-   -   *HELP* 2nd Gen factory HU wiring diagram! (http://www.tacomaworld.com/forum/audio-video/276216-help-2nd-gen-factory-hu-wiring-diagram.html)
DylansBase 05-02-2013 11:17 PM
Im looking to install a module with the end result of adding and amp/subwoofers. The module itself is not color coded although i do have instructions for what connects to what. All I need is a accurate wire diagram of the stock harness itself. If anyone comes across one and is able to post it, it would be greatly appreciated!
RubberDucky 05-06-2013 01:30 PM
http://www.tacomaworld.com/forum/aud...s-diagram.html
There are a few online... This is from that post:
2012 radio and speaker wires (not with jbl)
- all wires are found behind the radio
radio 12v- light blue
radio ground- brown
radio turn on/ignition- gray
radio ilumination- green(park lights)-- green w/ white stripe(dimmer)
-speakers
driver front speaker-pink (+)-- purple (-)
passenger front speaker- light green (+)-- blue(-)
driver rear speaker- black (+)-- yellow(-)
passenger rear speaker- red(+)-- white(-)
DylansBase 05-07-2013 04:02 PM
Awesome! Helps alot!
radio ground- brown
-speakers
mr2snob 05-08-2013 07:50 AM
Sub'ed. Looking at a self powered bass box and will need the remote turn on and speaker wire colors.
RubberDucky 05-08-2013 10:42 AM
I was trying to post a question about this as well. I am having issues using the "Gray" wire for my remote turn on. I have an Amp and an Equalizer I want to receive power when my truck is on and to automatically shut off when the truck is off. Right now they get constant power and I've got them hooked up to a switch that I manually shut off. I fear leaving it on and killing my battery. I know it will happen sooner or later.
I will keep searching for some other sources and better detailed diagrams. I highly recommend The12Volt.com for a lot of this type of info.
(I have not confirmed any info I am providing, just results from my Googling)
Additional Links:
http://stereowiringdiagram.info/2010-toyota-tacoma/
