What adhesive to use to put on a emblem?
Discussion in 'Detailing' started by Nolawall, Aug 11, 2011.
  1. Aug 11, 2011 at 7:03 PM
    Nolawall
    Nolawall [OP] "And there I was just minding my own business"
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    6" Fabtech Suspension Lift. K&N Air Filter Cobra 18 CB with 2 3' firestik II antennas
    I had two emblems on my truck stolen. The door Toyota tacoma emblem and the SR5 on the back door. So now I had to go on ebay and buy a used one. How the hell do i glue it on the truck?? What adhesive do I use for this?
  2. Aug 11, 2011 at 7:12 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    3M Double sided tape
  3. Aug 11, 2011 at 7:14 PM
    OffroadToy
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Goop works pretty good. Might need to tape it in place and let it sit overnight but once that stuff cures it's on there.
  4. Aug 11, 2011 at 7:16 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    [​IMG]This^^^^^^
  5. Aug 11, 2011 at 7:17 PM
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Is that stuff thin enough? I dont want to have a huge gap in between.
  6. Aug 11, 2011 at 7:17 PM
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    so double sided tape it is!!
  7. Aug 11, 2011 at 7:18 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    well,i think thats what it came with from the factory...stuff works good.
  8. Aug 11, 2011 at 7:19 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Epoxy. Done. It won't EVER come off.
  9. Aug 15, 2011 at 3:12 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    +1 this is what you want to use. clean the surface with alcohol to get it nice and clean, apply it firmly(best on a warm day but not necessary), and it will stick pretty damn good. lay it on there and trim off the excessive.
  10. Aug 15, 2011 at 3:30 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    3M double sided tape
  11. Aug 24, 2011 at 4:29 PM
    Nolawall
    Nick
    Virginia Beach
    2002 Dbl Cab Tacoma
    Done thanks for the help
  12. Aug 24, 2011 at 4:38 PM
    mcdowell
    mike
    mobile al
    2011 prerunner SR5
    Holding tag
  13. Aug 29, 2011 at 7:37 AM
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    3M makes several double stick tapes that we call gorilla tape that has a red protection strip on them. The sticky part is totaly clear. Some of them are over 1/8" & their are some 1/16 " & one that is paper thin. That I use.
    I see the OCC boys use the same think on their logs.
  14. Sep 5, 2013 at 2:20 PM
    Brock19
    Brock19 Well-Known Member
    brock
    southern utah
    Trail gear bolt-on sliders. BLHM, AUX relayed fuse block, Plastiderp, Diff breather mod, Paracord handles, Trex eyelids, Spacer lift (for now), Magnaflow offroad series cat-back exhaust. sound system, limo tint on all windows excluding windshield. all pro rear bumper with side plates
    what thinkness of the 3m tape did you use?
  15. Sep 14, 2013 at 4:13 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    Dude this thread is a year old.
    The red one, that's it. Thin as possible
  16. Sep 14, 2013 at 5:43 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    What I used.
    After cut out and I used two strips had to trim very little off the bottom and a razor blade on the very edge of the back will make life easy.
  17. Sep 14, 2013 at 5:45 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    At least he searched and didn't make a new one.
    TacoJut likes this.
  18. Sep 14, 2013 at 5:47 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    I have that 3M automative tape if you don't want to buy it.LMK.
  19. Nov 1, 2013 at 6:41 AM
    AbstraKt
    AbstraKt Member
    +1 on the double-sided 3M
