-   -   Is the fuse the problem? (http://www.tacomaworld.com/forum/audio-video/277425-fuse-problem.html)
ZMan2k2 05-11-2013 04:16 PM
Now, before you tell me, yes the correct fuses are in the mail. But I'm wondering if the smaller fuse is the culprit here.
I removed an Alpine MRP-M500 amp from my truck, which took a 60Amp fuse. I replaced the amp with an Alpine PDX-M6 amp which needs an 80Amp fuse. My issue currently is this, I'm not getting the same level of performance from the PDX that I got with the MRP. My gains are higher, in fact, maxed out, and the sub level control on my HU is maxed as well, usually, it's set to a 6 or 7.
So, is the smaller fuse the issue here? Will I get better performance once I get the larger and correct fuse in the mix?
Rich91710 05-11-2013 04:30 PM
No... and unless the existing wiring is suitable to carry 80a, installing the 80a fuse will increase the risk of fire.
ZMan2k2 05-11-2013 04:41 PM
It is 4ga. Solid ground point, all run and tied properly so that it looks factory. I'm not worried about the wire, more the performance because of the fuse.
Rich91710 05-11-2013 05:02 PM
The fuse is not the problem.
The fuse is simply a safety device that opens when overloaded. It is not a resistor or a regulator.
If the fuse is not blowing on the new amp, then it is "adequate" for the job for now.
ZMan2k2 05-11-2013 06:49 PM
I figured out the issue. I had selected the wrong voltage input on the amp. Selecting the right one, I have the gains at 2/3 and have some of the best bass I've ever had in this truck.
Rich91710 05-11-2013 06:51 PM
Awesome!
