-   -   Anyone using a Kenwood Double Din and does NOT have sun washout issues? (http://www.tacomaworld.com/forum/audio-video/277830-anyone-using-kenwood-double-din-does-not-have-sun-washout-issues.html)
Bmr4life 05-14-2013 01:48 PM
Like some of the other people have posted, I have a Pioneer Double Din and it sucks for daytime driving. The sun washes out the screen to the point that is dangerous for me to focus on it to read it. Unacceptable.
So now I'm going to ditch my X5500 and am looking into more options. I can't seem to find anyone complaining about the 2013 Kenwood Double Dins, but I thought I'd ask here because it appears that the Tacoma's do an equally poor job of protecting the HU from the sun that my Camry does.
DevL 05-14-2013 07:36 PM
With no sunroof and tinted windows I have no issues with the sun.
Bmr4life 05-15-2013 04:44 AM
Using the Pioneer HU??
DevL 05-15-2013 05:33 AM
Have a Kemwood 7"
B737 05-15-2013 01:41 PM
DNX9990HD no such issues
Aw9d 05-15-2013 03:11 PM
I have an AVH-3300BT, no wash out issues that isn't normal for a LCD screen.
RicWolffJr1 05-15-2013 07:00 PM
Pioneer 8500
I just had my pioneer 8500 installed on Saturday....The unit sucks in the daytime, completely useless.....can't see anything during the day and I have tinted windows. I have a 2013 tacoma that had factory touch screen and the factory radio was 100 times better....no washout issues on factory, probably going to have factory radio put back in...
B737 05-15-2013 07:11 PM
^ seriously? Why cant manufactures get this right?
It's one or the other. The display is perfect but the sound and features suck. The sound and features are great but the display sucks.
My Dnx9990hd is so frigging bright at night I had to actually cover the display with 20% tint to tone it down and that's even after I set it to its dimmest settings for night mode.
I can totally understand why you would want to go back to stock.
RicWolffJr1 05-15-2013 07:36 PM
1 Attachment(s)
^i hear ya....did they connect the dimmer wire so the head unit dims when you turn on your headlights? Here is a picture of my unit during the day.....I took it so I could send it to pioneer....
DirtJumper14 05-15-2013 11:24 PM
^ that is not cool. Does your screen tilt forward more?
I just installed a kenwood DNX890HD. Get some sun glare but can always see the screen. Will get a pic tomorrow. But the screen is almost too bright at night at stock settings but holding the bottom left corner brings up the screen settings so it's easy to adjust quickly. A clean screen will help some. I use my oakley sunglass bag to clean it off.
Geem750 05-15-2013 11:37 PM
http://www.tacomaworld.com/gallery/d...420_162613.jpg
Ive had my kenwood 6990 for about a month now and i havnt had any issues like this. never even heard of it until now. the deck is set further back with the new cover plate that comes with it. it could be why im not getting any issues
Rich91710 05-15-2013 11:43 PM
Ditto on my 6990.
Every now and then, the screen might be a bit washed out, but it's not bad. The blacks are black enough that it's generally readable unless it's totally glared out.
I wish the factory clock module was half as robust.
BTW Geem... you do know that you can change that yellow to an orange that matches the factory lighting.
Geem750 05-15-2013 11:49 PM
Originally Posted by Rich91710 (Post 6895447)
Ditto on my 6990.
Thanks, its already set at white but ill probably go amber once i get my 4x4 switch light mod installed :cheers:
Bmr4life 05-16-2013 04:47 AM
I may have to give the Kenwood a shot.
dtopgun515 05-16-2013 06:14 AM
Instead of replacing some of your radios maybe some of you guys could try this....
http://www.tacomaworld.com/forum/2nd...ash-cover.html
B737 05-16-2013 06:23 AM
Originally Posted by DirtJumper14 (Post 6895380)
... the screen is almost too bright at night
even when turned full down... on dark highways at night i find the screen far too bright and distracting. they need to make these things capable of going so dim that only cats can see them at night.
Aw9d 05-16-2013 11:43 AM
What brackets did they use?
If you use the stock metal brackets, the screen sits at an angle which causes tons of viewing issues.
If you use the ones that come with the kit it angles the deck correctly and it won't wash out.
Geem750 05-16-2013 12:52 PM
i find mine quite bright at night, but i havnt looked into changing the brightness for night driving yet.
B737 05-16-2013 12:55 PM
hold down the TEL button it will overlay the brightness controls. i have mine FULL down at night, PLUS 20% static cling tint over the entire face, and its more liveable.
DirtJumper14 05-21-2013 05:07 PM
This is my dnx890hd in the sun. Still see the screen fine in direct sunlight
http://i175.photobucket.com/albums/w...4/IMAG0633.jpg
