2006 Taco DC -- factory JBL amp question
Discussion in 'Audio & Video' started by BenWA, Feb 26, 2009.
  1. Feb 26, 2009 at 12:22 AM
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I want to add an aftermarket amp (to power an aftermarket sub) to my factory system, and to do that I'll need to tie in to the existing factory amp that serves all the speakers in the factory system. Does anyone know if a bypass harness system is available to intercept the unamplified signal from the factory head unit to an aftermarket amp?
    I found one on eBay for 2004 and earlier Tacos, but can't seem to find anything for 2005-2009's with the JBL system:
    http://cgi.ebay.com/ebaymotors/ws/e...50140779536&ssPageName=ADME:X:AAQ:MOTORS:1123
    If no such thing exists, can someone talk me through the wiring that goes into and out of the existing factory amp (pic below)?
    Which bundle is the input bundle from the head unit?
    I'm guessing the smaller bundle on top is the input and the mega-bundle in the middle is the output to the speakers, and the small bundle on the bottom for the sub (but this is just a blind guess).
    Which wires in that bundle do I need to intercept and splice into for an aftermarket subwoofer amp?
    Any assistance here would be appreciated immensely!
  2. Feb 26, 2009 at 2:46 PM
    BenWA
    Boston burbs
    I have another question about this while I'm at it...
    I read somewhere that to turn on the factory amp (JBL system), the factory head unit doesn't have a 12V amp turn-on lead but rather a data signal lead that tells the amp when to turn on. Is this going to be a complication with adding another amp to power a sub? Do most aftermarket amps have automatic signal sensors to know when to turn on? Or do they typically require a 12V turn-on lead from the head unit?
    Forgive my ignorance with all this, I'm more or less a newb with this car audio stuff....
  3. Mar 18, 2011 at 3:10 PM
    twistax
    twistax Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
    Assuming nobody knows this stuff?
  4. Mar 18, 2011 at 3:16 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
  5. Mar 18, 2011 at 4:10 PM
    twistax
    Carlsbad NM
  6. Mar 18, 2011 at 4:21 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
  7. Mar 18, 2011 at 4:23 PM
    BenWA
    Boston burbs
    Whoa, this is an old thread.
    I got the wiring figured out and it is written up in my sub box build thread for anyone who is interested:
    http://www.tacomaworld.com/forum/audio-video/31474-i-built-sub-box-my-06-dc-check.html
    Long story short, I just spliced a line out converter in to the wire harness that plugged into the factory sub. I had to add a new 12V amp turn on lead which I routed from the ACC in my fuse box using an add-a-circut.
    That Crutchfield wiring link was a nice find... I could have used that back when I was doing this but no such link existed back then.
  8. Mar 18, 2011 at 5:23 PM
    twistax
    Carlsbad NM
    Really nice write up man. So the factory amp is pretty much bolted into the truck? Do you have pics of the removal of the factory sub?
