How to Switch Rear Speakers: 1st Gen Ex Cab
Discussion in 'Audio & Video' started by Trowbocop, Nov 2, 2012.
  1. Nov 2, 2012 at 6:41 PM
    Trowbocop
    Trowbocop [OP] Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Just picked up a set of 5x7 coax speakers, and I cant seem to get the floor to ceiling panels off to take out my blown stockers.
    Anybody have suggestions??
    I can pop most of the clips off, but it seems the seatbelts won't allow me to pull the whole panel off. Is there a trick to those things?
    Any help or pics would be greatly appreciated. :cheers:
  2. Nov 2, 2012 at 6:42 PM
    blitzburgh99
    blitzburgh99 Well-Known Member
    Houston, TX
    1999 Tacoma TRD 4x4
    239,600 (as of 7-20-13 and counting)original owner miles
    have you tried to take off just the grille panel? That is what I did in my 99.
  3. Nov 2, 2012 at 6:44 PM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    It looks like my model has that all one piece! How did you take yours off? I'm not sure why they would have the earlier ones easier to change then the later ones.
  4. Nov 2, 2012 at 6:45 PM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    I've been debating cutting it where that grill is, and either super gluing it back when said and done- or getting a new speaker grill to put on
  5. Nov 2, 2012 at 6:48 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    From the top of the grill that covers the speakers use like a putty knife I used a pocket Knife stick it to the right corner and pop off that clip then do that for the other side as well research this as I may be wrong
  6. Nov 2, 2012 at 6:59 PM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    What year is yours? Mine is '03
  7. Nov 2, 2012 at 9:27 PM
    zbaldo
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Mine is a 99 as well takes longer to get my knife than to pop those things out. Mind you after I did this it left a tiny dsnt/impression the plastic if you don't want that use like a putty or something doesn't seems like you mind though. I don't think Toyota would have worked backwards and made it harder to change the speakers if the speaker holes don't fit with the existing holes just pre drill and use a screw that's what I did
    Sorry for the late response day of the dead visiting with my parents
    I say that because when I got my speakers I was dying to put them on
  8. Nov 2, 2012 at 9:34 PM
    zbaldo
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
  9. Nov 2, 2012 at 10:26 PM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
