Bad amp/sub combo?
Discussion in 'Audio & Video' started by JoshLV, May 16, 2011.
  1. May 16, 2011 at 9:02 AM
    JoshLV
    JoshLV [OP] Well-Known Member
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Hey guys,
    Just recently my setup has been giving me some issues. It started off by by sub going out when I turned the volume up too high, then it would kick back on when I turned the deck off then back on. Now the sub won't hit at all. I hooked another sub up to my amp and didn't get anything off of it, so I'm assuming that my amp is the problem. All connections are good.
    I went to an audio shop to ask for advice, and they said that my amp and sub shouldn't go together????
    I linked them below. Thoughts?
    http://www.sonicelectronix.com/item_16663_Pioneer-Premier-TS-W2502D2.html
    http://www.sonicelectronix.com/item_22574_Kenwood-KAC-9105D.html
  2. May 16, 2011 at 9:13 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    its a 2-ohm sub. That amp should be fine for power. The amp puts out 900rms at 2-ohm, 500rms at 4-ohm.
    edit: guess you noticed that after I quoted you haha
  3. May 16, 2011 at 9:16 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Yeah, I realized that after i re-read the specs.. I was like shitttttt, i feel like an idiot.
    Who know's bring it to another car audio place get their opinion.. You might just have a lemon.
  4. May 16, 2011 at 10:43 AM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Who wired up your subs? The sub looks to have dual 2 ohm voice coils, which can be wired down to 0.5 ohm. If your sub is wired down, then your amp wont work because its "only" 2 ohm stable. You may have blown a fuse in your amp, so check that as well.
  5. May 16, 2011 at 12:11 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    I wired it at 2 ohms. Also, fuses are fine. They were the first thing that I checked. I'm pretty sure the amp is the problem, but I'm going to measure the power coming out of it with a multimeter. What ranges should it be putting out?
  6. May 16, 2011 at 12:25 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Something doesn't sound right here. You have a dual 2ohm sub, so your single sub wiring options are:
    o 1 ohm - coils wired in parallel, amp bridged
    o 2 ohm - one amp channel to each sub coil
    o 4 ohm - coils wired in series, amp bridged
    If you are running 1 ohm you still might be overdriving the amp. I would try wiring the sub to 4 ohms and run it off the amp bridged. Also might want to check that the amp gains are turned way down. Then check if you're getting anything.
    I've run into cases where amps that were advertised as being stable at a specified ohm rating were not when they were in bridged mode.
  7. May 16, 2011 at 12:49 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    I'm with ^^ here. You said you wired the sub to present a 2 ohm load which would be impossible unless you were only using one voice coil. Your options for a mono block amp would be a 4ohm load in series or a 1 ohm load parallel. If you only wired up one voice coil it could be getting too much power.
  8. May 21, 2011 at 8:29 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Find a 50Hz tone and measure if it's putting out any VAC.
  9. May 25, 2011 at 10:53 AM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Thanks for the help. I found the problem. After hooking up my buddies amp and sub to my truck, and them not working, I figured it was a power issue. So I started from the basics and checked out the breaker under the hood and it looked good at first glance, but the cable was put in there pretty weak so it wasn't getting a good connection. Problem solved.
