-   Camelback Toyota Parts (http://www.tacomaworld.com/forum/camelback-toyota-parts/)
-   -   vibration when start to move (http://www.tacomaworld.com/forum/camelback-toyota-parts/217182-vibration-when-start-move.html)
tacomatato 04-27-2012 03:37 PM
I own tacoma 2005 with 76k miles that is starting to vibrate when it starts moving. The mechanic said that I would need to replace the shaft drive. Does anyone have any idea of what it could be? or has had the same issue? where can I find the shaft drive?
Jorge@CBTParts 04-30-2012 08:06 AM
Can you PM your VIN? Did your mechanic actually inspect the vehicle or was this something that he suggested without looking at it?
Pugga 04-30-2012 08:12 AM
What dealership did you take it to? Some of the Toyota dealerships up here are 'less qualified' than others. There's on in Acton that has a very good reputation.
When you get the vibration, is it just when you slowly start to roll off the line? Does it happen only under hard acceleration or does it vibrate when softly accelerating as well? Does it go away at speed? Any stray noises?
I doubt it's your drive shaft that's defective... It's most likely a drive line component, either a bad u-joint, carrier bearing or even a worn out leaf pack causing axle wrap but I doubt the drive shaft is the problem for a slow speed vibration.
