Sub questions
Discussion in 'Audio & Video' started by Bowfisher1, Apr 2, 2013.
  1. Apr 2, 2013 at 11:38 AM
    Bowfisher1
    Bowfisher1 [OP] Well-Known Member
    Ty
    Louisiana
    07 Tacoma Double cab
    3 inch Rough Country Off Road lift/level kit, NITTO Trail Grapplers, Monster Xd Series rims, memphis door speakers and amp, two sundown SD-2 10's, Kenwood head unit, weather tech floor matts, coverking neoprene shadowgrass seat covers
    Does anybody know what it means when a sub pre loads?
  2. Apr 2, 2013 at 2:27 PM
    Aw9d
    Aw9d That one guy
    Typically if you are buying a box a lot of people offer 'pre-loaded' boxes which means the sub comes already mounted and typically tested to ensure it works.
    Other than that I've never heard of pre-loading a sub.
  3. Apr 2, 2013 at 3:30 PM
    Bowfisher1
    Ty
    Louisiana
    I called Mr. Marv and asked him. He said when a sub pre loads the air from the sub hits a parallel surface and bounces back to the sub to fast causing it to distort and "sound like crap". Thank you for your reply.
  4. Apr 3, 2013 at 5:23 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    So how do you prevent it? get a bigger or deeper box, shallower sub?
  5. Apr 3, 2013 at 10:33 AM
    Geosh
    Geosh Why yes, I AM a rocket scientist.
    Chandler, AZ
    '03 PreRunner DC, 3.4L
    Polyfill. It will slow down the air travel inside the box and help prevent this.
  6. Apr 3, 2013 at 4:40 PM
    Bowfisher1
    Ty
    Louisiana
    I did not know this. Have you tried it?
    He said that there is a thing called loading which is a good thing. Pre loading can be prevented by giving more space between the sub and the parralell surface(the bottom of the seat) an you can do this by getting a seat lift and I think that makes the back of the seat not function.
  7. Apr 3, 2013 at 5:58 PM
    Bowfisher1
    Ty
    Louisiana
    We were talking about puting two 8's under the backseat of my 2007 Tacoma. Has anybody tried this? Do you really think if I filled te box with polyfill it would help?
  8. Apr 3, 2013 at 8:02 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I've done it in my Tacoma. Tell Marv that ItalynStylion gives you the green light to go for it. It sounds great in my truck and I'm picky as all hell.
    It would be better to not have the rear seat metal right in front of the cone but it's enough clearance to be fine. Plus, the seat isn't really parallel and it's not flat so I wouldn't worry too much. I can speak from experience here.
  9. Apr 4, 2013 at 4:34 AM
    Bowfisher1
    Ty
    Louisiana
    What year is your Tacoma? And what kind of subs do you have? Oh and how much air space it there per chamber?
  10. Apr 4, 2013 at 3:08 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I'm in a 2009. They're Elemental Designs e3.8 subwoofers. The airpsace is about 1 cubic foot and it's a single common chamber.
  11. Apr 4, 2013 at 3:27 PM
    Bowfisher1
    Ty
    Louisiana
  12. Apr 4, 2013 at 4:36 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Just check to make sure you have enough depth so the subs fit physically and you should be fine. Those Sundown subs move a lot of air so you'll likely need a 3" port per sub which is tricky but not impossible. I did it before so I know with effort it can work. It will likely be easier in your case since you will only have one motor structure to miss with the ports.
  13. Apr 4, 2013 at 4:43 PM
    Bowfisher1
    Ty
    Louisiana
    How much depth is there? And since I am fairly new to car audio please explain what your an by one motor structure and why it will be easier for me?
    What is the set up in that pic?
  14. Apr 4, 2013 at 9:25 PM
    ItalynStylion
    Steven
    DFW, Tx.
    The motor structure is the magnet on the back of a speaker. It makes the cone move. In my last picture I had two speakers per side (the side is divided by the hump in the middle where the driveshaft goes). So it was tricky to get the 3" pipe tube in there without hitting the magnets of two speakers.
    In your case, if you're using 1 sub per side you'll have more room so it will probably be easier. And I can't remember how much depth there is. I think someone tried Alpine Type R's down there (8" version) and those are 4.5" deep so there should be at least that down there. You should be fine.
  15. Apr 5, 2013 at 4:51 AM
    Bowfisher1
    Ty
    Louisiana
    Thank you I think I am going with a sealed box because if I do end up getting these it will be because I feel there is a lack of bass from the two tens I am puting behind the seat. And the box for the tens will be sealed so I'm afraid it will make them sound way to different if one box is ported and one is sealed.
  16. Apr 5, 2013 at 7:10 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Wait......say that again? You're planning on running 10's behind the seat AND 8's under the seat because you're afraid the 10's won't be loud enough?
  17. Apr 5, 2013 at 7:22 AM
    Bowfisher1
    Ty
    Louisiana
    I said I will be puting in the 8's if and only if I think the 10's aren't loud enough. I am Getting the two 10's no matter what.
  18. Apr 5, 2013 at 7:26 AM
    Bowfisher1
    Ty
    Louisiana
    But I'm sure it will be plenty load enough.
  19. Apr 5, 2013 at 9:21 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Yes. If they 10's aren't loud enough you either did it wrong or you can't hear.
  20. Apr 5, 2013 at 3:28 PM
    Bowfisher1
    Ty
    Louisiana
    That's what I was figuring.
