Write up/ Review BAMF Light Bar 2012 version.
Discussion in 'Bay Area Metal Fabrication' started by mclovin, Jul 19, 2012.
  1. Jul 19, 2012 at 8:16 PM
    mclovin
    mclovin [OP] chicka chicka, yeah!
    Biloxi
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    Ok bear with me this is going to be a little long just because of the issues that occurred with the install.
    First off I had originally ordered a powder coated light bar from Bay Area Metal Fab and was blown away with the quality of everything, just like my sliders (different topic). I had a Grillcraft insert for my truck on order but as soon as the light bar hit my front door it was on and I was wiring up the lights. First issue was the location of the transmission cooler. I had to move that, no big deal. Next was after the lights were on the bar, they sat way too low for the opening of the grill. I have 7 inch lights and about 2ish inches of them was below the highest part of the grill opening. No bueno. I decided to wait for the GC grill to show up and see how it ended up. Still a no go for my preference and for premium light output.
    At this point I was thinking about chopping up the light bar that I had and welding the outer mounting tabs to the bottom. I ended up talking to Jerry and after some convincing he built me a bar that would lift the lights higher in the grill opening.
    I got it in today finally and he treated me to this new powder coat blend that he’s been bragging about… and yes it is AWESOME! After ripping the box open I started the install. I found that the hood release latch needed to be cut down, and the cover for the latch assembly also needed to be removed.
    After doing this I ran into some issues with the bottom tabs of the latch assembly that need to be cut a little bit…
    Once this was done I found that the bar was not going to fit flush unless one of two things happened. Either it was getting cut or I was going to space it away from the radiator mounts with washers. I went with the washers.
    With the bar now mounted I got the lights on and started to test fit the grill. It was not going to fit at all without modification either. This was for two reasons. The light bar itself was preventing it from sitting even remotely close and that where I mounted my lights were right under the two middle supports. I channeled out the supports and cut down the mounting bolts from the lights.
    Now once this is done it’s a little tricky to get the grill over the light mounting bolts while getting the bottom tabs in to the bottom bumper but with a little finesse success will be achieved!
    Now I can’t say for not if Jerry is going to offer this light bar setup, but for those who don’t mind carving out your grill… I would most definitely recommend this if you plan on running anything bigger then 4 inch lights behind your grill.
    [/FONT]
    phenix likes this.
  2. Jul 19, 2012 at 8:43 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    Nice write up I'm glad it worked out for you.
  3. Aug 11, 2012 at 1:27 PM
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    No modification required to install the regular BAmf light bar on a 2012!
  4. Aug 11, 2012 at 9:01 PM
    mclovin
    Biloxi
    if i hadn't wanted to stuff these 7'in red rings in there the first one would have been boss.:rolleyes:
  5. Aug 12, 2012 at 5:20 AM
    knine00
    Hudsonville, Mi
    Stock for now
    Looks good though!
  6. Dec 4, 2012 at 1:30 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Thank you for posting this!. It saved me so much time on prep and installation. Thanks for sharing.
  7. Apr 17, 2013 at 1:06 PM
    Rhinog
    Rhinog New Member
    Which lights did you use behind the grill?
  8. Apr 17, 2013 at 1:44 PM
    mclovin
    Biloxi
    they were some generic red ring 35w HID lights that i got off a group buy last summer.
  9. Apr 17, 2013 at 5:30 PM
    Rhinog
    Rhinog New Member
    Cool thanks!
  10. Aug 8, 2013 at 11:02 AM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    Damn I want to buy the same lights and put them behind my new MX Grillcraft. But after reading this, it seems like I will run into a lot of problems :(
  11. Aug 8, 2013 at 11:28 AM
    JLee
    Jerry
    Benicia, CA
    Just go with a LED light and you will be fine fitting those big lights tough.
  12. Aug 14, 2013 at 3:06 PM
    mclovin
    Biloxi
    it really wasnt that bad, it was kind of a nice project to work on. to be honest, im thinking about getting an led bar instead so this set up might be available at some point soon
  13. Aug 14, 2013 at 11:39 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    I bought an LED light bar on Amazon. Gonna install it next weekend.
  14. Aug 17, 2013 at 4:30 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Was there any modifications to the light bar other than flipping the mounting tabs over? I got some 7" lights I'm looking at using with my bamf lightbar, so if its just relocating the tabs, ill probably just cut and reweld them.
  15. Aug 17, 2013 at 5:25 PM
    mclovin
    Biloxi
    yeah, the tabs just went from the top to the bottom.
  16. Dec 2, 2014 at 11:06 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So if I was to buy a new one for my 15 there is no mods needed correct? What lights are designed to go on this light bar anyway? Hella's KC Daylighters???? Is this the bar where you have to move the horns?
  17. Dec 6, 2014 at 10:03 AM
    Rhinog
    Rhinog New Member
    I had to move my horn on my 2010. I used rugged ridge slim lights on my mainly just for look to go with the grill I used.
  18. Nov 26, 2015 at 2:17 PM
    TSmalls89
    TSmalls89 Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    OK, where does everyone move the horns to??? I cannot figure this out at all
