown near the bottom behind the drivers kick panel. The speaker wires are slightly larger in diameter than the other wires in the connector.
    The passenger side wires are red and yellow (red positive) and the terminate behind the passenger kick panel. They are the only two wires in the black comnector seen near the top left of this photo.
    This forum has been very helpful to me over the past year so I figured I should join and post what I found.
    Thanks!
  11. Mar 14, 2014 at 4:50 PM
    #91
    clcnohio
    clcnohio Well-Known Member
    Carl
    Canton, Ohio
    4x4 base 2.7 5sp Barcelona red
    Gear Alloy wheels, Dee Zee bull bar, soft tonneau cover, Reese hitch. Magnaflow muffler, custom graphics,bug shield, window vent shades,modified stock grill, blackened stock headlights, aftermarket fog lights, led spots.
    Great job there...I'm going to do the same in my regular cab....thanks
  12. Mar 27, 2014 at 7:30 AM
    #92
    tony2018
    tony2018 Well-Known Member
    Have you guys thought about maybe a 6x8 in the back instead of a 6.5?
  13. Apr 17, 2014 at 7:43 AM
    #93
    nevenelestate
    nevenelestate Well-Known Member
    Andrew
    Southern MD
    12 Tacoma V6 4X4 SR5
    Stock
    Great info, has anyone found these wires on a 2012 or newer? really wish there was an easy source for Tacoma wiring diagrams!
  14. Mar 30, 2015 at 8:11 AM
    #94
    lennyk
    lennyk Well-Known Member
    Mountain Top, PA
    Magnetic Gray Metallic
    Thanks for the info!!!!!!!!!!!
  15. Mar 30, 2015 at 8:14 AM
    #95
    lennyk
    Mountain Top, PA
    pic1.jpg Great Info - Installed my Rear Speakers in the "Packs"
  16. Apr 22, 2016 at 10:41 PM
    #96
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    That looks awesome. How do you like the "packs"?
  17. May 2, 2016 at 1:41 AM
    #97
    Gilbot1088
    Gilbot1088 Well-Known Member
    Rey
    East L.A.
    2011 TRD sport extra cab
    Hey guys what size r the roof speakers? and is it difficult to upgrade them?
  18. May 10, 2016 at 12:32 PM
    #98
    lennyk
    Mountain Top, PA
    They Are GREAT - Besides My Speakers I Keep Tools, Gloves, Tie-downs and Other Stuff In Them:thumbsup:
  19. May 31, 2016 at 4:55 PM
    #99
    Tacomagirl76
    Tacomagirl76 REG. CABS RULE!
    Some where in New England!
    2014tacoma reg cab
    Duratra wrangler tires,tinted windows,kicker rear speakers,JL Audio front,fosgate amp. More to come
  20. May 31, 2016 at 4:56 PM
    #100
    Tacomagirl76
    2014tacoma reg cab
    Here are my rear speakers in my reg cab. They are 5 and quarter size
