-   CBI Off-Road Fab (http://www.tacomaworld.com/forum/cbi-off-road-fab/)
-   -   Questions about bushmaster rear bumper and swing out (http://www.tacomaworld.com/forum/cbi-off-road-fab/265077-questions-about-bushmaster-rear-bumper-swing-out.html)
Infra 02-24-2013 02:24 PM
So I'm still scratching my head with a few parts that go to the swing out on the bushmaster rear bumper. First, I have looked at the swing out and cannot figure out where this bump stop is supposed to be mounted on the swing out
http://www.tacomaworld.com/gallery/d...0/IMG_6550.JPG
This is the wire that is supposed to hold the handle to the swing out when not screwed into the bumper. I'm not sure exactly how this wire gets crimped, care to clue me in on how it works?
http://www.tacomaworld.com/gallery/d.../IMG_65492.JPG
Thanks for any help you guys at CBI can contribute.
JLink 02-25-2013 10:22 AM
That bump stop should go on the swing out just above where the screw that holds the swing out closed. As far as the cable.. I haven't done mine yet. I have 2 that help support my table and 1 that I could use for the screw and have a carbiner to clip it to the screw.. Not sure if ill ever do that. I've also been wondering about getting some thick rubber to glue to the swing out and cut a hole in it for the screw that way the handle doesn't point down. If I shim it out 1/4" the handle will be rotated up enough so it can't get caught on a rock or something.
But as far as how to crimp it.. I was going to use a crimper we have at work, but you could probably crush it pretty good with a vise
CBI Offroad Fab 02-27-2013 07:10 AM
Yes the plastic bumper stop does go on the back side of the swing away arm. There should be a tab that you can bolt it to. Bolt it so that the rounded side is pointing towards the bumper when closed. This bumper stop is important to mount up so that the swing arm rests on the bumper when closed.
The cable as mentioned goes with the handle. Put on single crimp on one end and then thread it through the hole on the back of the plate where the handle screws in. Then put another single crimp on the other side to lock it onto the handle plate. The double crimp is used around the center of the handle. Be sure to put it on tight enough that the handle will not fall out but loose enough that the cable will still slide as you tighten the handle down.
If you have any more questions just let us know!
JLink 02-27-2013 07:22 AM
Ill have to take a look at that. Thanks Nathan. I'm still working on getting some pictures to send to you with my thoughts on the bumper.
agv1700 02-27-2013 10:44 PM
No thread jack intended, but I was wondering and i myself have a question for you guys about the bushmaster 2.0 w/swing out, or those of you that own one...
Is the swing out removable? If so how easy is it to remove, and does anyone have any pics???? Thx, and again apologies to the OP, not trying to steal your thunder.
Infra 02-28-2013 08:13 AM
Yes the swing out is removable. The bushings that are in the swing out are very tight on the spindle and I found it very hard to get the swing out on, so I am assuming it will be a little difficult to remove it when need be.
To remove the swing away there are a few easy steps. There is a top plate that sits on top of the spindle, it is bolted to the bumper (this helps prevents theft of your swing out, but is easily removed if you have the tools to do it) and has a set screw in it. Back out the set screw, remove the 2 bolts holding the top plate on the spindle, take the top plate off and then you are ready to lift the swing out up and off of the spindle
Top plate that goes on top of spindle and is bolted to the bumper.
http://www.tacomaworld.com/gallery/d.../IMG_65631.JPG
Set screw on top plate
http://www.tacomaworld.com/gallery/d...m/IMG_6564.JPG
agv1700 02-28-2013 11:31 AM
Outstanding... Thx for the reply!
Infra 02-28-2013 12:12 PM
No problem bud :thumbsup: If you have any more questions or want to see some more pictures just let me know
CBI Offroad Fab 02-28-2013 03:13 PM
Great information guys! Just to add a little from our experience...
The brass bushings do fit tight but if you unload your swing arm and spray some WD-40 on the spindle and then take a moment to work in down the spindle by swinging the arm back and forth then it will dramatically help to pull the swing arm off of the spindle. You can use the same procedure to put the swing arm back on the spindle as well! Usually takes a couple of minutes to remove the swing away with this setup once you have removed the accessories from it.
