-   -   1st Gen Custom Speaker Install (Front Doors) (http://www.tacomaworld.com/forum/audio-video/285033-1st-gen-custom-speaker-install-front-doors.html)
jdkilroy 07-04-2013 05:37 AM
12 Attachment(s)
Not a lot of info on installing speakers in first gens so I thought I would post some pics for others that may be looking for some ideas on how to do this.
My goal with the install was to maintain a stock appearance. For orientation, these pictures are taken doing the work to the driver's side door panel.
Remove the door panels and the stock speakers and the plastic mounting pieces. (Depending on what you are planning to install, you may want to hang on to the connector to use with your new speakers.)
The inside of the door panel needed to be modified to allow round speakers to fit behind the grille.
Attachment 221415
Attachment 221416
Here I've done some initial trimming and marked the rest of the material to be removed. I used a Dremmel tool with a cut-off blade and a sharp chisel to remove the excess plastic.
Attachment 221417
In this picture the trimming is complete and the 6.5" round speaker fits.
I glue 1/4" closed cell foam strips to the edge of the speaker flange as spacers to prevent the cone from contacting the door panel as it moves outward. I also glued some small pieces of foam in to cover the parts of the stock grille that are not in front of the speaker.
Attachment 221418
Attachment 221419
Using 3/4" MDF, I made a set of mounting rings that serve to allow mounting the speaker to the door itself and to position it right behind the stock grille. Some trimming will happen later to allow the the mounting piece to conform to the elevation changes of the inner door face.
Attachment 221420
Attachment 221421
Need to make marks on the pieces while they are in position to maintain correct position while gluing up.
Attachment 221422
I needed to trim a little of the inner door skin off to allow the speaker frame to clear the door skin without touching. (passenger side door pictured)
Attachment 221425
I did not want to use the stock tweeter grill as it is too small and restrictive. Removal is pretty easy after removing the stock tweeter.
Attachment 221423
Attachment 221424
I will need to glue the new tweeter in place due to what I am installing and the nature of the door panel. You may be able to do something different.
Attachment 221427
I will add to this thread as I complete the install. Going to be a few days for this glue to completely set up.
96tacosx 07-04-2013 08:15 AM
I like this good write up so far looking to do something similar in my truck when the funds are there
JMaberry 08-16-2013 10:37 AM
sub'd!
MoonCrawler 10-04-2014 06:34 PM
Thread revival!! Do you have pics of your completed install? What did you use to trim the inner door skin? I'm going to be installing 6.5" components in my '03 in the next few days. I want to be as prepared as possible so I don't have to have my doors apart for longer than necessary. I'm willing to take the time to do a proper install, just want it to go smooth.
