-   -   Help with new audio system for regular cab (http://www.tacomaworld.com/forum/audio-video/272209-help-new-audio-system-regular-cab.html)
Silver Streak 04-07-2013 08:49 PM
I have a couple questions so here i go. A little info on what id like to do. -- Just a basic single din deck. 50Wx4 22w rms around about. Decent 6.5 speakers. Polk or something along those lines. Not sure if i should go for replacing tweeters too?
1 - Which dash kit is a good one? One that actually fits like its supposed to? Dosn't rattle and such.
2 - Do i have to get adapters for the tweeters and 6.5" speakers? not sure if they work without them.
ProForce 04-07-2013 09:23 PM
If you are not replacing the tweeters, buy 6x9" speakers for the front that way you don't need adaptors to fit the 6.5 in there. Polk is a decent speaker for running of ahead unit without amp. Also good are Rockford fosgate 3 way 6x9's. Or even alpine type S. Type E suck IMO and type r shouldn't be run without an amp.
Sounds like your on a good start for a basic system.
eric3187 04-07-2013 11:50 PM
sounds like you want a very basic setup. you might benefit most from just upgrading the headunit and adjusting the EQ to make stock speakers work best.
i would definitely replace the tweeters if replacing the speakers.
