-   -   Using the stock XM radio antenna (http://www.tacomaworld.com/forum/audio-video/276655-using-stock-xm-radio-antenna.html)
chris duby 05-06-2013 08:40 AM
I just upgraded my head unit from the JVC-NT1 to the Pioneer AVH-P8400BH and I'm loving every minute if it. I was just wanting to know if there is any way to utilize the stock XM radio antenna that came with my truck, or do I need to get an entirely new setup like the manual of the Pioneer says? It says I need to have the Pioneer GEX-P920XM XM Satellite Tuner for it to work. Here is where I would get it http://www.amazon.com/gp/aw/d/B0009I...dir_mdp_mobile.
If I do have to use it, could the antenna that is already on the roof of my truck work with the Pioneer tuner?
chris duby 05-06-2013 10:44 AM
Anyone?
bldegle2 05-06-2013 10:49 AM
generally speaking, any antenna will work with any unit, pioneer is just trying to get some more of your hard earned...
unless they use a proprietary plug, you are good to go...
chris duby 05-06-2013 11:41 AM
What is a proprietary plug? And, will the stock Tacoma XM tuner "and" antenna not work with the Pioneer?
Chad 05-06-2013 07:24 PM
This may help:
http://www.tacomaworld.com/forum/2nd...-location.html
jparf 05-06-2013 07:41 PM
Does your head unit require this:
http://www.amazon.com/SiriusXM-SXV20...sxv200v1+tuner
The new units can capture both Sirius and XM (they're one company but still have separate programming to prevent the govt from thinking of them as a monopoly). Since yours is an 09 I doubt it would work since the new unit you'd need probably isn't compatible with it. Your 09 probably only picked up either Sirius or XM, I don't know who Toyota partnered with.
I could be entirely wrong but functionally thinking that's my guess. Only one way to find out right!
RMotta2012 05-13-2013 08:31 AM
I just installed a GEX-P920XM XM....... To use the stock Shark Fin Antenna you will need this adapter cable. http://www.bing.com/images/search?q=...electedIndex=0
AZM9 05-14-2013 11:20 PM
The 8400 takes the SXV200V1 and no it is not compatible with the factory sat antenna. But they can mount it right in the bottom corner of your windshield and it will get perfect reception.
