-   -   pioneer avic x940bt help (http://www.tacomaworld.com/forum/audio-video/276987-pioneer-avic-x940bt-help.html)
tstout23 05-08-2013 11:54 AM
ive tried avic411.com with no response and tried contacting pioneer with no response as of yet. i just got it installed and im having some problems. i cant access anything with the navigation or the settings of the head unit. everything is "grayed out" and unclickable.
gps is hooked up and mounted on dash. it shows my location on the screen but i cannot change anything. below are some pictures of what i am trying to explain.
things i added, changed or didnt use:
im using aswc-1 and everything works fine.
i did not hook up the microphone
i hooked up a parking brake bypass with this kit - http://www.amazon.com/Parking-Overri...ss+avic+x940bt
i did not hook up the pink wire (car speed signal input) or violet/white (reverse gear signal input) wire
i am not running an amp or sub, xm radio, rear view camera, traffic tuner.
http://i515.photobucket.com/albums/t...ps9f0a389d.jpg
http://i515.photobucket.com/albums/t...psd8ec2a85.jpg
Aw9d 05-08-2013 11:57 AM
Disable break bypass and see if that helps. I can't do a screen calibration with my bypass on with my Pioneer. Seems like if the unit thinks you are in motion it won't allow you to change settings since you should be paying attention to driving.
tstout23 05-08-2013 12:04 PM
so do i need to hook that wire up to the parking brake once i disconnect the bypass?
Aw9d 05-08-2013 05:35 PM
Just disconnect the bypass first and try that. If that fails then hook it into the parking break. I'm not sure if this is your issue or not but I know with other Pioneer HU's if you use the bypass it always thinks you are in motion and some settings cannot be accessed while in motion.
tstout23 05-09-2013 09:56 AM
disconnected the bypass and it still doesnt work. where do i need to hook up the parking brake wire to?
tstout23 05-09-2013 03:11 PM
i connected the parking wire to ground on the main harness and everything is working fine
Aw9d 05-09-2013 04:30 PM
:thumbsup:
You'll want to put your bypass on a switch to get around this.
tstout23 05-09-2013 08:45 PM
Originally Posted by Aw9d (Post 6866151)
:thumbsup:
to get around what? every time i turn on the truck, after the splash screen it gives a caution screen that the parking brake lead isnt hooked up properly but i hit "ok" and everything works just fine. i love the navi on this unit too
