-   -   how do i remove back interior panels? (http://www.tacomaworld.com/forum/audio-video/78581-how-do-i-remove-back-interior-panels.html)
jasonm 03-02-2010 08:41 PM
i was wondering if anyone out there knows how to remove the plastic panel (the part under the rear window) and the seat backs out of the back of an 07 extended cab taco?
nxtruck 03-02-2010 08:54 PM
Basically, just pull. I didnt fully remove mine, but I pulled it loose enough that I could run some wire and a small project box behind the rear "seat". I started at the bottom near the door sill, then slowly pulled all the clips up the edge to the top corner, then pulled the clips towards the center of the seats. I didnt encounter any bolts that I recall, though I know there are some around the headrest.
As long as you pull the clips directly forward I dont think you will have a problem removing it.
edit: Mines a '10 access cab
Outlaw 03-03-2010 10:37 AM
You might check in the audio section or on Tacotunes website for video or detailed instructions.
rickand 11-26-2010 07:26 AM
the plastic panel simply pulls off (pry up at one end). then unbolt the padded backrest, then the lower panel pulls off.
daggertats 11-26-2010 12:38 PM
if those panels are the same as in a reg cab they do just come right off with a little tug.they got those plastic push things holdin em on.
